RE: Great Planes Reactor GP/EP 3D ARF .46-.70
Tower Hobbies
Logged in as Guest
Users viewing this topic: Jason Lewis
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great Planes Reactor GP/EP 3D ARF .46-.70
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/8/2007 4:19:38 PM
antiquefer
Status: offline
I have put about a gallon of fuel through the Ys 63 in my Reactor. The plane is a good 3d platform. There is a misprint in the construction manual. In one place in the manual it says that the measurement from spinner backplate to firewall is 4-5/16 inches, when it is actualy 4-15/16. I butchered my cowel due to this error. oops. The plane sits on the ground at nearly flight attitude, consequently takeoffs are steep and abrupt. I made the tailwheel as short as possiable, and squeezed the main gear together to make it taller and this helped allot. I am useing futaba 3004s on the ailerons.hitec 225s on the tailfeathers and throttle on 6 volts. Sofar this is working well. Knifedge is easy, with no coupeling. Waterfalls with nect to no correction to keep it flat. Crazy stable in harrier, and elevator, upright as well as inverted.
(in reply to JustErik)
       Post #: 476
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/9/2007 3:13:26 AM
antiquefer
Status: offline
YS63 in my reactor. Very good combo. Will do it all. Shorten tail gear and squeez mains together to rais nose to make rotation not so abrupt.
       Post #: 477
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/24/2007 3:54:09 PM
rclement
Status: offline
Well, After lots and lots of experimenting I've finally gotten this plane flying perfectly. Here's my set up for what it's worth. I'm using a Saito 82 and have .040" of shim behind the top of the engine mount for down thrust. I have taken out the original landing gear in favor of a set from a U Can Do. Just happen to have an extra set and found that they work great. Also I had the battery pack at about 15" forward of the very back of the fuse (measured from the hinge point of the fuse and rudder) but found that I still had to add 1 oz of tail weight to get it to balance right. Recently though I moved the battery to an area just forward of the fuse/rudder hinge point and put the battery in there and took off the 1 oz of tail weight. With some carefull cutting and some epoxy it fit in there good and is solid. Also since I had noticed a little bit of siphoning of fuel while it was sitting and some poor engine response I put a loop in the fuel line and that seems to have helped out a lot.
The CG is now 5 1/2" and the plane flies spectacular and the ground handling is great. It hovers good and it knife edges good with no coupling at all. Also when I roll it inverted it doesn't dive like it used to. It just stays relatively level. This has become one of my favorite planes to fly. Here's the pics.........
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rclement -- 6/24/2007 4:13:14 PM >
_____________________________
Any government, that''s big enough to give you what you want, is big enough to take what you have.
(in reply to antiquefer)
       Post #: 478
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/25/2007 12:42:13 AM
Ernie Misner
Status: offline
Nice work Rob! Work is right, Iknow you have really stuck with it on this plane. Thanks a lot for sharing cuz that will save us some time!
Ernie
(in reply to rclement)
       Post #: 479
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/25/2007 2:39:15 AM
rclement
Status: offline
Thanks Ernie and thanks for the idea of putting a loop in the fuel line.
(in reply to Ernie Misner)
       Post #: 480
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/26/2007 2:00:08 AM
Ricky Blade
Status: offline
for what its worth, i also have a saito82a installed inverted in my reactor. spectrum dx7 stock dig servos. my first 4stroke and with not too much experience on 2cycle i followed manual to the letter. after break in on the bench things seemed ok. finished installing it on the plane and test running ready to fly. the drenching of fuel oils that took place was incredible! it was dripping from everywhere. i was never really satisfied with the tuning of the engine (high speed seemed to hunt and vari too much and the idle wasnt very smooth or low) i was repeatedly told "DONT TOUCH THE LOW MIXTURE SCREW! ITS SET AT THE FACTORY!" OK, I WONT TOUCH IT. ...So having to scratch this insatiable weekly itch i went flying and wiping, flying and wiping, flying and wiping, you get the picture... by now oil soaked all the covering is peeling off and its looking rough from all the patch work. (by the by, wheel pants off and 3" soft foam wheels i dont have major nose over issues if the grass isnt too tall). running omega 15% blend in both my 2 & 4 cycles and really enjoying the plane i was willing to try anything, so....i removed the cowling and with thin blade screwdriver in hand i fired it up. i just was going to adjust it a little and also see if i could find out the hunting high speed problem. OK during high speed you can see air bubbles moving thru the fuel line (full tank of fuel) and causing fluctuations in the high speed running. OK problem identified. i can fix that! now on to the oil bath and the taboo idle mix screw! while at idle trim setting i turned the mixture lean little by little, the engine started to respond nicely, you could hear it running less laborously, less smoke, oil, smoother, calmer ect. i continued adjusting and lowering the throttle servo setting till this saito82 was just purring soooo low it was hard to beleive! i let it idle for what seemed to be 10 min to see if it would stall or load up. nope, it just sat there putt putt putt putt with no complaints. next time i'll grab my mini tach just to see how low. now on to the air bubbles during open throttle. any ideas out there? ricky.
