Montague
Personally, I always throw left-handed underhand. But I don't just flick it, I give a step or two and a good, hard arm swing, esp when throwing in a tail wind. (I was flying over the weekend with about a 10mph dead tailwind on launch, no problems at all). Part of the reason I use this throw is to avoid having to juggle the plane and transmitter while the engine is running. I find it awkward to get under the plane and get it up over my head. Now, there are guys who basically just let go of the plane, or just use a wrist flick, and let it fly away. That works most of the time, but can be a problem, so I don't do it. I also design my planes to have a good hand grip when held from the top, and use no-skid on the scale fuses. Some planes you just can't throw underhand since there's nothing to grab. And there are some planes that don't work overhand either. no matter which technique you use, the key is to get airspeed. Throw basically level or slightly nose up.
_____________________________
Kirk Montague Adams RCCA 560
