sfaust
MA, USA Status: offline
[QUOTE]Originally posted by Grayoon Ok, i know you get more out of your servo's...more speed and torque, but is there a reason all the radios come with a 4.8 and thats what most shops sell? I have a couple of 6.0v packs here that would work but i am wondering about why the 4.8v? All help is appreciated. Hope that made sense. Thanks [/QUOTE] A.T. hit the nail on the head. 6v will give you more speed and torque at the servo than 4.8v 6v will 'effectively' reduce your capacity by 12% to 20%, so you want a slightly larger 6v pack than a 4.8v pack. I.e., a 1200mah 6v pack to replace a 1000mah 4.8v pack. There will be a slight increase in wear on the servos since they are working a bit harder, however, still well within design specs and limits. Manufacturers approve using 6v packs, and many of them rate their servo torque specs based on 6v. Regulators can be used, but most are not using them, citing the added circuits, connections, and lower reliability of not using them. Using 6v helps recover a lot of the voltage loss in the wiring and switches, which reduces the speed/torque even further on a 4.8v system. In fact, using a 6v pack doesn't guarantee that the servos will even see 4.8v. It all depends on the wiring. Receivers are quite happy running at 6v.
_____________________________
Stephen http://www.StephenFaust.com/giantscalerc - my hangar, http://www.StephenFaust.com - commercial photography
