altacom
WA, USA Status: offline
Wow! Looks like I'm not the only one with the problem. Mine actully just quits sending a signal. I've lost 2 planes, and both the same way. Flying great, and just quit flying and go in. I was fortunate enough that my New QQ Yak flew the first flight flawlessly, after an hour of charging (It's Electric) I taxied out to the runway, and throttled back while getting into the cage. I advanced the throttle for takeoff, and the plane went into failsafe. (FMA Receiver) took it back to the pits and still no joy. Turned on another plane, and same thing immediatelly went into failsafe. Shut everything down, removed the module, tweaked the pots, fired everything back up, and all was well. No way was I going to put another $1500 plane up with this kind of a problem. Bought a Futaba 9C and no longer have problems. After the first major crash I sent the transmitter in, and it was returned as no problem found. Didn't see much sense sending it in again. The Hitec has been sitting on the shelf for 6 months now. At a recent contest I was told that a Futaba 9C single Frequencey module (as came with my 9C) can be used in place of the synthesized module, and the transmitter becomes useful again. Has anybody done this, and if so was it a successful change. I hate to have equipment just sitting round that I or someone else might be able to use. But I sure won't use it or sell it if it can't be depended upon. And I don't recommend the Optc 6 to my students.
