g_boxwood -> RE: Bernard Dumas' Canadair CL-215 (8/23/2007 3:22:24 PM)
Having built the main gear mock-up gave me some satisfaction but it also showed me with little regard that making it work the way it is designed would have been a painful experience. Page 7 (scroll down to last pictures) of this 3d shows original cylinders placement: http://www.rcuniverse.com/forum/m_4400160/mpage_7/key_/tm.htm I had to deal with it before committing time and patience to a non-rewarding matter: that setup isn't the best... for a number of reasons: 1. cylinders may (and they WILL) interfere with each other, their endcaps are larger than main body diameter 2. cylinders are a pain to fit in place in the finished model, they're a pain to fit even in the mock-up which was thought to ease things up a bit... 3. cylinders cannot be seen during operation = poor diagnostics of possible (if not certain) problems 4. if the cylinders are a pain to fit you can imagine how terrible it can be to fine-tune the linkage, and the tuning is a must... 5. cyllinders exit through a hole in the fuse and this compromises water sealing So we have difficult installation, almost impossible setup, invisible operation and super-tight accessibility... too many bad things not to deal with them right now. The attached pictures show what I came out with: everything is based on what I already have put together, with NO modifications to the already built fuse nor to the gear elements themselves, GIVEN the 1" stroke main cylinders that I own. Again, everything has been worked out trying not to touch anything and the simulations show that there is no interference between the gear operation and the fuselage (this is why I modeled a length of airplane cabin section). This way, which may not be the only possible way, almost all the bugs are worked out: you can see the cylinders working, you can install and remove them more easily, no more holes in the fuse sides... it sounds good to me. The only problem seems the little arm... this is forced by the 1" stroke of the cylinders, but remember that the not pictured locking/unlocking upper cylinder helps with the actuation of the entire system, especially at the endpoints (where the arm is at its smallest). Obviously every feedback and/or advise would be greatly appreciated!
