RE: Great Planes Reactor GP/EP 3D ARF .46-.70
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great Planes Reactor GP/EP 3D ARF .46-.70
Page: <<   < prev  27 28 [29] 30 31 32 33 34 35 36   next >   >>
Login
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 2:30:55 AM
outacntrl
Status: offline
zippy..servos 2 aile/2elev/1rudder/1throttle=6 i got a 55ax in mine and its unlimited the 70 4stroke would prolly be enough ?? not sure on that , i got just reg futaba 3004's all around and it works well flew it all summer w/o a problem ,motor mounts inverted i mounted mine @ 130 deg to get the exhaust stright out the bottom.. its a nice flying plane ok its a great flying plane hope that helps..tim
(in reply to Zippi)
       Post #: 701
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 3:52:33 AM
antiquefer
Status: offline
Flying the covering off mine ..literaly. Wish i had thought of that clearcoat idea. Ys 63 Hitec 225,s Where do you get the graph gear? How do you have to modify to install? antiquefer
(in reply to outacntrl)
       Post #: 702
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 12:23:32 PM
Zippi
Status: offline
antiquefer,
I found the Graphtech gear hear. Anyone have a pic of this gear on their plane?
http://www.graphtechrc.com/Secure/mall/maingear.asp
_____________________________
"It Ain''''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to antiquefer)
       Post #: 703
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 1:03:00 PM
DLEVETT
Status: offline
If you go back one page in the thread a couple of good pics are posted of the Graphtec gear.
Dave
(in reply to Zippi)
       Post #: 704
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 8:56:15 PM
MaxThrottle
Status: online
Hey Zip
Elevator servos:
Reactor requires two elevator servors mounted in front of the horizontal stab offset, staggered or tandom since the pattern like fuse narrows at that location.
I seem to remember one person in this thread coverted theirs to use one. Many needed more weight in the tail so having the two helped. Others pushed their batteries in the tail.
Engine position:
The plane is designed to have the engine inverted. Some have mounted thier horizontal. It took a little work to get the bugs out but I mounted a Saito 82 inverted. The new 55AX in my opinion would be the 2 stroke equal that works event better inverted.
I preferred the Saito since it allowed me to mount the tank at CG with the use of a small header tank. The Saito can draw fuel from ~ 12" where 2 stroke usually needs so assistance to affectively run the full range.
The pics I uploaded are old but at the time I turned the gear around to avoid the one issue with this design; the landing gear if positioned as directed tend to cause nose overs.
I later installed the Graphtech gear for weight reduction. Turning the gear around is cheaper and will do but I had two dead sticks on a tail wind, couldn't get it to turn around quick enough. With the factory gear I damaged the centrally mounted gear damaging the fuse. Did the similar from greater height with the graphtech and no damage all around.
I have this plane at the ready since its small, has a wide flight envelope and can be setup with Elevons/Ailevons and flapperon for even more fun.
Oh and iron down, glue, clear coat the covering. It delaminates quite a bit.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by MaxThrottle -- 2/8/2008 9:17:25 PM >
(in reply to Zippi)
       Post #: 705
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/8/2008 10:00:40 PM
Zippi
Status: offline
Thanks for the info guys. I to am looking for something small to throw in the truck to take to the field on those not so desirable days when you don't want to drag out the big stuff.
< Message edited by Zippi -- 2/8/2008 10:52:43 PM >
(in reply to MaxThrottle)
       Post #: 706
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/10/2008 12:39:00 AM
drumbum
Status: offline
Just ordered mine. Where is the E version thread? I ordered the combo setup with the rimfire and Pheonix 60 and for batteries flight power lite 3s 4250s in series. hitec 5245s all the way around. cant wait!
< Message edited by drumbum -- 2/10/2008 12:40:21 AM >
Lee Durham,
http://lee3d.tripod.com
(in reply to Zippi)
       Post #: 707
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/11/2008 3:15:11 AM
drumbum
Status: offline
WOW! what a lively thread. 24 hours no reply. I still havent found the electric thread if one exists it sure is hard to find
Lee Durham,
(in reply to drumbum)
       Post #: 708
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/11/2008 5:13:26 AM
MaxThrottle
Status: online
I don't recall a specific thread for this model setup in a E version. Most just add their brief comments in this or the build thread.
Have at it. I'd love to redo this model in a E version but I'd probably go with the 50-65-450 to turn a larger prop rathr than the recommended 42-60-800. The cost of the batteries is what still holding me back.
How much are the Lipos costing now?
Post your E setup or at least let us know if you start a new thread.
Cheers.
       Post #: 709
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/11/2008 12:54:28 PM
drumbum
Status: offline
I Ordered the stock setup noted above exept i ordered the flight power 4250 3s Lite packs at $124 a piece from tower. I ordered 4 (ouch) to make 2 packs . but plan on doing more than 1) 40 size electric. The flight power packs in 6s configuration is only 3 oz more than the recomended 3300 packs. I will try to shave that 3oz somewhere else hopefully.
Lee Durham,
       Post #: 710
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/11/2008 2:04:14 PM
cmala3
Status: offline
I'm wanting to convert this plane to electric myself. I was thinking about taking 4 of the Loong Max 2250, 25C packs , 2 connected in series, and then those 2 connected in parallel to 2 more packs connected in series. Those packs are about $30 each. So that would be $120 in LiPos for one flight. I'd like to know what some other people have done.
I have an OS 46 on it right now and it's not enough power to be fun for me so I was thinking of going electric instead of going with the Saito.
Craig
       Post #: 711
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/12/2008 1:18:41 AM
drumbum
Status: offline
Well I did the math on those packs. The great planes packs are 9.5 oz that they recommend so that is 19 total. those packs you are talking about will be after converting grams to ounces 27.23oz so your penalty will be 8.23 oz over the great planes 3200 packs. that is a half of a pound. plus to balance the packs you will have to buy 4 chargers and 4 balancers so there goes the money you saved. unless you want to do one at a time and spend about 2 1/2 hours between flights.
Lee Durham,
(in reply to cmala3)
       Post #: 712
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/12/2008 1:33:40 AM
cmala3
Status: offline
I'm not worried about charging them. Two Cell Pro's charging at 3C wouldn't be too bad but I hadn't done the math on the weight. 8 oz is a pretty big weight hit. I already have two of those packs that I use for other planes so I would only have to buy two more to get in the air.
       Post #: 713
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 2/12/2008 1:42:54 AM
dr
