RE: 75cc yak QB question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: 75cc yak QB question
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: 75cc yak QB question - 8/2/2006 9:39:19 PM
smarks
Status: offline
At sea level a 75cc to 80cc would be perfect. I am flying it at 6000 feet and also have a smoke system in it. It is probably a bit underpowered here for the weight. I am flying again this weekend. I should get some more flights on it and will post again how it does.
_____________________________
Special Thanks To:
www.Smart-Fly.com
(in reply to charrua)
       Post #: 26
RE: 75cc yak QB question - 8/2/2006 10:21:41 PM
charrua
Status: offline
is there an online manual for this 75cc yak???? I'm looking for one.
What's the lenght of the pushrods for the ailerons and elevator half?????
(in reply to smarks)
       Post #: 27
RE: 75cc yak QB question - 8/2/2006 10:50:37 PM
smarks
Status: offline
http://aero-works.net/upload/manual/75cc_yak.pdf
(2) 4-40 2-1/2” two end threaded pushrod for elevator
(4) 4-40 3” two end threaded pushrod for ailerons
< Message edited by smarks -- 8/2/2006 10:53:03 PM >
Special Thanks To:
www.Smart-Fly.com
       Post #: 28
RE: 75cc yak QB question - 8/3/2006 10:45:00 AM
bodywerks
Status: offline
quote:
ORIGINAL: charrua
I'm still waiting for someone who put a 100cc on it to see how it did and what's the auw on it!!!!!!
It looks like it's undepower with a 75cc isn't it?????
You will probably be waiting a while...
There is no place in GA where this would be underpowered with an 80 or 75. Smarks decked his out and has one of the heavier engines on his. With a ligher, more powerful engine such as the ZDZ 80 Super, and careful equipment selection, 22 pounds should be easily obtainable. At sealevel, you would have a rocket on your hands!
Putting a DA100 on this thing would ruin it - you'd be pushing 25 pounds! That might be great for power, but the plane would fly like a brick! You'd be looking at a 35 ounce wingloading - that's higher than most 40%ers!
STRAIGHTEN UP AND FLY LIGHT!!!
       Post #: 29
RE: 75cc yak QB question - 8/3/2006 5:11:14 PM
smarks
Status: offline
Bodywerks - Meant to ask you, do you still have your QS Yak?
Special Thanks To:
www.Smart-Fly.com
(in reply to bodywerks)
       Post #: 30
RE: 75cc yak QB question - 8/3/2006 9:44:36 PM
bodywerks
Status: offline
sent you a PM
       Post #: 31
RE: 75cc yak QB question - 8/3/2006 9:50:49 PM
charrua
Status: offline
quote:
ORIGINAL: bodywerks
quote:
ORIGINAL: charrua
so I guess i'll have to weit for the 35% then!!!!
       Post #: 32
RE: 75cc yak QB question - 8/5/2006 2:13:23 AM
STG
Status: offline
quote:
ORIGINAL: bodywerks
Going from the 80s to the DA100 should be more like 1 pound not 3?
_________________
The very nice manual shows H.D. plastic servo arms--Is this OK for a 23 pound 3D/IMAC plane?
The open canister/pipe tunnel looks great on this plane.
Good Flying to you!
See Blog for RCU Video's
       Post #: 33
RE: 75cc yak QB question - 8/5/2006 2:58:55 AM
bodywerks
Status: offline
quote:
ORIGINAL: STG
quote:
ORIGINAL: bodywerks
_________________
The DA weighs 1.5 pounds more than the ZDZ80, plus the extra weight of the extra ignition lead, the larger prop, the dual mufflers, the extra fuel cargo, etc. It's not 3 pounds but it is at least 2 or close. I never directly said there was a 3 pound difference. My 22 pound talk was considering minimum equipment on an 80CC powered plane with CF everything.
As for the plastic arms being OK, Yes, as long as they are the karbonite arms or maybe the Dubro heavy-duty arms. Mark Dennis is using the Karbonites on his AWX 35% 260 exclusively and has yet to have a failure
(in reply to STG)
       Post #: 34
RE: 75cc yak QB question - 8/5/2006 3:12:35 AM
STG
Status: offline
quote:
ORIGINAL: bodywerks
quote:
ORIGINAL: STG
quote:
ORIGINAL: bodywerks
_________________
Thanks for the great info. This plane sure does look awesome.
Good Flying to you!
       Post #: 35
RE: 75cc yak QB question - 8/5/2006 10:40:30 PM
aerobatic 3D
Status: offline
Will a ZDZ 60 power the new QB 75 cc Yak from Aeroworks? I just crashed a stuipd Wild Hare 540 Edge 28% and I never want another Wild hare so I was hoping the 75cc Yak would be a good choice. Dennis whats you input on this question??????
(in reply to STG)
       Post #: 36
RE: 75cc yak QB question - 8/6/2006 12:37:10 AM
Mark Dennis
Status: offline
The ZDZ 60 will be to small for the 75cc Yak but it would be perfect for our 50cc and would give it awesome power.
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to aerobatic 3D)
       Post #: 37
RE: 75cc yak QB question - 8/7/2006 12:03:26 AM
sukhoi26mx
Status: offline
quote:
ORIGINAL: smarks
I just finished my first five flights on the 75cc Yak with a ZDZ 80 Super on it and am thoroughly impressed. I fly at just over 5000' and with a new engine have good accelerating punch-out of the hover. Currently turning a Menz 26x10 at just over 6000. I suspect I'll see another 200-300 as she breaks in. The Yak flies very light, although I haven't weighed it (I weigh at the local small town Post Office, and they've been closed since Friday). Components include the ZDZ, 5955's all the way around, 545bb on the throttle, manual choke, Smart-Fly Power Expander, Ignition Cutoff, TurboReg, and flag switch. I am using my 12Z and 5014 PCM G3 receiver, so the new 14MZ Power Expander is a good match. No smoke for now, and the stock muffler.
I was really impressed with the quality of the components. I used all of it, which is really unusual for me. Normally I vertical file the majority of the hardware on most giant-scale ARF's, so it was a pleasant surprise to have such nice hardware.
Anyway, back to the discussion on power, I think the ZDZ 80 Super is perfect through at least 5000'. Might need more up at 6500, but should be ridiculous at sea level!
Scott
Click to see fullsize image.
Click for fullsize
       Post #: 38
RE: 75cc yak QB question - 8/7/2006 2:00:29 AM
STG
Status: offline
quote:
ORIGINAL: sukhoi26mx
quote:
ORIGINAL: smarks
Scott
Good to hear about the hardware. Makes this QBARF even more of a value. Are you running the new Supersonic pitts?
Good Flying to you!
(in reply to sukhoi26mx)
