RE: HOW-To..3D maneuvers
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes Ryan STA-M ARF - 1.20 Getting RARE - ARF
Seller:  aubreyinhouston
Details:   $450.00   |  6/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> RE: HOW-To..3D maneuvers
Page: <<   < prev  5 6 7 8 9 10 11 12 13 [14]
Login
RE: HOW-To..3D maneuvers - 11/10/2007 2:29:46 AM
Stick40
Status: offline
Ultimates are a little harder to harrier because the wing loading is higher with the skiiny little wings on it. I think the best plane to harrier in is a Kadet Senoir with a 70 4 stroke in 20 mph winds
Stick 40
< Message edited by Stick40 -- 11/10/2007 2:30:51 AM >
_____________________________
92% of teens have switched to rap music if you are part of the other 8% put this in your sig
I am the Master of Puppets
(in reply to AvoidingExpert)
       Post #: 326
RE: HOW-To..3D maneuvers - 11/12/2007 5:38:37 PM
Grrrrrumpy
Status: offline
My Last Parachute:
A U-Can-Do-3d .46 with a 2-stroke SK .80
Straight down, pulled full up elevator, plane snapped to level flight, but the engine
continued going straight down. Without the weight of the engine, the plane did a
fluttering, falling leaf impression.
I quit doing parachutes...
(in reply to Stick40)
       Post #: 327
RE: HOW-To..3D maneuvers - 11/16/2007 4:42:48 PM
RamboSmurf
Status: offline
Great Forum!!!
MikeEast Your the best!! You started this and Thanks to all for the info. I have been trying to learn this 3d on my own (nobody else around) and this has been a grreat help. As the attched pictures will show, I still need lots of practice (plus a new plane). But this info will help as I have already noted some things I did wrong.
Personal note for all -- Guide wires have a very strong pulling force that attracts flying objects.
Click to see fullsize image.
Click for fullsize
Click for fullsize
OK, Invert-Reverse controls-Now when it comes at me WHAT IS IT? Crap-They can break in that many parts.
(in reply to Grrrrrumpy)
       Post #: 328
RE: HOW-To..3D maneuvers - 11/17/2007 6:16:14 AM
pizza
Status: offline
best advice I ever got for rolling harriers was to practice and learn these on a slope with a glider first. it is too easy to bail out with power and never learn anything. learning to control an airplane without an engine is criticle for 3d. on a slope you can serf the air waive while rolling back and forth accross the slope face in reletive safety - with lots of up air lift you can roll stationary standing directly behind airplane for hours and hone your skill. the airplane will "settle in" to diff angles of attack to compensate for diff wind speed for you to maintain stationary flight while rolling. this frees you up to just learn combinations of elev/rudder even some more or less constant ail to bend the airplane to the left - right - away or back towards you. when you roll thru both knife edges with a thin glider with no side area on a slope they drop like a rock requiring you to master big rudder stick movement to the point it becomes second nature - you always need more knife edge rudder movement than elevator for rolling harriers. too many 3d guys never learn to control an airplane flying on control surfaces and using surounding air rather than an over powered engine with an on off switch and too much elevator. when I transitioned from slope to power suddenly I was putting in just the right amount of throttle not too much or too little to just hold the airplane up without trying. after many hours of watching my airplane in a constant stationary roll on the slope I became relaxed as my wing would nearly touch the ground while rolling at the power field. too many pilots panic, freez, overeact, bailout when their planes are rolling a few feet off the ground and they never get over this or improve their skill.
funny how you can interview a skydiver and he will say every jump is scary anything can go wrong - this is how it will always be. then interview the skydiver that has spent time practicing in a wind tunnel on the ground in relative safety and he will say it is like walking accross the street no big deal.
