MVVS 26 rod bearing ate back plate X2
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 26 rod bearing ate back plate X2
Page: [1]
Login
MVVS 26 rod bearing ate back plate X2 - 6/18/2006 1:51:43 AM
clm
Status: offline
Just had my second MVVS 26 gas engine rod bearing eat the back plate. The rod bearing bulges causing it to rub against the back plate, chafting the aluminum. Aluminum flakes go throughout the engine destroying it.
1st engine I'm told was due to not using fully synthetic oil @ 32:1 ratio.
2nd engine just received in March this year and just finished the second gallon of fuel using Mobile Racing 2T oil at 30:1 ratio.
What caused the second engine to go?
Is this a common problem with the MVVS engines?
Where can I get warranty work done on the second engine?
I really like the MVVS 26 engine until the second gallon of fuel then I just get sick when they eat themselves.
please advise
clm
PS picture shows grove in back plate. If you look closely you can see the rod bearing bulge on the far left side (9 o'clock position) and aluminum shaving eveywhere.
Click to see fullsize image.
Click for fullsize
< Message edited by clm -- 6/18/2006 2:00:32 AM >
       Post #: 1
RE: MVVS 26 rod bearing ate back plate X2 - 6/18/2006 9:00:56 AM
DarZeelon
Status: offline
Curtis,
I have not seen this happen on any MVVS gas engine.
Let's see if Pe can add anything.
Who did you buy this engine from?
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to clm)
       Post #: 2
RE: MVVS 26 rod bearing ate back plate X2 - 6/18/2006 12:04:50 PM
clm
Status: offline
I purchased both engines from PE.
Using a Mejzlik 18-8 prop @ 7900 to 8100 prm with tuned pipe.
Its the bulged bearing that appears to be milling the back plate.
< Message edited by clm -- 6/19/2006 1:48:00 AM >
(in reply to cyprusjets)
       Post #: 3
RE: MVVS 26 rod bearing ate back plate X2 - 6/19/2006 12:44:50 PM
pe reivers
Status: offline
Curtis,
I already sent you mail with instructions. Please do send me the information I asked for.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to clm)
       Post #: 4
RE: MVVS 26 rod bearing ate back plate X2 - 12/2/2007 10:31:13 AM
Garikoitz
Status: offline
I had EXACTLY the same problem with my engine one year ago. I phoned the shop where i bougth it (in warranty time) and they told me that i had to SEND IT to "Checoslovaquia" the country where they buid them. I still dont know what to do with that problem. Please if you know how can i repair it send me an e-mail to g_errasti(a)yahoo.es
Thank you very much
Garikoitz.
Sorry for my poor english.
(in reply to pe reivers)
       Post #: 5
RE: MVVS 26 rod bearing ate back plate X2 - 12/2/2007 2:11:43 PM
pe reivers
Status: offline
For warranty work, You indeed are best off sending it to the factory directly.
I have sent you a mail with all details for shipping.
(in reply to Garikoitz)
       Post #: 6
RE: MVVS 26 rod bearing ate back plate X2 - 12/3/2007 2:36:14 PM
Garikoitz
Status: offline
I've just send it to the given address.
Garikoitz
       Post #: 7
RE: MVVS 26 rod bearing ate back plate X2 - 12/24/2007 1:22:45 AM
chadderbox
Status: offline
I have had the same problem too. I had to rebuild mine twice now. My oil is mixed corectly with mobil syn.. I e-mailed MVVS and they said it was a cooling issue. I have done every thing I can to this thing with coooling baffles etc.... HELP!!!!!!!!!!
< Message edited by chadderbox -- 12/24/2007 2:45:19 AM >
(in reply to clm)
       Post #: 8
RE: MVVS 26 rod bearing ate back plate X2 - 12/24/2007 3:15:33 PM
pe reivers
Status: offline
Can you post pictures of your set-up?
The engines I repaired indeed all had cooling issues. (lack of cooling, or prop too large)
The piston coating prevents the engine from sagging, so you get no warning of engine distress until too late.
(in reply to chadderbox)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU5
