75cc yak QB question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> 75cc yak QB question
Page: [1] 2 3   next >   >>
Login
75cc yak QB question - 7/1/2006 9:40:00 PM
Mike3579
Status: offline
Will the 75cc yak perform 3D with the 3W75? Anyone have this plane with the 3W 75 on it yet? How would hovering be with this engine. Could you use one 5955 servo per wing panel?
_____________________________
takeoffs are optional Landings are mandetory
President of the Flying Eagles Model Club in Prompton PA
       Post #: 1
RE: 75cc yak QB question - 7/2/2006 1:37:00 AM
Mark Dennis
Status: offline
When we tested ours with the ZDZ 80 it had a TON of power even at 6000' asl the 75cc would do just fine for unlimited 3D if you are at or near sealevel. As for one servo per wing I would stick with 2 since the size of the aileron is so large.
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to Mike3579)
       Post #: 2
RE: 75cc yak QB question - 7/19/2006 2:26:52 AM
Nate69
Status: offline
I don't know for sure but i think it will be awesome with the 3w75. I am starting to put the 75cc yak together with the 3w 75 It may be a couple of weeks before i get it done and flying.
(in reply to Mark Dennis)
       Post #: 3
RE: 75cc yak QB question - 7/19/2006 8:06:34 PM
Scoubidou
Status: offline
Mark
If i want to install a tuned pipe with the 3W-80XI, what's the header drop?
Daniel
Seneca Engineering
http://www.seneca.ca/
       Post #: 4
RE: 75cc yak QB question - 7/26/2006 10:55:55 PM
smarks
Status: offline
I have one with a 3W75i finished. Will be able to tell you how it performs after this weekend, hopefully. I am at 6000 MSL, but the 3W75 should be fine.
Click to see fullsize image.
Click for fullsize
< Message edited by smarks -- 7/27/2006 1:19:57 AM >
Special Thanks To:
www.Smart-Fly.com
(in reply to Scoubidou)
       Post #: 5
RE: 75cc yak QB question - 7/27/2006 12:52:59 AM
charrua
Status: offline
man that's a good looking plane!!!!
I inda of want one but I want to put a Da 100 in the nose,,,maybe I should wait for the 100cc yak!!!!!
How wide is the cowling?????
(in reply to smarks)
       Post #: 6
RE: 75cc yak QB question - 7/27/2006 1:19:13 AM
smarks
Status: offline
Thanks man! It took longer than the 8 hours they say it takes to put it together. The cowl is about 10 1/2" wide. That would be one mean beast with a DA100!!
< Message edited by smarks -- 7/27/2006 1:20:27 AM >
Special Thanks To:
www.Smart-Fly.com
(in reply to charrua)
       Post #: 7
RE: 75cc yak QB question - 7/27/2006 2:07:34 AM
charrua
Status: offline
I know that's why I'm afraid it would be too much,,,but at the same time I see lot's of guys outhere with 33% ers and Da 100 in it!!!
Tha thing is if it only weight 22lb I could fly it with my DA-50!!!
I flew the QB 260 with the DA 100 and at 29+ lb it would hover at only 1/2 throttle and would shout it out almost like a rocket.
I'm the kind of guy that thinks that light flies better and I don't want to make a plane that it's sopoused to weight 22 or so lb. with a 75/80cc and installibng a 100c might go over 24 or so..
I can't wait to see more videos of either planes!!!!
       Post #: 8
RE: 75cc yak QB question - 7/27/2006 2:16:24 AM
bodywerks
Status: offline
If you were going to put a twin in this plane, the only sane option would be the BME 110 and stock mufflers. It would weigh less than a ZDZ 80 Super with a pitss-style muffler.
Smarks, did you get a chance to weigh it? What other equipment did you use?
STRAIGHTEN UP AND FLY LIGHT!!!
       Post #: 9
RE: 75cc yak QB question - 7/27/2006 2:20:03 AM
charrua
Status: offline
I heard the BME 110 is not that bad ass,,,is it???? I heard they get hot!!! is it right????
