what fule line to replace the vul can stock line ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> IRC Racing Support >> what fule line to replace the vul can stock line ?
Page: [1]
Login
what fule line to replace the vul can stock line ? - 7/3/2006 3:17:23 PM
rcworld2000com
Status: offline
what fule line to replace the vul can stock line ? the stock line seems smaller than what a 1/10 nitro uses is this so?
if so what size do i need to get from my lhs ?
also mind crime are the 2 speeds in stock yet ???
Thank you
       Post #: 1
RE: what fule line to replace the vul can stock line ? - 7/3/2006 9:43:49 PM
Mindcrime
Status: offline
No 2 speeds yet,
I use the same fuel line on my Vulcan as I do on my 8th scale buggy.....not sure what the size is, but any normal fuel line should work...
_____________________________
IRC Racing
(in reply to rcworld2000com)
       Post #: 2
RE: what fule line to replace the vul can stock line ? - 7/8/2006 7:16:32 PM
wesjr
Status: offline
I had problems with the stock line cracking at the muffler so I replaced with stock line from the hobby store. It would slip off the muffler when I installed the body so I inserted a spring from a ball point pen in the tube to keep it from kinking and tiewrapped it on using a very small zip tie. This seems to have solved this problem.
(in reply to Mindcrime)
       Post #: 3
RE: what fule line to replace the vul can stock line ? - 7/10/2006 11:11:28 AM
HYPERGOBLIN
Status: offline
Standard 2.5mm I.D fuel line (eg: for 1/8 scale) will not properly fit the fittings and may leak.
I used Dubro fuel line blue (1.5mm I.D) for small plane engines, it fits right, thicker and more durable than the standard line.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD727&P=M#tech
I have even been able to stretch this line to fit a small fuel filter. Good luck
(in reply to wesjr)
       Post #: 4
RE: what fule line to replace the vul can stock line ? - 6/1/2008 8:39:54 PM
nitrovulcnse
Status: offline
i have noticed that the stock fuel line is very brittle and easy to break, so i just went to the hobby shop with one of the little brass fittings from the car and chose a more durable tube. realy, you just have to see what works. hope that helped
(in reply to HYPERGOBLIN)
       Post #: 5
RE: what fule line to replace the vul can stock line ? - 6/1/2008 8:41:06 PM
nitrovulcnse
Status: offline
oh and by the way, i am using an airplane fuel filter just because it fitted.
(in reply to nitrovulcnse)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
