RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/10/2007 11:14:12 PM
gboulton
Status: offline
Wheee!
Lower wing panels are joined, epoxy curing as I type this. With some luck, should be able to make a decent start on sheeting the top wing panels this week! Picture will be forthcoming as soon as the wing gets out of the clamps/shucks.
_____________________________
The free man will ask neither what his country can do for him nor what he can do for his country. - Milton Friedman
(in reply to gboulton)
       Post #: 201
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/11/2007 3:49:21 PM
gboulton
Status: offline
It's a WING!
Click to see fullsize image.
Click for fullsize
       Post #: 202
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/13/2007 2:55:01 AM
gboulton
Status: offline
Considerable progress on the upper wing the last couple days. Center wing section is done, including hardpoints for strut mounts, the left wing section lacks only bottom cap strips, servo bay, interplane strut mount, and cutting/finishing the aileron. No pictures since, well, they'd be pretty boring.
I am, however, planning on carefully and completely documenting the ENTIRE process of the top right wing...since it will be the last wing panel, I thought it'd be handy if, SOMEWHERE in this build thread, the complete method from start to finish was included. Nothing at all says that this is the only, or even the best, method, but it's working quite well for me, and producing light, strong wings. That will be coming probably next week, as I'll be out of town this weekend.
       Post #: 203
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/13/2007 7:11:09 PM
gboulton
Status: offline
Heh...got a little anxious.
Thought I'd go ahead and start the top right wing panel today, and share info/details as I went along. not much chance of getting it "done" before going out of town but should be able to at least get a bit into it today. As such, expect the next several posts to be rather long and detailed, and contain lots of pictures.
The Bulldog's wings, as mentioned before, are sheeted foam core wings. They are not, however, completely sheeted, but rather sheeted with a LE and TE sheet, and then "cap strips" between the two. This is being done primarily to preserve the scale look of separate wing bays, and it has the added benefit of reducing weight.
What I'll detail here is a "step by step" process for doing one of the wing panels. Each wing panel has been done in a similar fashion. I won't include any measurements since, obviously, mine are specific to this particular set of wings. The method, however, should work well for ANY set of foam wings.
Before I get too heavily into things, allow me to say first of all that I was once told "once you know how to do foam wings, you'll never build another one". I found this rather difficult to believe at the time, and found it downright WRONG after doing my first foam wing on the small bulldog. After complaining rather loudly to Mike Dunphy (he who offered the original prediction), I learned that what he had in fact said was "ONCE YOU KNOW HOW"...and I most certainly did not.
After a bit of education, I gave things another shot on another wing for the small bulldog...and found things going much more smoothly.
Now...I've also heard a GREAT NUMBER of people say that foam wings are heavier than built up wings. This is simply NOT TRUE...or, at least, they certainly don't HAVE to be. They sure as heck CAN be, though. My own opinion is that this belief is the result of mass produced foam wings available on many larger ARFs. Since it is impossible to expect the "assembly line" to take the same care with our wings that we do it seems inevitable that many of the painstaking, but worthwhile, "tricks" will be left out of the mass production process.
Somewhere in the middle of building wings for the small Bulldog I was lucky enough to receive another rather lengthy education from Mike's son, Scott. Scott Dunphy is, arguably, one of the more knowledgeable builders ANYWHERE when it comes to wings. Some of you long time pattern guys probably recognize the name. To be certain, a fair number of world class pilots do. By no means did he teach me everything he knows...but I HAVE picked his brain enough to have learned a few of the tricks for keeping foam wings light, but strong. I'll share these as I go along.
So...let's begin:
First picture is of a brand new wing core as it comes out of a wing cutting machine. For those who are completely unfamiliar with foam wing cores, they are made simply by passing a hot wire through a rectangular block of foam. the wire is guided either by hand or by a machine (the latter being preferable imo) to cut an airfoil out of the center of the block. The top and bottom pieces (called shucks) are left together, with the wing sandwiched between them, to protect the wing during transport. They also provide nice bases when working on the wing, and will aid with alignment, as we shall see later.
Note that i have marked the wing, indicating that thi is the top of the right wing, and showing leading and trailing edge. It will become important down the road to know which way the wing should be oriented, and also to keep it in its original shucks. It might not seem critical with a symmetrical airfoil, but it is. Again, we'll see why later. For this reason, I also mark the ends while the wings are still in the shucks, indicating which way is up, and which end (root or tip) it is. Note that drawing a complete line, top to bottom, will also help with alignment down the road.
