daven
MN, USA Status: offline
Grubbs, In your weather, it may be tough to spin the 8.8"x9.25. The one prop you can never go wrong with is the 8.8" x 8.75 this prop will work in just about any condition. It is not quite as fast as the 9.25, but it makes up for it with a faster first lap and does not lose as much speed in the turns. My engines are competitive with most out there, and on average, my good engines peak about 19,600 with the 8.75 and only 19,300 with the 9.25. Thats the top rpm after a pinch of the fuel line. IF I can't get 19,300 with the 9.25, I will run the 8.75. I rarely change top ends, but have been cleaning carbon off the top of the piston and head after every 10-15 runs.
_____________________________
Dave Norman klasskote.com supertrc.com
