PST contact?
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Turbinator - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $138.98   |  9/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> PST Jets >> PST contact?
Page: [1] 2 3   next >   >>
Login
PST contact? - 6/21/2006 8:35:34 PM
Rider-60
Status: offline
Hi,
I need servicing on my 600r and tried to email PST , but it's been returned undelivered.
What is the correct e-mail adress?
also is there a service center in europe?
Florent
< Message edited by Rider-60 -- 6/21/2006 9:59:58 PM >
       Post #: 1
RE: PST contact? - 6/21/2006 10:59:40 PM
tschuy
Status: offline
Have you tried this from their site: http://www.pstjets.com/contact.html
They also have dealer contact information posted here: http://www.pstjets.com/dealers.html
Cheers,
< Message edited by tschuy -- 6/21/2006 11:01:34 PM >
_____________________________
Tim Schuy
tschuy@comcast.net
(in reply to Rider-60)
       Post #: 2
RE: PST contact? - 6/22/2006 1:11:48 AM
Kelly W
Status: offline
quote:
ORIGINAL: Rider-60
Hi,
Florent
Hi Florent,
What email address did you try? Was it pst@pstjets.com?
(Sorry, don't know why it screws the address up like that but you should be able to read it near the end of that messy character string...)
Kelly
< Message edited by Kelly W -- 6/22/2006 1:13:34 AM >
Kelly Williams, GTBA #1969
       Post #: 3
RE: PST contact? - 6/22/2006 9:21:59 AM
Rider-60
Status: offline
I tried this one , I ended up leaving a message on the site automatic box.
----- The following addresses had permanent fatal errors -----
<pst@pstjets.com>
----- Transcript of session follows -----
... while talking to pstjets.com.:
>>> RCPT To:<pst@pstjets.com>
<<< 550-Callback setup failed while verifying <FColombet@aol.com>
<<< 550-Called: 205.188.156.249
<<< 550-Sent: initial connection
<<< 550-Response: 554- (RTR:SC) http://postmaster.info.aol.com/errors/554rtrsc.html
<<< 550-554 Connecting IP: 202.142.213.196
<<< 550-The initial connection, or a HELO or MAIL FROM:<> command was
<<< 550-rejected. Refusing MAIL FROM:<> does not help fight spam, disregards
<<< 550-RFC requirements, and stops you from receiving standard bounce
<<< 550-messages. This host does not accept mail from domains whose servers
<<< 550-refuse bounces.
<<< 550 Sender verify failed
550 <pst@pstjets.com>... User unknown
Kelly I sent you an e-mail, do you service only american engines or will you take european ones as well?
shiping to thailand or to USA is pretty much the same for me.
(in reply to Kelly W)
       Post #: 4
RE: PST contact? - 6/22/2006 4:52:05 PM
Kelly W
Status: offline
Hey Florent,
I haven't received an email from you. I wonder if your account is somehow marked as a spam source or something to that effect? My service provider will automatically nuke a spam, so I'll never see it if it gets red flagged... I'll try sending you an email right away, since I think i see it in the previous post, and we'll talk over your engine servicing. In your case though, I'd still recommend sending it back to Thailand.
Kelly
       Post #: 5
RE: PST contact? - 6/22/2006 5:22:53 PM
Rider-60
Status: offline
Hi Kelly,
May be is it my aol account??
anyway I got your e-mail and replied, thanks
Florent
       Post #: 6
RE: PST contact? - 7/30/2006 8:02:40 PM
speedbrake
Status: offline
Kelly,
I'm installing a 600R in a R54. This is my first turbine. The manual isn't clear about the fuel system. The instructions say to connect the main tank to the header tank, then the header tank to the shutoff valve, then to the fuel pump, then to a fuel filter, and finally to the turbine. However, the diagram provided shows a different arrangement. What is the correct way to set up the fuel system?
The fuel pump I have doesn't have the mark mentioned in the manual describing the "in" nipple. It has instead an arrow going across the two nipples. I assume the arrow indicates the direction of fuel through the pump; thus the point of the arrow is the exit nipple - fuel to the turbine (?).
Please advise,
Keith Lindsay
       Post #: 7
RE: PST contact? - 7/30/2006 9:07:11 PM
Kelly W
Status: offline
quote:
ORIGINAL: speedbrake
Kelly,
Please advise,
Keith Lindsay
Hi Keith,
The pump supplier has since changed. You're correct that the arrow designates the direction of flow, so the one closest to the pointy end of the arrow goes to the turbine.
The shut off valve can go before, after, or one on both sides of the pump if you wish to have multiple emergency shut offs. Having it after the pump may cause a little more heat generation in the pump motor brushes due to the fact that the motor is effectively stalling when you close the valve while running. The advantage to using the valve after the pump is the net positive pressure on the o-ring seals. They are designed to operate with internal pressure, not a net vacuum. (same with all Festo or similar branded connectors) However, placing the valve on the inlet of the pump, so long as it has a reliable seal, does have one minor advantage. Upon closing the valve while the valve is running, the resistance to the inlet will instantly cause the pump to cavitate and run closer to a free wheeling condition. The current draw will be minimal and the valve won't see any undue wear since its still lubricated. Personally though, avoiding the extra leak point in return for a small amount of brush wear (if you ever need to shut it off with the valve) is a good trade-off. I always install the valve after the pump.