Once the wing was out of its shucks, the first thing I did was weigh it. Clearly, foam wing cores don't weigh much at all...what makes them "heavy" is all the stuff we'll be adding, especially glue. So, i wanted to see the weight of the core itself, so we could compare later and see just how much weight we add during this process.
The next thing I do is to start preparing the core to receive its spar(s). In this case, I'm using 1/4 x 3/8 Spruce for spars, and running one top and one bottom spars. Since the top wing of the Bulldog is not straight, I've had to engineer a joint where the wing sweeps back. This has been done by placing two horizontal spars in the center section (pictured at top) which extend a ways into the swept wing section. About 6" inboard of the section's root, they will join to a spar that runs parallel to the LE of the wing section. So, the first task is to draw out the lines to cut the groove for the center spar sections. We're doing that here:
The longer spar section of the wing panel simply runs parallel to the LE of the wing from the joint to almost the wing tip. I just use a straight edge to mark that line.
Once that's done, it's time to cut the slots. There are dozens of ways to do this. Many folks use a soldering iron method, or even a plain ole X-Acto knife. I've found, however, that I prefer using a Dremel. Many dremels come with, or you can separately purchase for little money, a router attachment. Mine has a "fence" that can be installed instead of the point used to route circular paths. With this fence, I can simply select a bit of the correct width (1/4" in this case), set it to the right depth (3/8" ) and run the fence right down the leading edge of the wing. (the diagonal slot coming in from the center section was a bit tricker...but simply clamping a piece of wood in place, and running the dremel along its edge did the trick)
Once this is done, it's then simply a matter of cutting the spar to the length you want, and epoxying it in place. One tip...I draw a few X's on the top surface of the spar so I know not to epoxy that side. No sense in adding the extra weight there.
A few words now on epoxy:
I use 30 - 60 minute epoxy when working with foam wings (depending on how big it is, and how much time I think I'll need to complete any given step. 30 is more than strong enough for any task we have, but 60 sometimes gives me a few extra minutes if I'm coating a large amount of sheeting or something).
Epoxy is, probably, the single biggest factor in adding weight to a foam wing. it's certainly one of the most controllable, and most frequently "abused". Certainly you can use lighter foam (many wings are cut out of 1 or even 2 oz foam, when 1/2 oz will do just fine) but, unless you're cutting them yourself, you may not have a choice. You can also be careful when selecting balsa sheeting, and look for competition grade balsa, though it is indeed pricier, and at times hard to find.
Epoxy, though, can make a HUGE difference, and control of the amount used is entirely within your hands. It's deceptive how quickly an otherwise light wing can become heavy just by being careless with it. Think about it this way:
Let's say on the top side of this wing panel, I use a mere 1 oz more epoxy than I needed. Very easy to do, you must admit. An ounce of epoxy is no more than a couple good sized drops.
Now...presume I do the same thing on each side of each wing panel. 4 wing panels, 2 sides each....8 ounces.
Yep...we just added A HALF POUND to the wings alone.
I'll share some tips in future posts, as I get to the sheeting stage (where the tricks are more useful, and the difference can be more easily demonstrated)...but suffice to say, be OBSESSIVE about removing excess epoxy.
More posts coming later today, and next week, as the process continues.
       Post #: 204
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/19/2007 8:43:05 PM
gjmjoe017
Status: offline
Looking good Gordon!We are slowly getting my paint work done on mine.
       Post #: 205
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/19/2007 10:17:03 PM
willey
Status: offline
Hi Gordon, wow! what a project you have going on! very nice!!
Hope you don't mind me sharing with you and other Bulldog fans my earlier project.
I built this Midwest Super Stinker back in 2002 and is still flying. I modified the shape on all the tail feathers, fin, rudder, stab & elevators, I also squared and shortened the wings, added full functional flying wires on wings and tail. Stan's Fiberglass cowl and wheel pants, on the cowl I molded the front to match the tru-turn spinner. Paint on fib parts is Dupont chroma-base w/clearcoat. For power it has a Moki 1.8 w/ 18-8 carbon prop, and covered with 21st Century fabric.
Have fun with your Bulldog project, It's looking Great!!
willey
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
++HUN HUNTER++
(in reply to gjmjoe017)
       Post #: 206
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/20/2007 12:52:09 AM
gjmjoe017
Status: offline
Great Job on your Bulldog.I am doing what you've done but with the Great Planes Pitts.How did you get your rivets and panels on the front done?
