Don Smith B-29 question
Tower Hobbies
Logged in as Guest
  Printable Version
Balsa USA Piper J-3 - 1/3
Seller:  RC Extreme power
Details:   $3,000.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Don Smith B-29 question
Page: [1]
Login
Don Smith B-29 question - 7/2/2006 11:31:46 PM
aerowoof
Status: offline
I am getting ready to start my 5 year plan to build the 141"b-29 from ds plans.After looking at them for a while this afternoon,the first question I have is what is with the rudder horn?I understand the hinges .It is a pice of 1/8 wire that runs the lenght of the rudder,thru 2 pivot points made of aluminum or fiberglass or phenelic material inside a plastic tube,do not know why a plastic tube would be used unless to try to cut down friction.but then it shows what looks like a tube over the wire with the rudder horn on it.know the only way this is going to turn that rudder is if that wire is epoxied securly to it.anyone that has built one of these could you please enlighten me a bit on this part of the contruction.Thanks
       Post #: 1
RE: Don Smith B-29 question - 7/2/2006 11:52:56 PM
Ichy
Status: offline
Can't help you but if you take a pic of the plans in that area and post it someone might be able to figure it out.
(in reply to aerowoof)
       Post #: 2
RE: Don Smith B-29 question - 7/3/2006 12:14:00 AM
aerowoof
Status: offline
If they built from the plans then they will know what I am referring too.I want advice from an actual builder.
(in reply to Ichy)
       Post #: 3
RE: Don Smith B-29 question - 7/3/2006 10:56:07 PM
sergio luiz
Status: offline
Hi man ,
If you can put a pictures oh the place of the to have am idea which his problem .....
Sergio(JOCA)
I have plans B-17 DS plans maybe can help ........
Regards
       Post #: 4
RE: Don Smith B-29 question - 7/3/2006 11:33:53 PM
TLH101
Status: offline
quote:
ORIGINAL: aerowoof
It's not real likely you will find a lot of builders of this model. It is a "major" undertaking for even the most dedicated modeler. BB Webber at Bomber Field has built 2 of them over the last 10 years.
_____________________________
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
       Post #: 5
RE: Don Smith B-29 question - 7/4/2006 7:05:47 PM
aerowoof
Status: offline
I have the D.S b-17 plans also and the rudder setup is almost the same ,take a look at your b-17 plans and see what you think.
(in reply to TLH101)
       Post #: 6
RE: Don Smith B-29 question - 7/5/2006 4:46:47 AM
Jgear
Status: offline
Ive got the 169" plans and it looks like old style hinging. 1/8" music wire soldered to a brass tube and the tube is most likely epoxied to the three lower ribs. Though you could probably make it removable using wheel collars to lock the wire into place. Just a thought...
       Post #: 7
RE: Don Smith B-29 question - 7/7/2006 4:02:35 AM
Saturn5
Status: offline
hi. if it helps i built ds b17 the rudder is the same with 1/8wire with hinges the tube is just a out line on the plans what i did was built the wire into the leaningedg grove to fit . on the bottom of the rudder 3or 4'' i used the plastic tube to go in to fus like a bearing holder and conected the horn it works fine only thing you cant take the rudder off 1/8 wire came about 18''long with 6'' in to the fus my b17 will fly in august its on rcu 138 ws ds good luck
(in reply to Jgear)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.781RCU2