So, what I'd do in your case is:
Main Tank ---- UAT ------ Fuel pump ---- Filter ---- Ball Valve ------- Motor
The ball valve can be placed before the filter with no side effects, just go with whichever method is easier to install.
Other notes:
The filter position is critical for 2 reasons. 1st, you need to be aware that a fuel pump itself will create debris in the fuel system, a little more so when its new or near end of life. The filter should be placed between the pump and engine for this reason alone. Secondly, if the filter were placed before the pump, upon collecting debris and increasing its restriction it can cause cavitation in the fuel pump. That can cause all sorts of problems from the irregular fuel flow into the engine, again more reason to place it after the pump. If you’re using a UAT, the filter will be redundant before the pump anyway, since the UAT has an integrated filter. The UAT’s filter won’t cause a lot of restriction though, since its surface area is very large.
Keep in mind that the all fuel lines before the pump should be the largest reasonable size that you can use, and as short as possible. The pump's inlet should be as close to atmospheric pressure as possible for a healthy fuel system.
Good luck with the engine!
Kelly
(in reply to speedbrake)
       Post #: 8
RE: PST contact? - 7/31/2006 6:46:26 PM
speedbrake
Status: offline
Thanks Kelly,
I used your recommendations to set up the fuel system. I can't believe how many questions I have about setting up the engine. I'm sure the engine will become less mystifying once I have run it a few times. I just need to balance the model and charge the batteries....to be ready for the first flight.
I read many of your responses to other modelers about the 600R. I too had problems understanding how to plumb the gas system....but fortunately you provided some clear directions and photos.
Where can I purchase some 4mm tubing?
Thanks again for the help,
Keith
       Post #: 9
RE: PST contact? - 8/1/2006 5:37:29 AM
Kelly W
Status: offline
There are a variety of on-line retailers here that can supply 4mm turbine and Festo fittings. I also carry a good variety of heavily discounted Festo fittings and hose inventory for PST customers, although I'll supply them anyone that needs hardware...
I'll post a list in a bit.
Kelly
       Post #: 10
RE: PST contact? - 8/2/2006 1:49:24 AM
speedbrake
Status: offline
Kelly,
The list would be helpful...I'll purchase some Festo fittings and some 4mm hose.
Also, I noticed your picture of the Hot Spot (?). I bought one on eBay with retracts and servos. It came primered and ready for paint. It will be my next project....I was planning on using the 600R for power. Any recommendations on how to set one up?
Keith
       Post #: 11
RE: PST contact? - 8/3/2006 4:49:16 PM
Kelly W
Status: offline
I need to update my price list first, but I carry all the common fittings (plus some uncommon ones) and hose in 3, 4 , and 6mm. The discounts I provide are better than the other hobby retailers for most items. If you PM me a list of the exact parts you're looking for, I can get you the details. I'd have posted it by now, but I'm running pretty short on time these days... I've got a turn key jet on the go for a local modeller, and several PST engines in the shop for servicing. You can certainly tell is flying season, although I'm certainly not the one who's getting out flying it seems!
Anyway, on the Hotspot.... I actually fly mine on a 1300R, at full rated thrust. It's a blast!!! A 600R will fly one, but you'll be running it flat out the whole time, and vertical maneuvers / top speed will suffer. It'll need a long paved runway to get off reliably. I have not seen a 600R on a Hotspot myself, but I've seen a video of one flying with a RAM-500. It seems like the power was adequate for flight, but you certainly wouldn't want to fly with any less. The 600R has pound n' a bit more than an older RAM-500, but the performance won't be much different.
Just make sure you build it LIGHT! Don't glass the wings if you still have the option, as opposed to just using monokote... If the fins aren't glassed yet, only cover them with 3/4oz, since they are a common failure mode (flutter). Be careful with the hardware you use, choosing the lightest equipment, and make sure you place everything inside the fuse such that you don't need any ballast lead anywhere. Following those rules should give you a decent jet, all be it not a speed daemon.
Kelly
Kelly,
Keith
       Post #: 12
RE: PST contact? - 8/7/2006 3:33:56 PM
speedbrake
Status: offline
Hi Kelly,
I flew my first turbine this weekend. Wow! What a thrill! The Reaction 54 and PST 600R combo is awesome.
I used tygon tubing for the fuel system. The nipples on the fuel pump require 4mm tubing. So somewhere in the system the two sizes meet. My manual says to stick the smaller tube into the larger tube 1/2 inch for a leak proof joint. Is there a fitting that joins the two different sizes? I noticed BVM tanks come with 6mm tubing, which has a bit smaller diameter (OD) than the tygon. I like the 6mm tubing because it is clear. So....I want a fitting that joins 6mm tubing to 4mm tubing. What is your recommendation for fuel tubing? Do you have a fuel filter designed for 4mm tubing? The only filters I have available are designed for glow fuel tubing.
I noticed the propane tank wouldn't hold more than one start sequence worth of gas. I used a trigger valve and closed the valve when the gas quit moving to the tank. The gas supply can was in a up right position. Any ideas on why it won't hold more?
What is the fuel consumption rate for the 600R? It really drinks the fuel. I have 54 oz. on board and can obviously use more. Would bringing the Max rpm down on the turbine decrease the fuel consumption enough to make a difference?
Keith
       Post #: 13
RE: PST contact? - 8/8/2006 8:26:54 AM
Kelly W
Status: offline
Hi Kelly,
