Aileron installation question on all white Yak 85"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> Aileron installation question on all white Yak 85"
Page: [1]
Login
Aileron installation question on all white Yak 85" - 6/25/2006 5:05:51 PM
zx32tt
Status: offline
Are the ailerons on the 85"Yak matched to wings as a pair or are the interchangeable? The left & right ailerons look identical to me. BTY a big kudo's to the guys in the packing/shiping dept. My Yak arrived in perfect condition, the best packing arrangement I have ever seen!.
Z
< Message edited by Rezagh -- 10/23/2006 6:12:23 PM >
       Post #: 1
RE: Ailerons? - 6/25/2006 5:23:59 PM
Rezagh
Status: offline
Hi zx32tt,
They are ont interchangeable! Have you taken the ailerons off the wing. If not, make sure when you take them off to do the hinging put them back the same way. Let me know if you need help. Also make sure to download the new manual on www.qqaircraft.com
Thank you,
Reza
_____________________________
Quique's Aircraft Company
(in reply to zx32tt)
       Post #: 2
RE: Ailerons? - 6/25/2006 6:09:10 PM
zx32tt
Status: offline
Yes, the ailerons have been separated from the wings. & I did not mark them to keep them matched. How can I tell which one goes to its mate?
Z
(in reply to Rezagh)
       Post #: 3
RE: Ailerons? - 6/25/2006 9:30:43 PM
Rezagh
Status: offline
The side of the aileron that should be next to the root of the wing is wider. Look at the attached pic and maybe best way is to match the colors and scheme.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 4
RE: Ailerons? - 6/26/2006 2:56:11 AM
zx32tt
Status: offline
My plane is all white. I understand that there is a "wing tip end", and a "root end"of each aileron. I also understand there are two close together on the tip end of each aileron. The question is, would the left aileron work with the right side wing?
Z
       Post #: 5
RE: Ailerons? - 6/26/2006 2:59:46 AM
Rezagh
Status: offline
No, it wouldn't. Let me get some measurements for you and get back with you. There is only one side of the aileron that is cut out for the hinges so you can't just flip it over and use the left ail on right wing. Like I said before the root end of the aileron is wider than the tip end but I will get you measurements.
       Post #: 6
RE: Ailerons? - 6/26/2006 4:27:13 AM
Rezagh
Status: offline
Root side measures 3.5" and wing tip side 2.75". Hope this helps.
Reza
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.414RCU1
