RE: Thunder tiger ST-1
Tower Hobbies
Logged in as Guest
Users viewing this topic: ericem, znutt69
  Printable Version
Tamiya Land Cruiser CR-01 Crawler Assembled w/ ESC - Kit
Seller:  sheograth
Details:   $300.00   |  9/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  208 209 [210] 211 212 213 214 215 216 217   next >   >>
Login
RE: ... - 5/27/2008 4:21:14 AM
madmax22
Status: offline
ok i took the center diff out cleaned it put it back in but now when it rolls the spur ind CB move, i started it and didnt move.... all the diff gears looks like they have 0 wear...... whats going on here??? I checked all my cups and shafts and what not...
_____________________________
They call me "butthead".......
(in reply to redfox03)
       Post #: 5226
RE: ... - 5/27/2008 4:23:03 AM
ericem
Status: online
Hold the center diff gear (spur) and try and roll it. Can you?
(in reply to madmax22)
       Post #: 5227
RE: ... - 5/27/2008 4:25:46 AM
madmax22
Status: offline
yup
(in reply to ericem)
       Post #: 5228
RE: ... - 5/27/2008 4:27:17 AM
ericem
Status: online
Has to be a drivetrain issue. Look veryyyyyyyyyyyyy closely at all the axles make sure they all have pins. If the set screw came loose and one of the pins fell out it will cause that problem and your 100% sure you tightened the two drivecup set screws. Another thing, the wheels, VERYY unlikely but you could have stripped a wheel hex.
       Post #: 5229
RE: ... - 5/27/2008 4:30:40 AM
madmax22
Status: offline
k thank ill look in the morning... naa the hexes are fine i took them off when I took the diff out
       Post #: 5230
RE: ... - 5/27/2008 4:34:02 AM
kweezinarts
Status: offline
quote:
ORIGINAL: derek_18mt
someon tell please which truck
my 2 co workers in buffalo got crt's but i went with the st-1, i got a jammin .28 and a JR xs3 and im still in less $ than they are ...
youz in Buffalo gotta bash some time...
NRusty 2.5 - TTR ST-1 w/ JPX.28 - Walkera Dragonfly #4
(in reply to st1_racer)
       Post #: 5231
RE: ... - 5/27/2008 9:33:00 AM
ItchyBum
Status: offline
Hey Madmaxx, have you checked the clutch? If it wont drive its possiblr something is wrong in there, maybe something stopping the shoes from opening????
       Post #: 5232
RE: ... - 5/27/2008 1:39:13 PM
madmax22
Status: offline
no its def. not the clutch, ericem i just checked all the pins were there and i thightened everything down the set screws were, set i couldent tighten them anymore. if i roll it the CB and the spur movesbut i can hold the spur w/ my finger and roll the truck and only feel a tiny little bit of resistance..... this sucks... I dont know
(in reply to ItchyBum)
       Post #: 5233
RE: ... - 5/27/2008 3:26:18 PM
chedster
Status: offline
Sounds like you need to pull the diffs. Your problem is either in the diffs or an clutch issue which sounds like it has been ruled out. Just pull each diff and check it out. You might want to do a re-build if the gears look worn to.
       Post #: 5234
RE: ... - 5/27/2008 4:40:51 PM
madmax22
Status: offline
ok thanks. ill go rip them out..... once i get home
(in reply to chedster)
       Post #: 5235
RE: ... - 5/28/2008 2:30:47 AM
Frozen72
Status: offline
I might get one of these for racing this summer. I love the Price at under $300 but it's going to be my first Nitro. I know about most of the stuff that is needed for a Nitro and do you think that this would be a good beginner Nitro but not Driver. Also how reliable are they since my LHS doesn't carry parts and I'll have to get EVERYTHING on-line?
"My friends don''t know I''m black"
Rap - Lies = Hip-Hop
       Post #: 5236
RE: ... - 5/28/2008 3:06:23 AM
madmax22
Status: offline
very reliable, good for begginers and begginer driver because it takes a beating.... I'm having diff. troubles b/c beat the living 'shiznit' outta mine
