RE: Thunder tiger ST-1
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  203 204 [205] 206 207 208 209 210 211 212   next >   >>
Login
RE: ... - 5/15/2008 6:58:08 AM
cold_reboot
Status: offline
I got a back order notice on the extended wing mount for the TTR from AMain this evening. Ordered it even tho I'm selling my TTR, brother in law will probably be pretty appreciative. Just a heads up
_____________________________
Caster Racing K8T, TTR ST-1, Spektrum DSM
(in reply to calvino)
       Post #: 5101
RE: ... - 5/15/2008 7:23:55 AM
kweezinarts
Status: offline
and what does this notice say? they shipping you the ext. wing mount?
NRusty 2.5 - TTR ST-1 w/ JPX.28 - Walkera Dragonfly #4
(in reply to cold_reboot)
       Post #: 5102
RE: ... - 5/15/2008 9:45:10 AM
msg73
Status: offline
Fortunately, I found the nut before I ran it. I could only imagine what damage that could have done.
On a separate topic, I decided try a run with the shell on and it cut out suddenly after 3/4 of a tank and I couldn't get it to start. I think I had what's called Vapor Lock. It ran fine for 7-8 minutes and then it went dead all of a sudden. I'm assuming the shell caused it to get too hot, causing the vapor lock. I'll try it again without the shell tomorrow. I'm definitely going to cut out some vents for better cooling.
(in reply to kweezinarts)
       Post #: 5103
RE: ... - 5/15/2008 12:09:15 PM
ItchyBum
Status: offline
Iv got racing this sunday and the track is in pretty bad shape so im going to try 5-5-3. I hope it goes alright cause my other 2 diffs are 30k and full lock and im too lazy to change 1 of them for just in case lol I also have 2 spare front diffs with 7k and 10k just in case also and a spare 1k for the rear. I think i should be covered if only i can get off my lazy butt and make a spare centre lol
       Post #: 5104
RE: ... - 5/15/2008 12:53:52 PM
ItchyBum
Status: offline
Just found something very useful. Check it out http://www.gesilicones.com/gesilwizards/blending/fluid2.html?SMSESSION=NO For when you dont have the exact weight diff oil, you can mix 2 together (same brand) at a certain ratio to get the weight you looking for
(in reply to ItchyBum)
       Post #: 5105
RE: ... - 5/15/2008 1:51:50 PM
cold_reboot
Status: offline
Yes, they are shipping it out to me.
       Post #: 5106
RE: ... - 5/15/2008 8:33:14 PM
cujoman
Status: offline
Ok, finally figured out what the prob with my ST-1 was. Remember my Throttle was getting stuck after 5 minutes of running and we thought it was either the clutch shoes or switch. Well it wasn't. I turned out to be the throttle servo. Go figure! Well I fixed it now and it's back and running excellent. Now I have one more issue. I don't like how the front tires get more traction or start spinning before the rears do. What can I do to change this? Just so that the rears get the initial grip instead of the fronts? Should I change the oil weiht to thicker in the front and thinner in the rear? it's stock right now. Let me know, thanks!
       Post #: 5107
RE: ... - 5/15/2008 9:25:35 PM
chedster
Status: offline
Ya if they are still stock they just have grease in them. Swap that for some diff oil. 5-10-3 is a good starting point.
(in reply to cujoman)
       Post #: 5108
RE: ... - 5/15/2008 9:37:27 PM
ericem
Status: offline
Just change the center diff oil. Put like 20k (20,000) weight. IMO 10k is nothing.
(in reply to chedster)
       Post #: 5109
RE: ... - 5/15/2008 10:18:50 PM
cujoman
Status: offline
ok cool, i'll try that. Thanks!
(in reply to ericem)
       Post #: 5110
RE: ... - 5/16/2008 12:25:22 AM
ItchyBum
Status: offline
The front wheels will balloon lots if you are driving on concrete or bitumen or anything with high traction. Once you take it onto some dirt they all spin pretty much the same but you definately need to change the diffs from grease to silicone oil so you have some kind of control over them. Iv got a 30k centre diff and it doesnt balloon at all so 20k should be a good medium
       Post #: 5111
RE: ... - 5/16/2008 12:58:53 AM
madmax22
Status: online
ok wel i got the roto start today and put it in all excited and the OWB (that was CRAP) just stopped... took it out and put WD-40 on it and got 1 little blip out of it but not evought to start it... i'm guessing i will order 2 of those... I ordered the roto start from amain on sunday and got it today (thursday) with the worst shipping givin... i might just order some from the LHS so i dont have to pay $8 shiping for a $9 part.
They call me "butthead".......
