Broken Brushless Motor- Salvageable?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Broken Brushless Motor- Salvageable?
Page: [1]
Login
Broken Brushless Motor- Salvageable? - 6/28/2006 1:45 AM
nebg9
Score: 100
Last Login: 8/15/2010
Status: offline
I have a PJS 550R brushless motor. A while ago, I was attaching my prop-shaft-adaptor and afterwords the motor sounded like it was gargling and I didn't have as much thrust. Then, I took the motor apart, looked at it, put it back together, and there was no more gargling noise. However, I still didn't have nearly as much thrust. So, now I'm thinking there's a problem with the magnets. I crashed a few times, but nothing really bad. Is there a way to fix the motor? Anyone have any ideas?
Hide Signatures
       Post #: 1
RE: Broken Brushless Motor- Salvageable? - 6/28/2006 7:33 AM
jdetray
Score: 115
Last Login: 6/14/2013
Status: offline
Check to see if the bell (rotor) is still securely attached to the shaft. Grab the shaft with pliers and see if you can turn the bell. You should not be able to turn it.
Magnets can be cracked in a crash, so examine them carefully. Magnets can also be damaged by overheating, which causes them to lose strength.
- Jeff
_____________________________
My other hobby: www.AstronomyBoy.com
Hide Signatures
(in reply to nebg9)
       Post #: 2
RE: Broken Brushless Motor- Salvageable? - 6/28/2006 5:07 PM
nebg9
Score: 100
Status: offline
The shaft seems to be attached. What if the magnets were overheated? Is there a way I gan re-strengthen them or no?
Hide Signatures
(in reply to jdetray)
       Post #: 3
RE: Broken Brushless Motor- Salvageable? - 6/28/2006 6:26 PM
jdetray
Score: 115
Status: offline
If the magnets have lost strength, they can not be restored, at least not by methods available to us!
- Jeff
Hide Signatures
(in reply to nebg9)
       Post #: 4
RE: Broken Brushless Motor- Salvageable? - 7/1/2006 3:36 PM
dyrodium
Score: 100
Last Login: 1/25/2007
Status: offline
True, the heat damages the magnets by unaligning the poles. If you could heat them up again in a really strong magnetic field...
Perhaps you could find a source of replacement magnets? I've seen some around. Although only useful if you know that's the problem.
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