MORE POWER SCOTTY!
I TELL YOU THIS ROCK MUST FLY!
       Post #: 481
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/26/2007 2:16:10 AM
JustErik
Status: offline
Ricky,
Good job on the idle adjustment. The needles are there to make adjustments. If the needs of the engine were not variable, the manufacturer wouldn't spend the money to design and manufacture them that way. As far as the bubbles, it sounds like an air leak somewhere or perhaps foaming fuel. I'd be inclined to install all new fuel line, check the tightness of the carb mounting bolts and give it another shot. I haven't heard of too many issues with foaming on this bird.
Just my thoughts,
Erik
"Toy airplanes are for people with more money than sense."
- My Ex-wife
(in reply to Ricky Blade)
       Post #: 482
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/26/2007 3:43:36 PM
malcolmm
Status: offline
quote:
ORIGINAL: JustErik
Ricky,
Just my thoughts,
Erik
I agree, the low speed mixture often needs adjustment. I only fly 2 strokes, so I don't know about 4 strokes - but on my OS engines, the low speed almost always needs a lot of adjustment (leaner). I have also been told to not touch the low speed. My 55 AX and 120 AX required quite a lot of leaning of the low speed mixture.
Malcolm
       Post #: 483
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/26/2007 10:06:31 PM
Ernie Misner
Status: offline
The needle story just got twisted (no pun intended a bit)...... the low speed needle IS set at the factory, but set for BEAK IN only. After that you are supposed to lean it out. It should say that in the directions as well.
Good that you got it purring. How does she fly?
Ernie
(in reply to malcolmm)
       Post #: 484
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 12:13:50 AM
Ricky Blade
Status: offline
well after the monster change in the 4cyc i'm sure going to try a little adjustment on my 2 strokes too... as to how she flys, i believe it's the easyest flying plane i've ever had. i'm the only limited link in the equation. apc 14x4w on the saito82 is the ticket for the reactor its just too much fun to fly every aspect envelope it is well suited for even beginners with only a little alieron training. slow, fast, vertical, nuts.... i do think after removing the fuel tank and finding nothing wrong with fuel lines it must be foaming the fuel. thinking using one of those clunks that look like a bunch of tiny brass beeds stuck together, maybe that might work better than just a clunk. ideas? ricky.
MORE POWER SCOTTY!
       Post #: 485
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 4:39:01 PM
jmehl
Status: offline
Just writing in to let everyone know I lost my reactor yesterday due to some sort of radio failure/glitch...make a long story short it was shot down. went nose first into ground at 60 mph+ and smashed into a million peices. Enjoyed this plane so much that I just ordered another. SO much fun to fly. I had a 72 and could of used a little more so I putting in my saito 82 and moving 72 to another bird. I installed a sullivan smoker on my last Reactor which was really cool.....can't wait for it to come in.
       Post #: 486
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 5:55:51 PM
JustErik
Status: offline
Sorry to hear about your loss, jmehl. I've noticed an occasional glitch with mine as well, and have read that others experienced the same thing. Before I fly mine again, I'm relocating the RX antenna to the outside of the plane. Something tells me being surrounded by three extra long servo leads is not good for reception.
- My Ex-wife
(in reply to jmehl)
       Post #: 487
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 6:30:49 PM
jmehl
Status: offline
JustErik
I lost so much confidence because of this I had to order the 2.4 GHz Radio....I did everything in my power to ellinate the glitches....but I would get them every so often randomly....I hope this helps.
       Post #: 488
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 6:48:23 PM
JustErik
Status: offline
jmehl,
I'd love to take the 2.4 plunge, but I'm not convinced it's a mature technology yet for our uses. Not to mention the fact that switching over everything I have would cost WAY more than I could possibly justify right now. I imagine that within 5 years or so, that will all change, but for now I'll just have to stick with 72 mhz.
Just out of curiosity, where was your RX antenna placed?
Erik
- My Ex-wife
(in reply to jmehl)
       Post #: 489
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 6/27/2007 6:57:01 PM
jmehl
Status: offline
I had it in several different locations incl outisde the fuse and along the servo wires in tube like you mentioned. Did not matter...still had very random glitches.
