msg73
Ok, I think my eyes are about to pop out of my head with all this reading Anyway, this is what I'm planning to order from amain tomorrow. I'm not looking to race, just bash in the backyard/park. Will mostly be running on wood chips and grass. I used to have several electric 1/10 cars and a 1/8 nitro buggy about 15 years ago, but lots have changed since then. I currenly fly electric heli's. Can you guys tell me what you think and let me know if I've missed anything or should change. Thanks, -Mike TTR ST-1 RTR OFNA 500cc fuel bottle Team Associated D-size glow igniter (cheap and I like to just use reg batteries instead of remembering to charge it up) McCoy #59 Glow plug as a spare HPI 4x80mm turnbuckle and 3x25mm countersunk screws (for steering mod) GH racing fuel filter Byrons 20% race 2000 gen2 fuel (2 quarts, is this enough?)...amain only ships quarts or 4 gals Hobbico after run oil Fluidz air filter oil (can I just use after run oil or diff oil?) Vairous diff oils... (Team Associated oils are cheap but nothing greater than 10k) Any recommendations on the diff oils in f/c/r for bashing on wood chips? thinking one of these combos: 5/10/1, 7/10/3, 7/20/3 How are the stock electronics/radio? I have a 7ch Futaba radio I'm using for my heli's...should I switch? I'll run the stock tires and rims unless you guys really think they are worth the upgrade. Do I really need to get a wing...can't find the wing extention part, but I could mount it using the standard TT wing mount assembly. Did I miss anything? Thanks again guys for your help...this tread has been very helpful.
< Message edited by msg73 -- 5/4/2008 5:47:58 PM >
