diamondave
AZ, USA Status: offline
quote:
ORIGINAL: chuck993 I've been looking thru this thread for awhile, is there any info on how to do the basic Knife Edge? I am using a Ultra Stick 60, with flaps and aielerons and mixing. i dont use mixing for my knife edge, you can but it would be ele, and some ail to hold the correct position, you dont want to use flaps or anything like that, i roll to one side, i go left from a right to left pattern, it feels more comfortable to me that way, you can do it either way, having the canopy towards you is more comfortable, you can go the other way if you like, once you get it down i have done big figure eights in a knife edge, kinda cool looking but tricky to hold it in as you go around a cirlce, anyway, roll to one side and stop it there, feed in opposite rudder, if you roll left, you will need right rudder to hold the plane level, the more rudder you give the more it will pull either towards the gear or canopy, planes are different, mine goes to the gear with more rudder, so i add up ele to keep it from tucking, you also may need to give a little left aileron because the rudder may roll it back to level, maybe someone else can explain it better, i am not sure about the ultra stick for doing it either, it may be a difficult plane to learn it on, your rudder may not be enough and it may really want to level out with rudder input...try it on a sim if you have one
