RE: Thunder tiger ST-1    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  306 307 308 309 310 311 [312] 313 314 315   next >   >>
Login
RE: Thunder tiger ST-1 - 11/24/2011 5:47 AM
kawpow321
Score: 100
Last Login: 11/25/2012
Status: offline
well with the mounts you no how there are two screws holding them onto the tower you just shift the out were the inside one bolts were the outsideone used to cause if not in the stock position the mounts hit right on the seam of the hood making it impossable to put clips in so alls it does is move them out to mount on the flat part of the hood but makes them look a little newer if you ask me
_____________________________
KAWPOW321 Thunder tiger ST1 Lrp z28 Traxxas Revo O.S. 21tm Ofna LX1 TTR Pro 28 BX-R
Hide Signatures
(in reply to KeithjV)
       Post #: 7776
RE: Thunder tiger ST-1 - 11/24/2011 5:50 AM
KeithjV
Score: 125
Last Login: 4/10/2012
Status: offline
Ok gotcha. How did you mount the back?
Hide Signatures
(in reply to kawpow321)
       Post #: 7777
kawpow321
Score: 100
Status: offline
picked that engine and extra rotostart backplate brand new for 115 shipped i was like hl yeah
Hide Signatures
       Post #: 7778
RE: Thunder tiger ST-1 - 11/24/2011 5:54 AM
kawpow321
Score: 100
Status: offline
if you could let me no were your carb settings are for you(i no there are alot of things altitude temp etc... but i just want a basic running setting to go off of cause i seen you got a few of these mills im sure you got em down all by the way i wanted to ask you how good those servos you use are i seen on your vehicles that you use the same ones and i looked them up there fairly inexpensive and thats the next thing im going to buy (i love the mt2 that was my first good rc had the os 18 it ripped )
Hide Signatures
       Post #: 7779
RE: Thunder tiger ST-1 - 11/24/2011 5:58 AM
KeithjV
Score: 125
Status: offline
Im not sure what servos I have listed. Im running JR and Hitec now. I got them on ebay, pretty good deals.
I didnt have to tune the engine much. Half a turn at most and it was running great. Thats why I love the LRP/SH engines. Very easy to tune and crazy amounts of power
Hide Signatures
       Post #: 7780
RE: Thunder tiger ST-1 - 11/24/2011 5:59 AM
kawpow321
Score: 100
Status: offline
the back was just stock it fits pretty much perfect besides beeing a little narow have to kinda pull it apart to sit down on and do that adjustment to the front other than that fits great you think it looks ok? if so pick one up i think it looks alot better than stock or the mb5xt bodies (i love the bulldog bodies) you could probably get the jconcepts illuzion for the mb6xt as well but im not sure havent tried it yet
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 7781
RE: Thunder tiger ST-1 - 11/24/2011 6:01 AM
KeithjV
Score: 125
Status: offline
I had been looking at the bulldogs but i wasnt sure how it was going to work with the rear wing
Hide Signatures
       Post #: 7782
RE: Thunder tiger ST-1 - 11/24/2011 6:02 AM
kawpow321
Score: 100
Status: offline
oh get this for the mudflaps i just took the stock wing of my st1 body cut it exactly in half and trimed it alittle you no to round the edges and it made the best mudflaps better than the ones my brother bought for his losi 8t 1.0
Hide Signatures
       Post #: 7783
RE: Thunder tiger ST-1 - 11/24/2011 6:03 AM
kawpow321
Score: 100
Status: offline
id grab one it fits in the rear perfect just trim out the taillights like you did on the stocker and it will sit flat on your mounts perfect
Hide Signatures
       Post #: 7784
RE: Thunder tiger ST-1 - 11/24/2011 9:56 PM
kawpow321
Score: 100
Status: offline
Finally got to run my St1 with my Lrp z28 today my brother brught me that roto start he n i ran 6 tanks through it to brak it in n when i got to finally tune it up OMG does this thing rip it makes that stocker look like a .18 its awesome!!!! go LRP for making when heck of a mill id recomend it to anyone im going to have to retune my diffs to accomadate for all this power
Hide Signatures
       Post #: 7785
RE: Thunder tiger ST-1 - 11/25/2011 4:11 AM
KeithjV
Score: 125
Status: offline
Told you that you wouldnt be disappointed. Do you have any closer shots of the mud flaps?
