RE: Thunder tiger ST-1
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Thunder tiger ST-1 - 5/2/2007 9:52:51 PM
slinger22
Status: offline
offset helps balance the truck in the rough stuff, it will fly more balanced and it will help it corner better, you will get full steering throw without the rub. i have always run mine with the ofna offsets and never had an issue
(in reply to Joe Ortiz)
       Post #: 76
RE: Thunder tiger ST-1 - 5/3/2007 9:24:58 AM
PhilDz
Status: offline
Thanks, are the ofna ones, the only ones with that offset?
(in reply to slinger22)
       Post #: 77
RE: Thunder tiger ST-1 - 5/3/2007 4:25:30 PM
slinger22
Status: offline
i believe proline has some and ttr i think has some too just not sure what part numbers are
(in reply to PhilDz)
       Post #: 78
RE: Thunder tiger ST-1 - 5/17/2007 10:45:32 AM
PhilDz
Status: offline
So...., I broke the pull-start on the stock motor, and got the roto-start conversion. In my frustrations, I removed the pull-start, gave it a once over, decided that there was no way in hell I could fix it, and then trashed it. Uh-oh, little did I know that there was a part there that I needed. It's the plastic washer thing, that attaches to the shaft, I needed that so I could slide the gear of the roto-start on there. Does anyone know if I can buy that little part seperately, and if so what is the part number. Please help, I haven't even got to fully break in the truck yet .
       Post #: 79
RE: Thunder tiger ST-1 - 5/17/2007 4:28:03 PM
jaywax
Status: offline
quote:
ORIGINAL: PhilDz
It is called a one way bearing. Go to www.infinitehobbies.com to buy one. The part # TTRAN0924. I would order at least two. They tend to strip out sometimes. Make sure you heat your engine up with a heat gun or good hair dryer before using roto start. It keeps the one bearing from stripping out. Hope this helps.
< Message edited by jaywax -- 5/17/2007 4:30:12 PM >
_____________________________
Mugen MBX5T Prospec w/STS S21T***KO Propo EX-10 Helio w/Spektrum Pro Module
       Post #: 80
RE: Thunder tiger ST-1 - 5/17/2007 7:33:55 PM
PhilDz
Status: offline
Thanks, that definitely helps. I'm eventually going to the starter box.
(in reply to jaywax)
       Post #: 81
RE: Thunder tiger ST-1 - 5/22/2007 5:46:59 AM
morkendi
Status: offline
might be ordering the pro this weekend, does this come on the pro? Is there anything else i should place along with my order to save shipping?
http://www.amainhobbies.com/product_info.php/cPath/1_24_178/products_id/6413
       Post #: 82
RE: Thunder tiger ST-1 - 5/22/2007 7:23:39 PM
PhilDz
Status: offline
I am currently breaking in my stock motor. It's been a while since I have done this. I have a quick question though, is it normal for the motor to cut out when I apply the brakes? Does it do this because the setting is rich? I don't remember this happening when I was breaking in my TMaxx.
(in reply to morkendi)
       Post #: 83
RE: Thunder tiger ST-1 - 5/22/2007 7:37:28 PM
warriorking
Status: offline
You need to adjust your linkage. the reason its cuting off is because the carb opening is closing too far.
You might also need to adjust the carb opening.
carb opening should be about 1.5-2mm
CAP 232 ACRO .60, TRAINER .40,
I smile because I don't know what the *&%#@ is going on!!
       Post #: 84
RE: Thunder tiger ST-1 - 5/22/2007 11:28:06 PM
Matt (12 year old rc fanatic)
Status: offline
Sorry for the stupid ? but what does TTR mean
RC10T4 W/MM 7700, XTM XT2,
Thunder Tiger ST-1
(in reply to warriorking)
       Post #: 85
RE: Thunder tiger ST-1 - 5/23/2007 1:06:59 AM
warriorking
Status: offline
quote:
ORIGINAL: Matt (12 year old rc fanatic)
Thunder Tiger Racing
http://www.amainhobbies.com/product_info.php/manufacturers_id/41/products_id/12595
< Message edited by warriorking -- 5/23/2007 1:09:36 AM >
       Post #: 86
RE: Thunder tiger ST-1 - 5/23/2007 8:22:17 AM
PhilDz
Status: offline
Which one would be better performance wise?
http://www.amainhobbies.com/product_info.php/cPath/1_23_34/products_id/3171
http://www.amainhobbies.com/product_info.php/cPath/1_23_34/products_id/5314
