What's voltage for the new MVVS's ignition ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> What's voltage for the new MVVS's ignition ?
Page: [1]
Login
What's voltage for the new MVVS's ignition ? - 7/2/2006 12:17:49 AM
flassh
Status: offline
Hi,
I have buy the last mvvs 45cc and i have put a 1s2P lippo on agnition. But the led of ignition is flickering for to inform that battery is empty and there is no spark ! I checked and it's not empty ! I don't understand this ignition. What's is the good voltage 6volts ? 7.4volts ? or 8.4volts ?
And, I did not understand the programming of the system easy start !!
Please help me.
Thanks.
Pascal.
< Message edited by flassh -- 7/2/2006 12:31:50 AM >
       Post #: 1
RE: What's voltage for the new MVVS's ignition ? - 7/2/2006 10:33:47 PM
pe reivers
Status: offline
You need a 2S pack
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik
There is sanctuary in analisys.
(in reply to flassh)
       Post #: 2
RE: What's voltage for the new MVVS's ignition ? - 7/3/2006 11:35:21 AM
flassh
Status: offline
Hi,
I have a 2s put on ignition and the Led is flickering ! But my lippo is full ! Are you sure that 7,4volts is enough ?
Pascal
(in reply to pe reivers)
       Post #: 3
RE: What's voltage for the new MVVS's ignition ? - 7/3/2006 8:56:11 PM
flassh
Status: offline
Manual say 2s ! And for voltage : 6 - 8.4v
2s is 7.4v but maybe it's no enough ?
(in reply to Ramz-to-tha-z)
       Post #: 4
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 6:58:26 PM
pe reivers
Status: offline
even and fast on-off blinking is low voltage
long on-short off blinking is long silencer ignition curve
long on long off blinking is short silencer ignition curve.
If you have a ICU professional, it needs 9-13 volts
       Post #: 5
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 9:57:56 PM
flassh
Status: offline
Hi,
Thanks but my question was "2s (7.4v) is enough ?"
Tomorrow I buy a 8.4 nimh pack for to try. And when you don't know something you can say "I don't know" preivers !!!
< Message edited by flassh -- 7/4/2006 10:00:05 PM >
       Post #: 6
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 11:00:10 PM
pe reivers
Status: offline
(in reply to Tor)
       Post #: 7
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 11:01:38 PM
flassh
Status: offline
2S1P (2s) is 7.4v. So is it enough. If you have the mvvs 45cc with the new ignition you can talk about battery that you use.
(in reply to Tor)
       Post #: 8
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 11:12:51 PM
flassh
Status: offline
Which voltage use to be made function this new ignition ? Me with a 2S1P it answers me that the accumulator is discharged. Thus does that want to say that it is necessary to use an accumulator of 8,4v? And to finish that what 6 - 8.4v wants to say? It is the beach of use?
       Post #: 9
RE: What's voltage for the new MVVS's ignition ? - 7/4/2006 11:26:49 PM
flassh
Status: offline
Yes I have a 2S1P (7.4v).
I know that 2S1P is 2 elements of 3.6v and I reapeat I HAVE 2S1P PUT ON IGNITION AND IGNITION SAY THAT IT'S EMPTY !!!!
I looked at behind the ignition and I have see a big "P" maybe my ignition is a professional version ?! It's crazy ! Usually the 45cc is delivered with a standard version of ignition ?
(in reply to Tor)
       Post #: 10
RE: What's voltage for the new MVVS's ignition ? - 7/5/2006 10:18:11 AM
flassh
Status: offline
Thanks cyprusjets. Yes I have the P version ! I have put a 3S1P on ignition and I have a BIG spark ! I will try to start the engine on saturday with friends at field.
(in reply to cyprusjets)
       Post #: 11
RE: What's voltage for the new MVVS's ignition ? - 7/5/2006 11:02:43 AM
flassh
Status: offline
The summer will pass very quickly and I would undoubtedly not have time to finish my Extra-330L before leaving on holiday. I lost more than one week to be tried to make function this (b)uk ignition!
       Post #: 12
RE: What's voltage for the new MVVS's ignition ? - 7/7/2006 8:18:02 PM
flassh
Status: offline
Hi !
Today the engine have run very well. I have mount a 22x12 propeller and the engine is very impressive. The choke is controlled by ignition. The idle is gone down to 887 rpm !!!!!!!!! Enjoy this engine !!!!
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
