RE: Bernard Dumas' Canadair CL-215
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Bernard Dumas' Canadair CL-215
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Bernard Dumas' Canadair CL-215 - 5/15/2007 2:37 AM
Kmot
Score: 130
Last Login: 11/8/2009
Status: offline
Yeah, awesome stuff! Why not machine all the way through on some of those parts?
_____________________________
~Tom~
Hide Signatures
(in reply to akflyer)
       Post #: 176
RE: Bernard Dumas' Canadair CL-215 - 5/15/2007 8:04 AM
g_boxwood
Score: 100
Last Login: 11/2/2009
Status: offline
Dunno way... it would be easier too... that's how they're designed on the plans and I think they look nicer and 'more complicated'.
You got the point anyway, since when I dealt with a machinist and gave him plans of the lower arm I considered the cut-through option as the simpler one in case he opted for a quicker and less expensive job.
Thanks for the kudos akflyer!
Giacomo 'g_boxwood' Bosso
Hide Signatures
(in reply to Kmot)
       Post #: 177
RE: Bernard Dumas' Canadair CL-215 - 6/19/2007 2:22 PM
g_boxwood
Score: 100
Status: offline
I'm sorry I'm not working on the 215 at all in this busy period but in the last few days I found some time and patience to deal with the main gear physical mock-up.
At first I wasn't sure whether or not to build it, but as things are getting together I feel happy I did it.
I want to be sure that the cinematics will work fine and that every single gear element will be fine the way they have been CAD modeled. I want to be sure of that BEFORE committing the gear to the machinist.
I wanted to make the elements as simpler as they could possibly be but I ended up making them as complex as they are. The only ones I really simplified were the gear legs.
I still need to finish some elements, but the attached pics show some of the already done work.
I also got my Bimba actuators so I plan to the test the whole system with the wooden mock-up before having it machined.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to g_boxwood)
       Post #: 178
RE: Bernard Dumas' Canadair CL-215 - 6/20/2007 12:32 PM
g_boxwood
Score: 100
Status: offline
OK, I finished all the elements and put them together: they do work!!!
Some trimming here and there will be required but everything looks really fine.
Now that I better understand the role of every single piece I can re-draw them to make them easier to machine in case it speeds things up a bit and/or keeps costs down.
I'll now correct some interferences and try to operate the whole sys, I'm both excited and worried at the same time... the Bimba cylinders come with HUGE clevises... I need to find something different...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 179
RE: Bernard Dumas' Canadair CL-215 - 6/27/2007 11:31 AM
g_boxwood
Score: 100
Status: offline
Attached are a few pics of the entire assembly in primer w/ Robart 3-1/4" wheels and the upper locking/unlocking cylinder. The actuating lower cylinders are still missing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 180
RE: Bernard Dumas' Canadair CL-215 - 6/27/2007 12:30 PM
Strykaas
Score: 123
Status: offline
Awesome
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
       Post #: 181
RE: Bernard Dumas' Canadair CL-215 - 6/27/2007 9:24 PM
teresos
Score: 100
Status: offline
Good work Giacomo....
Don't forget to place the wheel axle in about 4 degrees , so wenn the all system lock's in the upper position the wheel must be as flat as possible with the sides of the fuse.
Click for fullsize
No risk , no fun ...no fun , no life...
Hide Signatures
(in reply to Strykaas)
       Post #: 182
RE: Bernard Dumas' Canadair CL-215 - 6/28/2007 7:09 AM
g_boxwood
Score: 100
Status: offline
You're right Teresos, fact is that the gear legs in the mock-up are the only simplified items... I drilled the axle bolt hole flat.
Why should the wheels be in a plane parallel to the fuse sides?
I'm asking it since I'll be using Robostruts as the gear legs and I don't think I'll be able to cant the axle down @ -4°. In a Robo the axle is perpendicular to the leg axis.
Hide Signatures
(in reply to teresos)
       Post #: 183
RE: Bernard Dumas' Canadair CL-215 - 6/29/2007 5:13 PM
teresos
Score: 100
Status: offline
I personally believe that if the wheels are parallel to the fuse, and close to it like the real one ,then the flying will be less affected . Moreover ,when this 6 Kg-- and more-- plane is about to land ,it is suggested that the wheels are vertical to the ground ,so that the axles and generally the whole landing system will be less distressed.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 184
RE: Bernard Dumas' Canadair CL-215 - 7/2/2007 1:58 AM
teresos
Score: 100
Status: offline
quote:
ORIGINAL: g_boxwood
Let me make a suggestion
You can try to increase the length of the clevis ,where the Robo join the upper strut, so the " package" Robostrut-Axle-Wheel , are vertical to the ground ......,or share the whole distance in two halves and increase-decrease the length of the upper and lower clevis.
Hide Signatures
       Post #: 185
RE: Bernard Dumas' Canadair CL-215 - 7/2/2007 1:53 PM
LADISLAV
Score: 100
Last Login: 11/7/2009
Status: offline
This drawing from maintenance manual might help.