(in reply to bodywerks)
       Post #: 10
RE: 75cc yak QB question - 7/27/2006 2:49:14 AM
smarks
Status: offline
Here is all the equipment:
JR9303
Rudder - Two JR8611a pull pull
E - Two JR8411
A - Four Hitec5945MG
Throttle and Choke - Hitec5475HB
Matchbox on elevators
Smoke - Slimline Showtime Pro
3W75i w/Pitts
Nova Extra spinner from Air wild
Mejzlik 24x10
Duralite batteries 2400 ignition 4000 on receiver fail safe switch/regualtor
CF wing tube
Came out to just under 24 with smoke. Probably a bit on the heavy side. What can ya do??
Question for you bodywerks - You fly down in the springs right...I think we met out at chatfield. I had a Wild Hare Extra 300lx. Remember?? Anyway, the engine offset for the Yak is recommended at 7 to 7 1/4. Mine is at 6 1/4. You think that will hurt? Someone told me that I need extra clearance because of the big cowl. I have run the engine and it seems to pull just fine. Thoughts?
Special Thanks To:
www.Smart-Fly.com
       Post #: 11
RE: 75cc yak QB question - 7/27/2006 4:42:20 AM
Aerohead
Status: offline
7 to 7 1/4" is not EXTRA clearance. It is the clearance the manual calls for. Look at the pics of the real Yaks. The prop is spaced way out from the cowl. And the reason is to get more prop blast past that huge cowl. But if the looks bug you, go ahead and stick it right up close.
Nick Jones
Badges? We don't need no stinking badges.
       Post #: 12
RE: 75cc yak QB question - 7/27/2006 4:55:12 AM
smarks
Status: offline
But you don't think it will cause any major issues being closer?
Special Thanks To:
www.Smart-Fly.com
(in reply to Aerohead)
       Post #: 13
RE: 75cc yak QB question - 7/28/2006 2:13:10 AM
Mark Dennis
Status: offline
quote]ORIGINAL: smarks
[/quote]
As long as you can get the plane to balance you will be OK. It does help make the prop a little more efficient but the big reason is for 3D. On another note were did you get the carbon tube from? The plane looks great by the way let me know how the maiden goes.
Team Aeroworks
       Post #: 14
RE: 75cc yak QB question - 7/29/2006 7:26:13 AM
smarks
Status: offline
Thanks for the info. It does balance fine. Just curious why it helps with 3D?
I had the carbon tube left over from a Wild Hare Extra 300LX. Got it from Troy Built. Same ID and OD. Although it was about 3" too long, but cut it to the same length as the stock tube and it fits perfectly.
I'll let you know how she flies!
< Message edited by smarks -- 7/29/2006 7:30:56 AM >
Special Thanks To:
www.Smart-Fly.com
       Post #: 15
RE: 75cc yak QB question - 7/31/2006 8:06:50 PM
bodywerks
Status: offline
quote:
ORIGINAL: smarks
JR9303
E - Two JR8411
3W75i w/Pitts
Mejzlik 24x10
CF wing tube
It was that nice-lookin, but 22 pound 50cc Extra with the 3W 75, right? I remember. If you like how that thing flew and the power it had, then you will love this Yak! 24 ain't bad with a smoke system, but probably not enough to pull out of a hover...
As for the prop clearance from the cowl, it is necessary to have a considrable amount in order to get the most thrust out of the prop and it also might help the engine run cooler. You can try it like you have it and if it doesn't get hot and has enough vertical for you then leave it.
       Post #: 16
RE: 75cc yak QB question - 7/31/2006 8:12:52 PM
bodywerks
Status: offline
quote:
ORIGINAL: charrua
I'll be honest. I am not impressed with the power of mine, but I may just be having issues. I have seen some that were powerhouses and BME claims that no DA should be able to keep up with it. I have unfortunately found just the opposite. And yes, the engine does run hotter than the DA, but
