RE: Thunder tiger ST-1
Tower Hobbies
Logged in as Guest
Users viewing this topic: KershawJoe, brzpk, ItchyBum
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  227 228 [229] 230 231 232 233 234 235 236   next >   >>
Login
RE: ... - 7/12/2008 1:21:16 PM
dirthead
Status: offline
Break-in is pretty straight forward.
(ALWAYS MAKE SURE THERE IS AMPLE SMOKE COMING FROM THE EXHAUST STINGER)! THIS IS CRITICAL, ESPECIALLY DURING BREAK-IN!
1. Make sure engine is set to factory settings, should say in your manual.
2. First tank, Start your engine and let it idle for a full tank, if it stalls just start it again. If you have a hard time turning the engine over, heat it with a hair dryer to expand the cylinder so the piston is not so tight.
3. Second tank Let engine cool down a bit, and start engine again, but this time you can drive it around giving it 1\4 throttle(no more though).
4. Third tank, let engine cool down a bit, and restart, now you can run giving up to 1\2 throttle bursts.
5. fourth tank, repeat step 4
6. Fifth tank, repeat step 4, but now give it a little more throttle, even full if you want, but only in short bursts of a second or so.
7. Sixth tank, start leaning out your engine but only a little at a time, (ALWAYS MAKE SURE THERE IS AMPLE SMOKE COMING FROM THE EXHAUST STINGER)! THIS IS CRITICAL, ESPECIALLY DURING BREAK-IN!
8.Every tank after now you can keep tuning till you find the sweet spot on your engine, once you do, richen it about 1\8-1\4 turn, and you should be ready to rock.
Important!, the easier you are on your engine (especially during break-in), the longer and better it will run!
Hope this helps, and have a great time with your new friend!
If you have any questions, these are a great bunch of guys on this thread to help you out!
_____________________________
ST-1 PRO, ST-1 Spektrum DX-2 Saxton mod, offset hubs, 1\2 offset proline mtr crime fighters
EB4-S3 TTRpro21 all upgra
(in reply to dirthead)
       Post #: 5701
RE: ... - 7/12/2008 2:55:31 PM
nastysim
Status: offline
hi looking nice there i dont believe you gave him the cobra lol
have you ran the beast since you installed the new chassie and ifso have you noticed any difference in the handling mate
ttr st-1 pro ttr eb4 s3 with all hop ups
schumacher rascal and ftx blaze
(in reply to ItchyBum)
       Post #: 5702
RE: ... - 7/12/2008 9:24:58 PM
ericem
Status: offline
hey guys just wondering if someone can measure the length of the shocks in the rear of your st-1, with them fully depressed of course. I was going to get st-1 shocks for my mgt can't remember which ones I measured were the correct length. Be well appreciated, don't really feel like stopping by my friends house just to measure his shocks.
(in reply to nastysim)
       Post #: 5703
RE: ... - 7/12/2008 10:00:41 PM
dirthead
Status: offline
Nice tigers itchybum, How are your diffs set? You seem to have really uniform wear on the tires.
Well tomorrow's the big race, I'll let you know how I do.
Here are my weapons of choice!
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 5704
RE: ... - 7/13/2008 5:38:20 AM
misasi
Status: offline
Hey guys i just ordered my ST1 RTR and i was wondering what kind of run times i can expect out of the stock motor?
RC10GT, MIP, RPM,O.S., FT, GRP , Futaba Fasst
TTR ST1, Futaba Fasst
       Post #: 5705
RE: ... - 7/13/2008 5:42:19 AM
calvino
Status: offline
mm depends on tune, if you are running VERY rich, about 4 minutes, tuned "good" mmm, like 10+ minutes, also varries on the amount of throttle your using to
RC18T 6800 Sidewinder Micro 2s lipo, 1980 Goldpan (needs electronics), ST-1, Slow Stick $15 outrunner combo 3s lipo †
(in reply to misasi)
       Post #: 5706
RE: ... - 7/13/2008 6:56:11 AM
calvino
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFUX5&P=M can THAT work with my ST-1 or is it a not so good idea (or it won't work pierod), anyone also know of other starter backplates (aka, tigerdrives) that will work with the ST-1, since i would love to run it before my fuel goes bad in my bottle
(in reply to calvino)
       Post #: 5707
RE: ... - 7/13/2008 7:11:52 PM
ericem
Status: offline
quote:
ORIGINAL: calvino
like i said already NO it will not work, unless you shim it up alot and get the backplate that matches. You also need the one way bearing from the monster gt since there is one inside the engine as well as in the roto/pull starter itself. Man I have gone through this with many vehicles. I will tell you what starterbox is the best option and cheapest in a short run. When you have finished buying one way bearings, and pullstarts and replacing worn rotostarter's you realized you could have just gotten 4 of these starter box's.
http://www.amainhobbies.com/product_info.php/cPath/1_23_52/products_id/11556
With this starterbox you simply put on the front and rear bracket but you can't use the pegs. I just look at the wheel and line it up every time, it starts up instantly anyways. The box has plenty of torque for any motor. Very good product and you can not beat the price. Seemed like the easiest battery combo was two 7.2v stick packs just a FYI.
       Post #: 5708
RE: ... - 7/13/2008 9:21:42 PM
st1_racer
Status: offline
guys do i take the glow plug off too see if the piston is at the bottom. Do i turn the flywheel to see, before i break it in?
boogidy boogidy boogidy lets go racing boys
Thunder Tiger St1 is going to be sold/ Gs Racing Storm Cl-1. 1/8 Truggy kit
(in reply to ericem)
       Post #: 5709
RE: ... - 7/13/2008 10:17:55 PM
calvino
Status: offline
ok, so explain this, i can FIND the starter spring on ACE hobby's site, BUT there is no "seach feature" and you can't click on the "starter" stuff on the side of the page, how frustrating, anyone know if you can purchase directly from them or what, since im gettin a little frustrated here, or i can just wait for the roto to come in stock, maybe ill get a tigerdrive
       Post #: 5710
RE: ... - 7/13/2008 10:45:08 PM
dac8
Status: offline
