RE: Great Planes Reactor GP/EP 3D ARF .46-.70
Tower Hobbies
Logged in as Guest
Users viewing this topic: jkovar, ceriverob
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great Planes Reactor GP/EP 3D ARF .46-.70 Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/12/2007 4:08:12 AM
Celidon
Status: offline
I'm a noob to mounting a glow engine. I am planning on using an Evolution 2-stroke. Will it be OK to mount it 45 degrees down?
< Message edited by Celidon -- 1/15/2007 1:37:20 AM >
(in reply to JustErik)
       Post #: 76
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/12/2007 1:03:14 PM
JustErik
Status: offline
Celidon,
Absolutely. In fact, that's how the manual shows a 2-stroke install. It puts the muffler on the bottom of the fuse and looks pretty clean. What size evolution are you using? I've read that those are pretty decent engines. It should do well.
Erik
_____________________________
"Toy airplanes are for people with more money than sense."
- My Ex-wife
(in reply to Celidon)
       Post #: 77
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/12/2007 5:28:22 PM
RobertC
Status: offline
Actually, Erik, there is padding UNDER the tank (and the velcro tie holds the tank snug against the padding). I guess that I could add some on the sides, but I've never had a problem doing it like this. My VenusII (see avatar) is the new home of my YS .91 and I did the same thing (again, stock tank mounted at C.G.) and have not had any problems.
       Post #: 78
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/12/2007 6:42:06 PM
JustErik
Status: offline
quote:
ORIGINAL: RobertC
Robert,
How very clever of you. I'm stealing all your ideas, you know. Thanks again for helping me out.
Erik
- My Ex-wife
(in reply to RobertC)
       Post #: 79
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/13/2007 4:04:14 AM
RobertC
Status: offline
Feel free to copy all you like Erik (they are probably not *my* ideas anyway ) I am glad that I can help. I should get the rest of the plane finished this weekend.
< Message edited by RobertC -- 1/13/2007 4:08:08 AM >
       Post #: 80
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/14/2007 2:37:28 AM
GarySS
Status: offline
Hello all Reactor owners,
Has anyone converted the standard rudder control to a pull-pull arrangement? If so, was it difficult to get the alignment correct and the fuselage hole spacing accurate, etc? What engine and where was the rudder servo placed? OR is the factory design adequate in this case? Thanks!!!
       Post #: 81
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/14/2007 7:44:02 PM
RobertC
Status: offline
Gary, I didn't attempt to mount the rudder-servo in a pull-pull arangement but I did notice that there appears to be pre-cut slots for the cable exits at the rear of the fuselage. Given the single plywood support in the center of the fuselage (where the rudder servo would go for this type of setup), it shouldn't be difficult. Question is, could you get the plane to balance like this? Are you thinking of using a *really* light engine?
I finished-up mounting the engine/muffler. I used the OS .70FS 90-degree elbow and the stock YS muffler. Worked-out perfect-- puts the muffler right where I wanted it. I opened-up the bottom of the cowl (for cooling as glow-plug access) as well as a bit more in front of the cylinder.
Only thing left to do is mount the battery/RX and balance. Once the snow clears (next weekend?) I should get a chance to fly!
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to GarySS)
       Post #: 82
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/14/2007 8:44:26 PM
Don M.
Status: offline
RobertC it kinda looks like we have the same tastes in planes and Avatars I to am going to be putting together a Reactor and YS .63 We must be related
Anyway my question is about your OS 70FS elbow. It looks like it fits with no mods eh ? Did you brace the muffler ? Do you think the vibration will cause a problem in the exhaust system now that it is so long. I have a similiar set up on my Venus II but I have a flex pipe between muffler and elbow.
< Message edited by Don M. -- 1/14/2007 9:44:55 PM >
I can only please 2 people every day and #2 just left.
       Post #: 83
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/14/2007 10:28:53 PM
GarySS
Status: offline
Hi Robert, If I bot a Reactor I would use my Saito .82 so the engine wouldn't be that light. I was just wondering what the rudder control options might be. Thanks. I have also noted that a lot of people are using metal spinners so they aren't necessarily cutting weight in that department. .........
(in reply to Don M.)
       Post #: 84
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/15/2007 7:20:46 AM
Ernie Misner
Status: offline
Thanks Bluehawk. I guess I just don't like having to put the glow igniter on from the bottom of the plane. What would the drawbacks be to mounting it horizontally in a Reactor? Throttle, cutting up the cowl more?
thanks!
Ernie
       Post #: 85
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/15/2007 5:42:36 PM
RobertC
Status: offline
Hi Don-- yeah, nice taste in planes that you have there! What can I say-- GP has some terrific models (and I have a soft-spot for pattern ships) and I love YS four-strokes!
Yes, the OS 90-degree elbow fit with no problem. I thought about using the Performance Specialties elbow but it says on the webpage that "these adapters do not fit the stock mufflers." Probably a generalization, and maybe it would fit the stock YS muffler (and certainly be lighter than the elbow/pipe/muffler setup that I am using). Best-case would be using the P.S. elbow/muffer combo but this was the least expensive way to go. The header-pipe will go fairly far into the muffler so I don't think that vibration will be a problem but you bring-up a good point. I'll certainly let you know if I find a problem!
Gary, I still have not had a chance to balance my plane but I suspect that you would need to locate the rudder servo in the rear for balance. I am sure that the .82 would be a great engine for this plane!
       Post #: 86
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/15/2007 6:22:55 PM
JustErik
Status: offline
Robert,
Regarding the Performance Specialties elbow, they do make one that fits the stock muffler; it's the same price as the one that only fits their muffler. I only know this because I mistakenly ordered the wrong one. Mr. Shadel and company, however, took care of me and now I have the correct one. I haven't weighed it or reached the point of installation yet, but it appears to be a quality piece.
- My Ex-wife
       Post #: 87
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/16/2007 1:27:39 AM
bluehawkbm
Status: offline
Ernie,
I agree that putting on the glow ignitor on and inverted engine is a bit of a pain. I haven't gotten around to mounting my motor or throttle sevo yet but it does look like a horizonal mounted engine would require cutting up the cowl quit a bit. If your main concern is the glow plug ignitor, why not use a remote ignitor. That would solve your problem. Tower Hobbies carries these. Here is the link
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD693&P=7
       Post #: 88
RE: Great Planes Reactor GP/EP 3D ARF .46-.70 - 1/16/2007 3:52:37 AM
Celidon
