RobertC -> RE: Great Planes Reactor GP/EP 3D ARF .46-.70 (1/29/2007 3:44:36 AM)
Well, we had a gorgeous weekend here in Seattle-- and I got the chance to maiden the Reactor! First of all, WOW! This plane is "locked-in" like you cannot believe. As smooth-- if not more-so-- than my VenusII! Didn't have a chance to try all-out 3D, but I guess that I am getting ahead of myself... First of all, I had to mount my 5-cell 1400 mAh pack in the VERY BACK of the hatch area! Even here, with the RX also in the rear, it barely balances at the recommended point. I guess that since my tank is on the C.G. this is fine. I didn't get a chance to weigh the complete airframe. I ran a few tanks of YS 20/20 through the .63 (full-throttle runs, 3-4 minutes each and 5 minute cool-down in between). After this, I was able to get a very reasonable idle. I was running an APC 11-7 (which was recommended for break-in) and, unfortunately, I forgot my "flying-prop" at home. I was almost worried that the 11-7 wouldn't get the plane off the ground. Boy, was I wrong! Still very rich, and running the too-small APC, I opened-up the throttle and watched the plane race down the runway. It easily took to the air and required only a small amount of trim to fly straight as an arrow. And that is exactly what it felt like I was flying! The YS .63 is plenty of power for this airframe-- it was unlimited even as rich (and under-propped) as it was! Roll-rate, as anybody who has seen the size of the ailerons will guess, was like a drill... on low-rates! Snaps were quick and felt like they stopped immediately on releasing the controls. Made a few knife-edge passes-- required very little rudder and almost no coupling! I pulled the plane into a hover-- fully expecting the plane to fall-out almost immediately with that tiny prop-- and it was rock solid! Probably easier to hover than my U-Can-Do! First landing was an absolute breeze. The plane is very "slippery" (again, probably due to the thin airfoil), but I was still able to slow enough for an easy landing (even at the fast idle of the still-new Y.S.). With all this well-deserved praise, I have to mention the one minor problem that I had: the plane has a tendency to nose-over on taxi and landing. It never *actually* nosed-over, but I had to catch it a few times (and I had to hold full-up elevator-- on high-rates-- to keep the tail on the ground). Note that I am flying off grass. This minor issue aside, I highly recommend the plane! Everybody liked the look of the plane (color and shape), and loved the way it flew! I am looking forward to putting a "real" prop on and seeing what else it can do.
