JoeyCoates
Hey idtbuzz, where exactly is your cg right now? I have an ax55 on mine and put the third flight on it today. So far I like it, but I do not have much wing rock, certainly a LOT less then I had on my Funtana X50. I am right about 4.75-5.0 right now and am about to order the graphtech gear to both get ride of the damn nose over tendencies (I have not yet, but I hate having to constantly be on my toes about it and I fly off of a kind of rough grass field)and to move the cg back a bit. I have to hold some down elevator when inverted and I would preffer it to be more neutral. To get my cg where it is I had to mount my 5-cell battery on the back of the plate in the rear of the fuse that acts as a tunnel for electric setup, it was a b!tch to get it in there, but I HATE to add weight. I also used a pico servo for the throttle, a 5625mg on the rudder, and 225mg's everywhere else. So far I am at 91.2 oz or 5.7 lbs and with a 12.25x3.75 it has outrageous vertical performance. I am however using a Tower 46 muffler and Morgan 25%, but that allows me to turn the APC at 14,600 backed off to 14,400 or so and I leave a nice faint trail. I am hoping to get to 5.6 or so lbs with the graphtech gear, it is already good but you just cannot get enough. By the way, do not expect it to fly like the G3.5 does, reality in this size plane is just different, it will rock some. I can do all sorts of crazyness with the Yak 54 on 3.5 that I cannot do in the real world, but it is a great tool. I have found though that the Reactor is the easiest plane to hover that I have flown.
