Ernie Misner
WA, USA Status: offline
Celidon, going back to post #152 where you show the pictures, if you are still using the non-stock angle on the right hand ele servo, Bluehawk is right. Both servos have to be set up with the same exact geometry to get equal throws. With enough channels on a computer radio, you might be able to correct that, but then you could use the stock arrangement too. Why not use the stock setup, but with a Y cord if you are limited with your radio like I am. Ernie
