ALUMINUM Beer BOTTLE pipe???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> ALUMINUM Beer BOTTLE pipe???
Page: [1]
Login
ALUMINUM Beer BOTTLE pipe??? - 7/3/2006 4:27:06 AM
xlr82v2
Status: offline
Hey guys,
Has anyone out there made a pipe out of one of the new Budweiser Aluminum Beer Bottles?
I'm thinking of making one up for use on a ST G90...
If anyone's already done it, how did it perform?
Thanks in advance,
Brian
_____________________________
Brian
       Post #: 1
RE: ALUMINUM Beer BOTTLE pipe??? - 7/4/2006 7:54:07 AM
xlr82v2
Status: offline
BTT...
Brian
(in reply to xlr82v2)
       Post #: 2
RE: ALUMINUM Beer BOTTLE pipe??? - 7/4/2006 12:30:35 PM
w8ye
Status: online
Brian
We havn't seen anything about the new type bottle in this forum.
Make one up and tyell us about it.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 3
RE: ALUMINUM Beer BOTTLE pipe??? - 7/4/2006 5:20:59 PM
Ernie Misner
Status: offline
What size is that can??? I want to see one.... My mousse can is working good on the G90. It is about 6 1/2 x 2". Using the 7/8" diameter Mac's header (not the 3/4" one that WILL fit the 90 but is intended for the 60 and 75 ST's). Have only shortened the header by 1" so far. They are about 9" in length stock, could go shorter for high end, but it pulls like a tractor and still has good top end this way.
Ernie
[image][/image]
Click to see fullsize image.
Click for fullsize
< Message edited by Ernie Misner -- 7/4/2006 5:22:54 PM >
(in reply to w8ye)
       Post #: 4
RE: ALUMINUM Beer BOTTLE pipe??? - 7/4/2006 5:30:35 PM
Kmot
Status: offline
It's a 16 ounce bottle so it will probably be quite large and heavy:
But it would look cool.
DRILL BABY DRILL!!!
(in reply to Ernie Misner)
       Post #: 5
RE: ALUMINUM Beer BOTTLE pipe??? - 7/4/2006 6:44:40 PM
MOTORMAN37
Status: offline
I have had my hands on quite a few of these, but I think it is double walled and to heavy, but it sure keeps the bear cool.
(in reply to Kmot)
       Post #: 6
RE: ALUMINUM Beer BOTTLE pipe??? - 7/5/2006 4:19:04 AM
xlr82v2
Status: offline
Yep, the one I have is similar to the one pictured above... except it's Bud Select...
Actually, it's quite light.
I haven't dissected one yet, but it does not appear to be double-walled. My specimen has a small dent in one side, and the dent is just as evident inside as it is outside... If it is double walled, then the clearance between the inside and outside is very small.
The aluminum bottle measures 9.5 inches tall, and 2 5/16 inches in outside diameter at the base. The neck opening measures 13/16 inside diameter, and 1 inch outside diameter.
It's nearly the perfect shape for a pipe ... I'm just hoping it isn't too large to work on my ST G90...
Click for fullsize
Brian
(in reply to MOTORMAN37)
       Post #: 7
RE: ALUMINUM Beer BOTTLE pipe??? - 7/5/2006 4:38:54 AM
xlr82v2
Status: offline
More technical info on the aluminum bottle:
http://www.aluminum.org/ANTemplate.cfm?IssueDate=05/01/2005&Template=/ContentManagement/ContentDisplay.cfm&ContentID=8468
It's an interesting article... and it only says that there is 3 times the aluminum in these bottles than in a regular beer can. This is also printed on the bottle itself. It does not say anything about it being double walled or anything exotic like that...
I wish I had a good scale to weigh this thing on... I'd say it weighs about 2 ounces approximately, with my calibrated elbow... It really is fairly light, very similar to a mousse can.
Brian
       Post #: 8
RE: ALUMINUM Beer BOTTLE pipe??? - 7/5/2006 4:53:15 PM
ifixairplanes
Status: offline
If I'm not mistaken I think those bottles have a liner made of some sort of plastic. The liner keeps the aluminum taste from getting into the beer.
I still like the taste of glass bottles better
"We request that model aviation not be innocently sucked into a black hole of regulation..."
       Post #: 9
RE: ALUMINUM Beer BOTTLE pipe??? - 7/5/2006 8:27:50 PM
Ernie Misner
Status: offline
Very interesting! Maybe someone will make one that is a little narrower which would be good, not quite so draggy. The "neck" makes a great divergent cone for the expantion part of the chamber in a resonant system. The neck size might be fine for JB Welding a 7/8" thinwall tube into (right size for the G90 header coupling)
The mousse can arena is expanding!
Ernie
(in reply to ifixairplanes)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU5
