sseward -> RE: Great Planes Reactor GP/EP 3D ARF .46-.70 (10/2/2008 1:02:15 AM)
quote:
ORIGINAL: Zippi sseward, How is that Keleo Pitts muffler working out on your Saito .82? How is the sound. Have any pics? Zippi, I just got it Monday and just got the cowl fitted last night. I had to cut just a small opening at the front of the cowl to accomodate the corner of the muffler, even after I ground the corner down a bit, but it still comes out of the cowl nicely. I may also trim a bit of the down pipes as they are quite long. I ran down to the shop and snapped a couple of quick pictures so you could see how it fits. I'm going to repaint it with high temp engine paint, then it will be ready to run! Since this does'nt go back into the tunnel, i'm going to mount my fueling port and remote glow adapter back there. As for the sound, obviously i haven't had it fired up with the muffler on it yet. I will say that it fits great and is beautifuly designed. If I don't get it maidened this weekend then I at least hope to fire it up to set the idle and engine cut-off. I'll let you know how it sounds! Steve
