malcolmm
BC, CANADA Status: offline
I've now got almost 50 flights on my Reactor. I increased the elevator travel significantly from the suggest 3D rates in the manual. Flat spins are now truly flat, although I can't do climbing flat spins, I've never managed that on any plane I've owned. Elevators are excellent with little or no wing rock, provided you are flying into a fairly stiff breeze. I think I may still need some more elevator travel, without a strong headwind wind, the plane won't do the elevator manuever. Knife edge is wonderful. I planned on mixing out the coupling, I ended up not bothering for now, there is so little coupling. Everything, apart from the tendency to tip over on takeoff/landings, is great. I love the fact that the Reactor has no tendency to want to snap, unless you want it to. I wish I could say the same about my Showtime 90, that plane can bite you. Even my Somenzini 72" Yak isn't so forgiving as the Reactor. My OS 55 AX is broken in now, tons of power. I was worried about the covering as the clear layer tends to separate from the colour layer. I have had to glue done a few edges, but overall it is holding up well, and the plane still looks great. I like the plane so much I filled out the suggestion form at the Great Planes website asking them to build larger versions of the Reactor. Malcolm
