RE: New Mini Electric is here the Falcon 3D!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Thunder Tiger Raptor 50 V2 - ARF
Seller:  atari
Details:   $1,200.00   |  10/27/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter Beginners Forum >> RE: New Mini Electric is here the Falcon 3D!!
Page: <<   < prev  199 200 [201] 202 203 204 205 206 207 208   next >   >>
Login
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 3:32 AM
Whirley Bird
Score: 100
Last Login: 3/1/2009
Status: offline
OK so if I don't pull my leg the amps will stay down and the motor will run cooler
Vegas/
quote:
ORIGINAL: quickster47
Vegas, AKA - WhirleyBird, I think Steve was just pulling your leg and not your amps.
Carl
quote:
ORIGINAL: Whirley Bird
Steve,
How will that make the motor run cooler if it's still pulling the same amps?
Vegas/
quote:
ORIGINAL: sgomes
Katana,
You will notice the motor runs much cooler when you get those new booms!!
Steve
_____________________________
Vegas/
The only Easy Day Was Yesterday.
Hide Signatures
(in reply to quickster47)
       Post #: 5001
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 3:51 AM
Whirley Bird
Score: 100
Status: offline
You bet this a great forum.
I remember joining RCU several years ago and it was more trying to make your way through a mine field wearing over sized snow shoes
If a thread ran to long the moderator would end it.
Flames were very common.
The heli site has always been a nice hang out.
A few days ago I posted a few questions in the fixed wing area and no one responded.
See all that RED TEXT above where you post?
That says it all.
Vegas/
Vegas/
Hide Signatures
(in reply to Gandalfg77)
       Post #: 5002
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 9:08 AM
sillyrabbit72
Score: 100
Last Login: 1/9/2009
Status: offline
hey guys i have a question. i a about to order a falcon and i just had a question about transmitters. what is the difference between mode 2 and mode 1? i thought it had to do with which side the "throttle" was on. (when i say throttle i meen the stick in which the y-axis is not spring loaded and is used to control the head speed.
thanks in advance for any clarification you can provide!!!
Hide Signatures
(in reply to Whirley Bird)
       Post #: 5003
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 9:12 AM
xargxar
Score: 100
Last Login: 5/30/2008
Status: offline
Go check this out. Huge balls, lots of control where things could go very bad in a sec. A bit too reckless for my taste, though.
http://www.youtube.com/watch?v=C7otMY43lwI&mode=related&search=
At the rate I'm crashing, I'll be an expert soon.
Hide Signatures
(in reply to sillyrabbit72)
       Post #: 5004
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 9:16 AM
xargxar
Score: 100
Status: offline
My falcon is still down due to some missing parts. I need to order both the hor and vert stabilizer holders, but can´t seem to get a part # for that. What do i need to order to get those parts? Thanks in advance
Hide Signatures
(in reply to xargxar)
       Post #: 5005
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 10:36 AM
quickster47
Score: 100
Last Login: 6/21/2009
Status: offline
I think that us here in the States have mode 2, throttle and rudder on the left stick and elevator and aileron on the right stick. And I believe that the UK, and maybe the rest of the world, use mode 1 where throtle is on the right an cylic is on left.
Carl
quote:
ORIGINAL: sillyrabbit72
Hide Signatures
       Post #: 5006
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 11:09 AM
sgomes
Score: 100
Last Login: 7/25/2009
Status: offline
xargxar,
Welcome back!! Haven't heard from you for quite a while. Will be thinking of you when we arrive in Marbella tomorrow for some holiday.
Anyway, I know I have seen the plastic part you are looking for, and I think it was for the Shogun. Here is an aluminum part that I think will work, you might contact them for the dimensions. This is the best I can do for now, but if I can think of where I saw it I will let you know. Maybe try some thread searches here and over at the RCGroups Falcon thread.
http://grandrc.com/inc/sdetail/20976
Hope this helps.
Steve
< Message edited by sgomes -- 4/16/2007 11:10 AM >
Uh oh! My wife just got back from a business trip and found landing gear marks on her pillow. Gulp!
Hide Signatures
       Post #: 5007
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 11:35 AM
sillyrabbit72
Score: 100
Status: offline
cool thanks for all the clerificatio cause i want throttle and rudder on the left and cyclic on the right
Hide Signatures
       Post #: 5008
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 12:24 PM
quickster47
Score: 100
Status: offline
xargxar,
I think I know where to get some parts like what you need but I am at work and do not have my usual list of online RC parts sources.
Carl
quote:
ORIGINAL: xargxar
Hide Signatures
       Post #: 5009
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 1:37 PM
sgomes
Score: 100
Status: offline
Carl, Xargxar:
Will these work? I still KNOW I have seen the exact part with the split section. These don't appear to be split, but still may work.
http://www.hobbypeople.net/gallery/165131.asp
Steve
Hide Signatures
       Post #: 5010
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 2:03 PM
quickster47
Score: 100
Status: offline
Steve,
Those are for the Shogun V2 belt drive that has a carbon fiber tail boom larger than the Shogun V1 and the Falcon .
Carl
quote:
ORIGINAL: sgomes
Carl, Xargxar:
Steve
Hide Signatures
(in reply to sgomes)
       Post #: 5011
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 3:15 PM
sgomes
Score: 100
Status: offline
Okay, thanks Carl.
