Sevro programming and PE problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> Sevro programming and PE problems
Page: [1]
Login
Sevro programming and PE problems - 6/25/2006 9:27:04 PM
flyierjon
Status: offline
Hi, I am running all Hitec 5735 digital servos. They are programmable. I set the servos for certain end points with the hitec programmer and set everything else the way I want it. Then I plug the servo into a channel on the power expander which is then hooked up with my reciever and regulator and then my double 2400 LI- Ion batts. My problem is after i set the settings for end points with servo programmer the servos work fine. I plug them into the expander and they only move a tiny ammount against what i set them to with the programmer. Can any one help please!
Jon
       Post #: 1
RE: Sevro programming and PE problems - 6/25/2006 11:20:56 PM
rrritchey
Status: offline
Hi Jon,
When you say they work fine after setting up with the programmer do you mean you are plugging them into the receiver to check them? There are only buffers in the PowerExpander and they should not change the signals coming out of the receiver. Please let me know more details and I will see if we can work through this.
_____________________________
Robert Ritchey
Owner, Smart-Fly
(in reply to flyierjon)
       Post #: 2
RE: Sevro programming and PE problems - 6/26/2006 3:18:38 AM
flyierjon
Status: offline
They work fine the way i set them up plugged in to the programmer... When I plug the servos into the power expander they dont travel as far as what I set my end points to be in the programmer. I hope that helps
Jon
(in reply to rrritchey)
       Post #: 3
RE: Sevro programming and PE problems - 6/26/2006 2:42:47 PM
rrritchey
Status: offline
Hi Jon,
Try plugging them into the receiver without using the PowerExpander and let me know what happens. Does it do this on all channels or only one?
Robert Ritchey
Owner, Smart-Fly
       Post #: 4
RE: Sevro programming and PE problems - 6/26/2006 11:30:41 PM
flyierjon
Status: offline
Hi bob, I tried my aileron servos and they are the ones with this problem I am having... Yes they have the problem thou the power expander as well as going straight thou the receiver.
       Post #: 5
RE: Sevro programming and PE problems - 6/26/2006 11:37:40 PM
rrritchey
Status: offline
Hi,
Have you checked your travel volume on those channels?
Robert Ritchey
Owner, Smart-Fly
       Post #: 6
RE: Sevro programming and PE problems - 6/26/2006 11:47:47 PM
flyierjon
Status: offline
How do i go about that?
       Post #: 7
RE: Sevro programming and PE problems - 6/26/2006 11:50:44 PM
rrritchey
Status: offline
You will have to find out from your transmitter manual. This is beyond where I can help you.
Robert Ritchey
Owner, Smart-Fly
       Post #: 8
RE: Sevro programming and PE problems - 6/26/2006 11:59:56 PM
flyierjon
Status: offline
Ok thank you bob! I will try that
       Post #: 9
RE: Sevro programming and PE problems - 6/28/2006 6:43:39 PM
todhog
Status: offline
Flyerjon, I have done exactly what you are doing and it works fine. The PE has nothing to do with what you are experiencing. The problem, and it's not a problem but the nature of the receiver, is that the signal from the the receiver is different from the programmer. What you have to do is set your transmitter to the max travel for each channel minus about 5%. Futaba is 140% and I believe JR is 150%. Now set your center and end points with the programmer and check them with the receiver. The center will probably be off a little. This is where you reprogram the center and end points until you get them dead on when the receiver is connected.
Here is the video that will explain everything in much clearer detail than I have done.
http://www.downonthedeck.com/videos_instruction.htm
Watch them all and you will understand it. It takes some time to get this right but when you do its worth it. I programmed two servos per elevator half like this and I plugged all four servos into one channel on the PE. Both elevators move perfectly in unison and the same speed.
Programming servos is a little complex but worth the effort to learn. I also have four aileron servos plugged into one channel on th PE and they work perfectly. I reversed the travel on one wing so the servos move in the correct direction.
Again, the PE has nothing to do with your servo travel and settings, it's your receiver.
Todd
       Post #: 10
RE: Sevro programming and PE problems - 6/29/2006 12:21:09 AM
flyierjon
Status: offline
Thank you Tod, Those videos really helped! Im going to be fixing all my 8 servos for the evening!!
(in reply to todhog)
       Post #: 11
RE: Sevro programming and PE problems - 6/29/2006 4:47:41 AM
todhog
Status: offline
My question is why doesn't Hitec give you any of this info?
Todd
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
