tIANci
Joined: 1/15/2004 From: Kuala Lumpur, MALAYSIA Status: offline
The MJ is a lovely flying plane, I never flown it with the stck motor but I guess it will do about 40 mph only giving a lot of fun as its such a smooth plane to fly. I am on No. 4 now and I went through 3 set ups: ZAGI Tazz 10 turn motor with CC25 and El Cheapo Chinese made 30A ESC Its a 400 sized brushless of about 2,800 KV. Just about right, its fast enought to enjoy but not to a point where you are not able to relax. I used the Gunther 5x5 prop (23,000 RPM), it was the best, better than APC or Graupner CAM props. I think the plane was doing about 70 mph. Was nice to fly. Feigao 3,600 KV motor, HiModel 60A ESC This is a 400 sized motor but about just under 1/2" longer and its heavy. I used an APC 4.7x4.25 (30,000 RPM). Its superbly fast but the AUW was a lot more, I needed bigger batteries as I was pulling about 36A or so ... I believe the plane was touching 100 mph. Problem was my GWS Naro servos were not good enough. It was all about speed and nothing else. Align 2,800 KV outrunner, El Cheapo Chinese 30A ESC Very nice set up, the motor is really light and my FP 1,800 batts were starting to warm up only. I used the APC 4.7x4.25 getting about 22,000 RPM. It flies 'slow' compared with the Feigao but the plane is much more fun to fly. With your 2S set up it will not be fast but I bet you can easily hand launch the plane, I need a bungee.
_____________________________
Its nice to be important, but its more important to be nice ... Revver Brotherhood No. 232