Sorry, Xarxgar
Hide Signatures
       Post #: 5012
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 4:08 PM
tsteege
Score: 100
Last Login: 9/3/2009
Status: offline
Hi everyone,
Well I had to share my news. Even after my Falcon flight thru my wife's orchids in the house, she "let" me get another bird. After tons of research, I just purchased a Align T-Rex 600CF, and Futaba 7CHP radio system. This baby is huge, I can't wait to get it trimmed and setup the transmitter.
I plan to keep my Falcon as well becasue I love to fly it and it works great. I hope to start posting differences and simularities I find between the Falcon and a larger helicopter on my site for people who like me are expanding their love for this hobby.
If no one objects I will post to this site as well.
Happy Flying!!!
Terry
All RC Heli owners unite at the Facebook of RC Helicopter Pilots...
www.MyRCHelicopters.com
Hide Signatures
       Post #: 5013
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 4:18 PM
xplorur
Score: 100
Last Login: 3/30/2009
Status: offline
IM Jealous
thats my next jump after the Falcon , good luck with it.
Peace
x
quote:
ORIGINAL: tsteege
Hi everyone,
Happy Flying!!!
Terry
falcon3d-alum upgraded-Phoenix-35 esc-gy401-4 hs65hb-cool red motor-ar7000-dx7-copilot- Zippy 2200mph 11.1-315mm blade
Hide Signatures
(in reply to tsteege)
       Post #: 5014
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 4:26 PM
Whirley Bird
Score: 100
Status: offline
I think you mean normal and 3 D
You need to keep it in normal before you start to fly it because if the switch is in the 3D mode it over rides the speed control
So if the TX is on and the speed setting is down and you connect the battery the blades kick in at high speed
Vegas/
Vegas/
Hide Signatures
       Post #: 5015
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 5:31 PM
ct420
Score: 100
Last Login: 12/24/2008
Status: offline
tsteege: Contrats on the 600. The first time you fly it, you will be SHOCKED at how easy it is to fly compared to a smaller heli. I don't have one myself (yet), but I have two TREX 450s - They are VERY nice helis, and rock solid...
I still like my Falcon a lot too... I use it for practicing new maneuvers and taking risks that I don't want to take with the Rexes... It's perfect for that...
Good luck with the 600, and post some pics, etc!!!
Hide Signatures
       Post #: 5016
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 5:49 PM
SnowAviation
Score: 100
Last Login: 8/26/2007
Status: offline
I have searched for how to adjust the paddles and cannot find it anywhere, the flat spot on the flybar kinda makes adjustment difficult and one of mine are off by a few degrees.
Does the paddle twist on the metal mount? I tried to twist it but it didn't budge and I didn't want to break it.
Hide Signatures
(in reply to ct420)
       Post #: 5017
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 5:54 PM
quickster47
Score: 100
Status: offline
The part with the allen screw, the metal part of the paddle, actually screws into the paddle and the paddle can actually be rotated a smidgen to align them, or make them horizontal.
Carl
Hide Signatures
(in reply to SnowAviation)
       Post #: 5018
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 6:29 PM
Whirley Bird
Score: 100
Status: offline
Every heli I saw had a small allen screw to loosed but i'm at a loss getting them horizontal with eye ball engennering
Does anyone have a better way to set blade pitch and paddle pitch other then tracking at high rotor speed and doing the eye ball test?
Vegas/
quote:
ORIGINAL: SnowAviation
Vegas/
Hide Signatures
       Post #: 5019
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 6:35 PM
Whirley Bird
Score: 100
Status: offline
Carl,
You can loosen the allen screw and take the paddle right off.
I don't know the best way to align then but when their right on you notice how much better the heli flies.
There must be a better way then spin,look,stop re=adjust.
Vegas/
Carl
Vegas/
Hide Signatures
       Post #: 5020
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 7:03 PM
Mr Nice Guy
Score: 100
Last Login: 6/17/2008
Status: offline
Might be able to use a pitch gauge if it'll fit on the small paddles. I will try mine tonight when I get home. I just eyeballed it and it looks pretty good to me.
Hide Signatures
       Post #: 5021
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 7:12 PM
Whirley Bird
Score: 100
Status: offline
I hear a lot about them but I can't seem to find anyone who sells the tool for adjusting the blades or small paddles.
Bye the time I get the blades in a nice track the black links are work from removing them so many times.
Gotta be a better way.
Vegas/
Vegas/
Hide Signatures
(in reply to Mr Nice Guy)
       Post #: 5022
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 7:26 PM
quickster47
Score: 100
Status: offline
Guys,
Other than eyeballing the paddles the only other way I know is to use a very small bubble level on the paddles. I bought several from HeliHobby and they work great for many things on a heli.
Of course, when you do all this you need to make sure the swashplate is level and all the the other head pieces.
http://www.helihobby.com/html/MA6.html#PARTMA0517
Carl
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5023
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 7:36 PM
Whirley Bird
Score: 100
Status: offline
Carl,
How can you even get close with a bubble alignment tool when the small paddles are symmetrical and the bubble will never be level
I have a laser tool here and I'm going to try that.
I been searching the web and thee are nice blade pitch tools but their all from Hong-Kong
Vegas/
Vegas/
Hide Signatures
       Post #: 5024
RE: New Mini Electric is here the Falcon 3D!! - 4/16/2007 7:38 PM
Mr Nice Guy
Score: 100
Status: offline
I got a pitch gauge from my LHS espritmodel.com I think it was only about 10 or $12. I believe it the align one.
Hide Signatures
       Post #: 5025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.719RCU1