Hide Signatures
       Post #: 7786
RE: Thunder tiger ST-1 - 11/25/2011 11:57 PM
kawpow321
Score: 100
Status: offline
ill get them on there tomorow for you bud but ill explain it the best i can for now on your stock st1 you no how the wing bolted to the body i took it off cut it exactly in half then rounded the corners were i cut it then on your a arms there is a spot to mount an additional shock you take the right side of the wing and mock it up to bolt to the left a arm and vice versa you will be placing two screws in each mudflap i beleive youll need to layout to add an extra hole and one of the exissting holes will work perfectly in the pack with your front stabilizer youll have a ball with a hole in the center i used 1 ball pewr side to mount wich will be place inbetween the gap on the a arm but ill post pics for you
Hide Signatures
       Post #: 7787
RE: Thunder tiger ST-1 - 11/26/2011 12:21 AM
kawpow321
Score: 100
Status: offline
here they are dont mind the dirt i was out enjoying that engine
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7788
RE: Thunder tiger ST-1 - 11/26/2011 12:31 AM
calvino
Score: 106
Last Login: 1/28/2012
Status: offline
quote:
ORIGINAL: kawpow321
Back when I had my ST-1 running... it was a fun engine and a nice step up from the stock engine. I do have to say though that it is one fuel PIG if you don't tune it right. My favorite though is the Mach 427 teal head engine with the Losi Sport pipe. That was insane helped to have fuel economy also
Right now my poor car sits waiting its final fate. Ive debated getting it running or selling it off for parts... to bad a brushless conversion is still a bit of $$ even if I did make a motor mount for it
Axial AX10, "Irene" with custom chassis, Thunder Tiger ST-1 [not working]
Hide Signatures
       Post #: 7789
RE: Thunder tiger ST-1 - 11/26/2011 12:41 AM
kawpow321
Score: 100
Status: offline
so the losi 427 was a ripper huh
Hide Signatures
(in reply to calvino)
       Post #: 7790
RE: Thunder tiger ST-1 - 11/26/2011 12:58 AM
calvino
Score: 106
Status: offline
quote:
ORIGINAL: kawpow321
I got it with a ton of miles on it, and some good compression. Ran it till I said "worn enough" and got a new piston and sleeve. Sadly though the wrist pin retainer broke after 1 gallon and RIP lil engine ... imagine my horror changing the glow plug after break-in and seeing a nicely marred piston and sleeve
Hide Signatures
       Post #: 7791
RE: Thunder tiger ST-1 - 11/26/2011 1:15 AM
kawpow321
Score: 100
Status: offline
couldnt imagine you got my sympathy bud
Hide Signatures
       Post #: 7792
RE: Thunder tiger ST-1 - 11/29/2011 9:35 AM
syko69
Score: 100
Last Login: 12/5/2011
Status: offline
Hide Signatures
       Post #: 7793
RE: Thunder tiger ST-1 - 11/29/2011 9:49 AM
syko69
Score: 100
Status: offline
Just thought i would put a pic up of my st 1 to show all cheers
Hide Signatures
(in reply to syko69)
       Post #: 7794
RE: Thunder tiger ST-1 - 12/2/2011 12:41 AM
kawpow321
Score: 100
Status: offline
wish i took pics when my bulldog was all PPEERRTTYY!!! but thats one sick truck by the way love the paint
Hide Signatures
       Post #: 7795
RE: Thunder tiger ST-1 - 12/2/2011 12:44 AM
kawpow321
Score: 100
Status: offline
syk069 how did you do your front body posts did you move them out like i had to?
Hide Signatures
       Post #: 7796
RE: Thunder tiger ST-1 - 12/2/2011 12:46 AM
kawpow321
Score: 100
Status: offline
kinda similar as my pics on page 311
Hide Signatures
       Post #: 7797
RE: Thunder tiger ST-1 - 12/2/2011 5:40 AM
syko69
Score: 100
Status: offline
The posts havent been moved just marked the body and drilled, Love this thing around the track owes me alot of money and time but well worth it, Best truggy i have eva had very durable, My other body just arrived the nxt 1 should look better
Hide Signatures
       Post #: 7798
RE: Thunder tiger ST-1 - 12/2/2011 9:55 PM
kawpow321
Score: 100
Status: offline
what did you order another bulldog? im in the market for another myself one for the shelf that is then ill continue to put miles on this one so you didnt do anything with the front mounts at all? i was concerened with it working because it looked like it was going to fall right on a body line and not let it set flush maybee ill put them back when i do the next one so i can mount the post with both screws.. how did your sides fit do you have to pull the body out to go over the sides of the chassis? and last of all is that body for a MBX6T and i agree this is by far the best RC ive ever drivin and ive owned quit a few and with the lrp its so fun to drive my fuel jugs just keep going empty ive burnt a gallon through the LRP in 1 week that might not be alot to some but thats alot to me this thing just adores odonnell speed blend 30% loves it What do you guys run in your LRP
Hide Signatures
       Post #: 7799
RE: Thunder tiger ST-1 - 12/3/2011 4:23 AM
syko69
Score: 100
Status: offline
Posts are in there original spots never moved them, Never had problems with the sides this body fits perfectly with no mods except the cutting out and a few drilling holes, Must say they are a weapon with an lrp, We use AT RACING FUEL heard of it before im running 25% drinks like a blown v8 but runs cooler and better
Hide Signatures
       Post #: 7800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
