Ziroli P38 flaps
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Focke Wulf FW 190 1/4 scale
Seller:  BAGOSTIX
Details:   $5,500.00   |  7/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Ziroli P38 flaps
Page: [1] 2   next >   >>
Login
Ziroli P38 flaps - 12/29/2002 5:56:14 AM
flying2bill
Status: offline
In building my ZP38 I am at a point in the center section to install the flaps. I am not doing fowlers. How many have used the internal linkage method shown on Ziroli's plans and do they work well. I've seen a couple of pics of others planes and they have the servos hanging out the bottom of the wing. Is there a problem installing them internally or did they just go the easy route?
_____________________________
Rule of the 3 W's
If it involves Wheels, Wings, or Women, it's bound to be trouble.
       Post #: 1
Flaps - 12/29/2002 7:05:27 AM
CaptainHook
Status: offline
I put servos' in for all four flaps. Just my preference I guess as I am not a big fan of bell cranks on a high load surface. You can hide the servo in the wing if you don't like the looks of the servo hanging out of the wing.
Carey
(in reply to flying2bill)
       Post #: 2
flaps - 12/29/2002 9:22:36 AM
flying2bill
Status: offline
A servo on each flap was my plan, the way I interput the plans is with the servo and linkage inside the wing. I have a PCK laser kit and it comes with ply flap horns. I am considering replacing them with aluminum ones that I will make using the ply ones as a pattern, or do you think the ply is ok. I have had ply horns break on me before
Rule of the 3 W's
       Post #: 3
Ziroli P38 flaps - 12/29/2002 3:40:46 PM
P38J
Status: offline
the internal linkage as shown on the plans work fine as long as the horns are made from aircraft grade ply the holes will not develope excess play, if you make them from metal then you have to worry about metal to metal contact causing possible rf noise.
       Post #: 4
Ziroli P38 flaps - 12/29/2002 8:40:05 PM
flying2bill
Status: offline
I will be using ball link type connectors such as Rocket City through out the whole plane, in 4/40 of course. That should help to eliminate the RF interferance. The PCK horns are aircraft ply, I just have a trust issue w/ply horns. Been there, crashed that.
Rule of the 3 W's
       Post #: 5
Ziroli P38 flaps - 12/29/2002 10:25:56 PM
JLB
Status: offline
I am about the same place you are in construction. Have decided to do ball link connectors as well just like I always do. Have been undecided about the Fowler flaps and was wondering why you decided not to go that way. I am leaning against also just because of the added construction time and I'm certainly not headed to the scale masters anyway.
       Post #: 6
Ziroli P38 flaps - 12/30/2002 9:05:39 AM
flying2bill
Status: offline
Looks like I'm not doing them for the same reasons as you. Don't want to complicate the building process any more than it already is nor am I going to Scalemasters either
Click to see fullsize image.
Click for fullsize
Rule of the 3 W's
       Post #: 7
Flaps - 12/30/2002 11:28:06 AM
luckyb001
Status: offline
I built my ZP-38 per the plans with 4/40 pushrods and Sullivan clevices of all 4 flaps. One servo per flap. 4 years and over 100 flights and never had a problem. If I had to set it up again I would use a JR Matchbox. What a pain it was seting up 4 servos to all work the same. PS use a high tourqe servo if you want them to come down under a load. Mike
"No hanger Queens"
       Post #: 8
Ziroli P38 flaps - 12/30/2002 10:58:02 PM
k_sonn
Status: offline
flying2bill:
Take a look at the bell cranks sold by Nelson Hobby. They are made of T6 aircraft aluminum and use the Rocket City 4-40 ball link. They have two ball bearings that the mounting bolt swivels aroung. They are very strong and slope free. They come as a kit that you put together.
Click for fullsize
       Post #: 9
Ziroli P38 flaps - 12/31/2002 10:45:29 AM
flying2bill
Status: offline
K_sonn, those are some cool looking bell cranks, I'll keep them in mind, however I am doing plug in wings so will need seperate servos in the wing panels, Might could use them in my mock p38 trainer though.
Luckyb001, enlighten me on JR Match box please. I have hi-torq servos for the whole project. Most are 100 oz, a few 80 oz. Also planning to run 6 volt packs for the servos.
Rule of the 3 W's
       Post #: 10
Matchbox - 12/31/2002 4:25:04 PM
luckyb001
Status: offline
JR has a electronic device called a Matchbox. It will allow you to use up to 4 servos together and set the travel and endpoints for all 4 to be the same. A Friend of mine just used one to set up a plane and he said it worked great. You can also reverse servos if you need to. I have not used one yet but it would be great on a P-38. Mike
"No hanger Queens"
       Post #: 11
p38 flaps - 1/1/2003 9:56:25 PM
flying2bill
Status: offline
this matchbox gizmo sounds just like the contraption I need for the flaps, tips on who is selling them?
Rule of the 3 W's
       Post #: 12
Ziroli P38 flaps - 1/1/2003 10:08:21 PM
Vince
Status: offline
The matchbox is a neat device, but doesn't it require it's on power supply?
Vince
Can't keep my mind from the circling sky.
       Post #: 13
Ziroli P38 flaps - 1/1/2003 10:25:47 PM
JLB
Status: offline
Matchbox can be purchased direct from Horizon or any dealer that handles JR equipment. The unit has the option of using it's own battery but that is not required. If you do not connect a separate battery pack, it simply uses the receiver power supply like any direct connected servo.
       Post #: 14
own power supply? - 1/2/2003 9:52:08 AM    <