Click for fullsize
Hide Signatures
       Post #: 186
RE: Bernard Dumas' Canadair CL-215 - 7/2/2007 6:10 PM
g_boxwood
Score: 100
Status: offline
Thanks both of you. I'll deal with it later on. And I'll come back to you for advises.
I re-assembled the gear after a coat of paint I sprayed just to seal the wood. Don't worry about the grey... it is the only one I had readily available.
I messed up with the Bimba order and I got the cylinders with an uncorrect air-port alignment: even if the options are only 2 (rotated 90° or not) ... I ordered exactly the opposite I needed.
You can see what I mean in pic #3: the air-ports are coming straight out of the bulkhead, where I grinded a window. This is not good and I preferred to work onto the attachment points of the cylinders themselves (pic #4) to get the correct orientation of the ports. The extra hole and the removed material doesn't seem an issue in terms of cylinder strength.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to LADISLAV)
       Post #: 187
RE: Bernard Dumas' Canadair CL-215 - 7/2/2007 6:16 PM
g_boxwood
Score: 100
Status: offline
Next I wanted to connect the upper cylinder to the air system to test if it helps getting the gear up/down: pic #1 shows how much it lifts both legs. Then the arm becomes too little and it can't do anything else. This is no matter anyway, since the main work will be done by each lower cylinder, the upper one being deputed to locking and unlocking only. Just curious...
Pic #2 (in the middle) shows the correctly rotated air-ports on the upper cylinder, NOW facing down!
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by g_boxwood -- 7/3/2007 5:47 PM >
Hide Signatures
       Post #: 188
RE: Bernard Dumas' Canadair CL-215 - 7/4/2007 10:17 PM
teresos
Score: 100
Status: offline
quote:
ORIGINAL: g_boxwood
One more mod you must take care off before machining ......
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 189
RE: Bernard Dumas' Canadair CL-215 - 7/5/2007 6:34 AM
g_boxwood
Score: 100
Status: offline
AAAAAhhhhhhhh!!!!
Thanks for sharing!
Hide Signatures
       Post #: 190
RE: Bernard Dumas' Canadair CL-215 - 7/17/2007 8:48 PM
Turbo_jet
Score: 100
Last Login: 2/27/2008
Status: offline
[image][/image]I dont speak english.Please picture wing.
Hide Signatures
       Post #: 191
RE: Bernard Dumas' Canadair CL-215 - 7/18/2007 6:48 PM
teresos
Score: 100
Status: offline
Have you done anything with the cockpit ?.
This is mine design .I decide to make it in one, separate piece, so I can have access inside the cabin....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 192
RE: Bernard Dumas' Canadair CL-215 - 7/18/2007 6:58 PM
teresos
Score: 100
Status: offline
The windshield is made from lite ply , the rest one is made from some scrap balsa sheet ,joined together .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 193
RE: Bernard Dumas' Canadair CL-215 - 7/18/2007 7:06 PM
teresos
Score: 100
Status: offline
......and.. , after some hours of ,triming and laping...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 194
RE: Bernard Dumas' Canadair CL-215 - 7/18/2007 7:59 PM
Turbo_jet
Score: 100
Status: offline
I am begging you to grant the plan of the building of a wing.
Hide Signatures
       Post #: 195
RE: Bernard Dumas' Canadair CL-215 - 7/18/2007 9:31 PM
g_boxwood
Score: 100
Status: offline
Really really nice teresos!!! The notch is definitely a top trick!
Did you get all the infos from the plans or was it a try & fit process or both?
I always thought the plans lacked all the required infos to easily build the cockpit! Am I missing something?
This is a really bad period, last exam of the session is tomorrow then probably holidays in Greece (but I'm not sure about them any longer after I spoke with my girlfriend a few minutes ago) then back to studying in time for September... Not much time and energy left for building... I'm really pissed off!!!!!
Turbo Jet: no wing has been built yet, at least on my side of the building.
Hide Signatures
(in reply to Turbo_jet)
       Post #: 196
RE: Bernard Dumas' Canadair CL-215 - 7/19/2007 1:03 AM
teresos
Score: 100
Status: offline
Turbo Jet: First pic is the plan.....next 2 is the wing........
You can find the plans here ... http://bernard.dumas.chez-alice.fr/Plans.htm
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 197
RE: Bernard Dumas' Canadair CL-215 - 7/19/2007 1:37 AM
teresos
Score: 100
Status: offline
quote:
ORIGINAL: g_boxwood
Yes , it was a try & fit process , and hopefully it was successful .....I believe that the plans are not so instructional at this point of building .
Hide Signatures
       Post #: 198
RE: Bernard Dumas' Canadair CL-215 - 7/19/2007 12:07 PM
Turbo_jet
Score: 100
Status: offline
Ask for more pictures.
Hide Signatures
       Post #: 199
RE: Bernard Dumas' Canadair CL-215 - 7/19/2007 3:45 PM
Kmot
Score: 130
Status: offline
It is very enjoyable to watch such masters building their airplanes!
~Tom~
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.641RCU1
