XJet
Joined: 3/31/2003 From: Tokoroa, NEW ZEALAND Status: offline
Chester, like yourself I've bought more than a few lemons in my time but I've learned one thing: *all* manufacturers make mistakes and they all (occasionally) have products that need to be recalled. It's how they subsiquently handle the recalls that sort the "good" companies from the "not so good". To its credit, Hitec has a great support reputation and often fix stuff for free that other manufacturers would charge an arm and a leg for. On the filp-side, Hitec also has a policy of "deny or downplay" many of the problems they've had with their products. Digital-servo lockups, Optic 6 AAA fault, Optic 6 handle weaknesses, Electron 6 thermal issues, 5955GT/programmer issues, Fusion 9 problems, Optic/Spectra glitches. These are all examples where there *have* been problems but Hitec has significantly downplayed or (in some cases) denied them. Perhaps it's US product liability laws and their insurers that prevent them from being alittle more up-front about the existance or scale of these problems when they occur -- or maybe they're just aware that the vast majority of customers don't visit RCU so won't be aware what's going on. However, I still buy Hitec gear (albeit I wait for the inevitable bugs to be sorted in new releases) because it's still pretty good value. I've got: an Eclipse 7 and use it every day. An Optic 6 (that sits under my bench with AAA on the display -- it's not worth sending all the way back to the USA from where it was purchased so Hitec's free upgrade is worthless to me), a Supreme 7-channel receiver, a 555 5-channel receiver, 2 x QPCM receivers (also worthless to me now because only my faulty Optic 6 does QPCM, my Eclipse doesn't), a Feather receiver (best not talk about that), 4 x 5955TG servos, 30+ HS425BB, 12 x HS475, 2 x HS5475, 4 x HS5925, 4 x HS700, 4 x HS81, 4 x HS645, and a snot-load more stuff. Once the Fusion 9 problems (which don't exist) are sorted I'll probably buy a couple of those and when the new Hitec 9-channel transmitter comes out I'll toss up whether to go for that (after the bugs are worked out) or a Futaba 9C. What people forget is that Hitec gear is generally quite a bit cheaper than most other name-brands so don't expect to get the same quality or performance as a top-of-the-line JR set. Of course that doesn't mean you shouldn't get something that actually *works* for your money. Like yourself, I wish that Hitec would pay the ticket to have stuff with obvious manufacturing defects returned to them (and back to you) for repairs (then I could use *all* that stuff that's currently worthless to me because of Hitec's manufacturing/design faults). But hey, we're talking Nissan-type RC, not Rolls Royce.
_____________________________
When I'm not here, I'm at RCModelReviews
