Wheels spinning on idle?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> Wheels spinning on idle?
Page: [1]
Login
Wheels spinning on idle? - 7/2/2006 5:20:52 AM
tablist56
Status: offline
ok guys, almost there! lol...
can get it started ok now. just cant seem to work out why my wheels spin at idle?
i have a 1-2mm carb opening at brake/idle.
any ideas?
(btw does anyone know how u can change the topic of a post after u have posted? might have been easier to change the topic of my other post)
       Post #: 1
RE: Wheels spinning on idle? - 7/2/2006 5:29:06 AM
hpi apollo
Status: offline
1mm of carb barrel opening is just righ, it might require a little less or more (doubtful) each engine is very unique, make sure your clutch bearings arent bad and make sure that the clutch springs arent loose and dragging causing it to spin the gears, also, you could have your low speed needle a little too lean, but never sacrifice tuning for the car to sit still, good luck
_____________________________
95% of statistics are made up on the spot
(in reply to tablist56)
       Post #: 2
RE: Wheels spinning on idle? - 7/2/2006 5:31:01 AM
Rob6
Status: offline
Either you clutch it melted or the spring is snapped or come loose. OR your idle is to high. Using the throttle servo is a bad to set your idle. I am not familiar with the HPI engines but i know there is a idle screw on there. The idle should be at the most 1 1/2 MM's open.
-OS-
If your a Mac User put this in your signature to show your pride!!
       Post #: 3
RE: Wheels spinning on idle? - 7/3/2006 3:27:06 AM
tablist56
Status: offline
so when i start the car, the transmitter should be turned off so i can manually set the carb to 1/4 open, then once she is started THATS WHEN i turn on the transmitter to get the carb back to 1.5mm on idle?
is that right?
(in reply to Rob6)
       Post #: 4
RE: Wheels spinning on idle? - 7/3/2006 3:50:51 AM
hpi apollo
Status: offline
ALWAYS i repeat ALWAYS start the car with the transmitter (tx) and receiver (rx) turned on, and 1/4th open is too much, the hpi manual says something similar to that, dont do it, 1.5mm should be enough, there should be a black screw on the front that takes an allen wrench, adjust that
       Post #: 5
RE: Wheels spinning on idle? - 7/5/2006 3:41:10 AM
tablist56
Status: offline
ok cool will do. i can so see why some people hate nitros man! i guess once i get it all down ill love it! hahaha
thanks for helping me on my other thread btw hpiapollo! its much appreciated.
i have updated the other thread for you. thanks mate.
(in reply to hpi apollo)
       Post #: 6
RE: Wheels spinning on idle? - 7/5/2006 3:42:44 AM
tablist56
Status: offline
i guess u could always increase the throttle trim to increase the carb opening to help start the car then reduce the trim once started and warmed up.
       Post #: 7
RE: Wheels spinning on idle? - 7/5/2006 3:53:33 AM
hpi apollo
Status: offline
on my mx-3 it has the throttle adjustment, and when i am starting or warming it up i always set it really high, it actually helps a fair amount
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.891RCU1