(in reply to willey)
       Post #: 207
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/20/2007 4:13:54 AM
willey
Status: offline
Thank you, I used the Top Flight fine line pens, warbird templete for rivets, and a plastic flexible & rigid ruler, around the corners and places you can't use the rulers I used the 3M blue fine line tape as a guide - works good for this.
"Take note all" after year or so the ink pen applied to the 21st century fabric starts to BLEED into the fabric over time, kinda fuzzy looking, it's been a little over five years now and it still holding up pretty well.
On the cowl - I applied the lines on the base coat color then applied the clear over top, to this day it looks like I painted it yesterday! Holding up very well.
willey
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
++HUN HUNTER++
       Post #: 208
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/21/2007 3:35:52 PM
gboulton
Status: offline
Willey,
That's some nice work, man! I'll bet it presents BEAUTIFULLY in the air!
Sorry i didn't get much posted this week, guys...been facing a bit of a bug all week. Hope to get some more sheeting done today, and have a few pics up by the end of the day.
       Post #: 209
RE: Jim LeRoy Pitts Bulldog - Scratch Build Thread - 7/21/2007 5:23:51 PM
gboulton
Status: offline
Decided to go ahead and do some sheeting on the wing panel this morning before running off to do errands, so i could go ahead and put up this part of the "step by steps".
So...when last we left our intrepid adventurer, he had laid in the spar for a top wing panel, and was preparing to begin the sheeting process. Our story picks up with a rather strange collection of "necessary tools" laid out on his work table. We have straight edges, rulers, balsa, a wing, a pencil, necessary equipment for feeding the nicoteine addiction, and, of course, hair spray.
Err...hair spray?
Yes...hair spray. Just go with it.
First order of business is, of course, to lay out the sheeting and cut it to correct lengths/shapes/etc. One quick tip here...I tend to cut the sheeting a tad long (maybe 1/16" on each end) and let it overlap. It's easily sanded off once everything cures, and it prevents wasting a whole piece of sheeting by cutting it just a smidge too short.
Once that's done, our goal is to scrape, squeegee, mash, roll, or otherwise remove every single drop of epoxy we can off that sheeting. It'll be VERY hard to believe you're leaving enough...but you are. Best thing I can tell you is to try this some time with a scrap piece of sheeting and a small block of foam....try this procedure, completely, and see the results for yourself before you trust a wing to it. I begin by scraping as much as I can off of the sheeting using the mixing stick....note the huge GLOB of epoxy here...
From there, I just use progressively "finer" tools....a scrap piece of wood, a window tinting squeegee, whatever. I know one fellow that actually turns the balsa "upside down" on some saran wrap, and rolls it from above pressing down as hard as he can, to squeeze every last nanodrop out of the thing.
The key here isn't to leave a bunch of epoxy on...it's to make sure that EVERY square millimeter of that sheeting is covered...but ONLY covered, not smothered. If you have any sheeting coming up after things have cured, it was a LACK of epoxy, not too LITTLE of it.
Just to give some idea, I did a few comparisons here, so you could see what we're talking about:
First, the LE sheeting piece, before epoxy:
Now, the same sheet, after being coated with hair spray and epoxy:
Yep...a whole .1 ounce. Note how the wood just barely appears "damp", and doesn't even have a wet shine to it.
Another comparison:
The TE sheet with epoxy "spread" thinly, but not completely, and not squeegeed off:
The same sheet after carefully squeegeeing (note I hadn't gotten around to wiping down the edges yet...that's important too)
.3 ounces lighter. Big deal, right? Well, again, remember our math: .3 ounces PER SHEET, 2 sheets per side (.6 oz), 2 sides per wing panel (1.2 oz), 4 wing panels for the plane (4.8 oz) Nearly 5 ounces of glue that would be doing NOTHING.
Finally, once things are epoxied, I lay the sheets in place, position the core VERY precisely in its shucks, and then set it on the bench with weight on top. I've found it quite important to be sure that both your bench AND the "top board" are FLAT and SMOOTH, and should cover the entire shuck, not just part of it. For weight, use just about anything you wish, but know that "practical experience" (in other words...a bunch of guys who are good at this say) dictates that about 120-150 lbs of weight is required, and should be distributed as evenly as possible. (Hence why a bunch of folks vacuum bag these things).
Here's my setup:
Time to go run some errands, but later this afternoon I'll pull that wing, and snap some shots to show the clean and solid edges, and the good bond of wood to foam.
(Edited 7-22-07 with new image host)
< Message edited by gboulton -- 7/23/2007 12:14:51 AM >
       Post #: 210
