RE: Thunder tiger ST-1
Tower Hobbies
Logged in as Guest
Users viewing this topic: KershawJoe, brzpk, ItchyBum
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Thunder tiger ST-1
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Thunder tiger ST-1 - 7/6/2007 1:04:34 AM
jaywax
Status: offline
quote:
ORIGINAL: bascom
hey guys this may sound like a stupid question
BUT..
just brought an st1 from ebay that has hardley been used but the problem is that
I CANT GET THE STANDARD WHEELS ON!!!!!!!
its like the ttr 4 way wrench doen't fit deep enough into the rim to tighten the hex nut and is pi$$ing me off as i want to take this truck out any1 else have problems and HOW did you solve it..
Those are the offset wheels, not standard. If you have regular tools, find a socket that will fit and use it. If that does not work, place the nut on with your finger and turn it a little. After that, you can tighten with some needle nose pliers. I used the plier method until I bought a rc socket wrench. Here is a link to a deep socket wrench. They are rather pricey.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMJV4&P=7
_____________________________
Mugen MBX5T Prospec w/STS S21T***KO Propo EX-10 Helio w/Spektrum Pro Module
(in reply to bascom)
       Post #: 126
RE: Thunder tiger ST-1 - 7/6/2007 3:40:09 PM
ItchyBum
Status: online
This is the tool that i use it came in my dads xtm mammoth kit
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to jaywax)
       Post #: 127
RE: Thunder tiger ST-1 - 7/7/2007 1:46:24 PM
bascom
Status: offline
hey itchy did yours come with the offset wheels standard..
(in reply to ItchyBum)
       Post #: 128
RE: Thunder tiger ST-1 - 7/7/2007 3:41:24 PM
ItchyBum
Status: online
nah mine is only the rtr version, it came with the spoked chromies. I had to buy the offset wheels separately
       Post #: 129
RE: Thunder tiger ST-1 - 7/7/2007 4:52:13 PM
bascom
Status: offline
i have the crome rims as well but the standard 17mm wrench didnt fit
so they must be the offset ones even though they look like the standard ones
would show pictures but dont know how to attach pictures on this forum have tried uploading but no luck
Click for fullsize
Click for fullsize
       Post #: 130
RE: Thunder tiger ST-1 - 7/7/2007 4:53:34 PM
bascom
Status: offline
guess i figured it out and didnt even know it
       Post #: 131
RE: Thunder tiger ST-1 - 7/7/2007 5:22:30 PM
jaywax
Status: offline
If those are the rims you are using, you do not need a deep wheel dish wrench. A regular 4 way wrench should work. It is the big wrench that also removes glow plugs.
       Post #: 132
RE: Thunder tiger ST-1 - 7/7/2007 6:55:42 PM
bascom
Status: offline
believe me the standard wrench AINT fitting down ive tried n tried, even got a mate of my who races regulary and used to work for hpi to have a look and he couldnt make any sense of it him self
look carfully at them, then compare to the standard ones on link
link
see how much shallower they look compared to mine
       Post #: 133
RE: Thunder tiger ST-1 - 7/7/2007 8:21:44 PM
jaywax
Status: offline
quote:
ORIGINAL: bascom
link
Okay, I see now. Those are different than the stock TTR. Did you get my response about the battery pack and switch?
       Post #: 134
RE: Thunder tiger ST-1 - 7/7/2007 9:20:26 PM
bascom
Status: offline
yeah got your pm thanks
weird about those rims aint it, so then would i be right in saying that these are the offset 1's??
       Post #: 135
RE: Thunder tiger ST-1 - 7/8/2007 5:13:29 AM
jaywax
Status: offline
quote:
ORIGINAL: bascom
Offset has to do with the inside of the rim. It will extend out half a inch, so that it has a wider stance. The place where you attach rim to the axle. Zero offset is the standard. Check the inside of those rims.
< Message edited by jaywax -- 7/8/2007 5:16:13 AM >
