how to pick a brushless
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> how to pick a brushless
Page: [1]
Login
how to pick a brushless - 6/17/2006 4:19:23 PM
wo23dodge
Status: offline
I've read so much here about going brushless and it seems everyone uses a different setup,what specs are you looking for when picking one?
One is the size of the motor? (20MM)
while looking for a brushless for my Styker plane I found this
http://www.aero-nuts.com/product_info.php?cPath=37_77&products_id=203
they also carry a step down version
http://www.aero-nuts.com/product_info.php?cPath=37_77&products_id=202
Price is right if one will work.
       Post #: 1
RE: how to pick a brushless - 6/20/2006 2:52:22 AM
wo23dodge
Status: offline
Nobody can tell me what I need to know to pick a brushless,I am not even 100% sure what I need to look at to be sure it will even fit
(in reply to wo23dodge)
       Post #: 2
RE: how to pick a brushless - 6/21/2006 2:23:19 AM
Truglodite
Status: offline
your stryker is powered by a 480 setup. you need a bigger 300W class motor and a 35A esc.
something like this warp4 motor might work.
before i'd buy, i would ask someone else who has experience with running brushless motors in strykers. they're probably hanging out in the wattflyer forums or somewhere besides here.
try the guys in this forum:
http://www.rcuniverse.com/forum/m_3738912/anchors_4187398/mpage_35/key_brushless/anchor/tm.htm#4187398
_____________________________
whew, r/c used to be so much simpler.
       Post #: 3
RE: how to pick a brushless - 6/21/2006 2:28:56 AM
wo23dodge
Status: offline
I'm sorry,I guess I wasn't very clear.
I happened to find these brushless motors while I was looking for one for the Stryker and was thinking maybe one of those two in the links would work with my Blade CP?
(in reply to Truglodite)
       Post #: 4
RE: how to pick a brushless - 6/21/2006 2:38:17 AM
Truglodite
Status: offline
i see, in that case, both motors should fit (20mm, 2mm shaft), but the 4600 might give too much head speed with the stock tx, and the 2800 might overheat. somewhere around 3200kV is best if you're using the stock tx. 4600 would be nice if you have the ability to adjust your throttle curve to limit RPM.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU5
