JustErik
VA, USA Status: offline
Max, I haven't made any thrust line adjustments. I'm still a bit nose heavy, I just haven't had much opportunity to dial it in lately. What little time I do get to myself is usually spent on non-hobby activities. The header tank sounds like a simple, inexpensive and effective solution. I wonder why no one thought of it sooner? When I first finished up my Reactor, the all up weight was 5 lbs 10 ounces. Since then, I've removed the cowl (until I get the YS properly tuned), removed the wheel pants (bumpy grass field + wheel pants = no joy), and switched to the Graphtec gear. Right now it's 5 lbs 6 ounces, but after I reinstall the cowl, I think it will be right at 5.5 pounds, which might still be a little heavy for all out, balls-to-the-wall 3D, but it should be fine for a hack like me.
_____________________________
"Toy airplanes are for people with more money than sense." - My Ex-wife