(in reply to Cambo)
       Post #: 329
RE: HOW-To..3D maneuvers - 11/18/2007 5:55:58 AM
8KCABrett
Status: offline
In the full scale Pitts type aircraft that is pretty much the way that you do a knife edge spin. Hammerhead left, then right rudder after about 90degrees of rotation and full forward stick. Aileron is held to the right (and it's already there in a hammerhead anyway). Aileron is variable through the spin and requires constant adjustment to keep it dialed in, and it takes practice to get them to really tighten up and stay KE, and because gyroscopic action of the prop isn't helping to keep the nose high, these are "accelerated" KE spins. The biplanes do not really like KE spins much when done right wing low though, and many Pitts pilots thought that you simply couldn't do them in the Pitts, but that is because they were trying them as the monoplane pilots do them. Which brings me to the comment that I wanted to add initially, which is my take on the best looking knife edge spin entry, as I do it in full scale monoplanes, and the method I use in my RC aircraft as well.
Pull to vertical as in a hammerhead, when you want to initiate thespin, reduce power to around 25% (in most of our 3D planes that's enough throttle for a goood pivot, if you are REALLY overpowered or underpowered it will vary of course-the objective is to have just enough airflow over the tail, but still are large power reserve available), kick full left rudder to pivot and perform a normal hammerhead, except that instead of stopping the pivot after 180 degrees of yaw, you keep the full left rudder in, and at around the 150 degree point of the pivot as the nose nears the vertical downline start adding throttle to around 50% (or however much you can carry without flying out of the figure). This blast of power will drive the pivot more strongly past the 180 degree point, and back up towards the "2nd horizon." As the yaw rate starts to decrease (around the 240 degree point) you are ready to come in with full forward stick and some left aileron. . .once in the spin, you should be hold full left rudder, full forward elevator, and whatever aileron it takes to keep it KE.
Depending on the aircraft, kicking just a moment earlier than you would for a hammerhead may help the pivot go beyond 180 degrees. Also, the amount of throttle you need to add back in towards the end of the pivot to drive the spin will depend on the model and powerplant, and once you get a nice KE spin going you can practice adding throttle to see how much you can add before it wants to spiral out of the spin, it may not do this, and in that case, going to just about full throttle will help to really bring the nose up towards the horizon, and to get a nice tight spin right around the CG. In full scale aircraft, and large scale RC models the gyroscopic action of the prop is important for driving the nose up, so right wing low, and forward stick is the ideal. (The same goes for flat spins, if upright, use left rudder, if inverted use right)
And now some really cool videos on the subject:
14 seconds into this video is an excellent helmet cam view and an external view of a KE spin in an Edge540, oh and at the very end is an awesome view of another KE spin!:
http://www.billsteinairshows.com/Video/20062007Video/BSA20062007DemoMedium.wmv
At 3:15 in the 2005-2006 Demo video (and the video archives page) there is a helmet cam view and an external view of a longer KE spin. There is lots of cool tumbles, snaps, torque rolls, tailslides and such in Bill's other videos so check them out at: http://www.billsteinairshows.com/BSADemoVideo.html
,Go here to see the KE spin in the Pitts S-2C from a cockpit mounted camera:
http://www.tutimaacademy.com/video_spin.html
quote:
ORIGINAL: Pat Roy
Another entry for the KE spin, but it works better for the larger planes with more tail areas.
Go vertical into a hammerhead. Carry just a touch of throttle so you won't make a full stop at the top. Just before the stall at the top go to max high rate rudder either direction. As the plane rotates to the horizontal on the rudder input, reverse the rudder to the top, add full up or down high rate elevator, depending on the desired direction of rotation. Hold the top rudder and max elevator, maintain neutral ailerons and throw power at it to get the rotation going. Use ailerons to counter roll coupling.
Bubba, just found this thread for the first time, what a great idea!!
< Message edited by 8KCABrett -- 11/18/2007 8:20:00 PM >
-Brett
Northern California Aerobatic Club:http://www.iac38.org/
(in reply to Tired Old Man)
       Post #: 330
RE: New Video: HOW-To..3D maneuvers - 11/23/2007 9:47:27 PM
porkboy125
Status: offline
hey guys i am wanting to start to learn how to fly 3D i have been looking at a Extra 260 50 - 53.5" 3D and puting a .61 supertiger in it does anyone know if that will do most 3D manuvers?
(in reply to bubbagates)
       Post #: 331
RE: HOW-To..3D maneuvers - 4/28/2008 1:25:26 AM
Cambo
Status: offline
Hi everyone. What is the best way to enter a low hover without the planes momentum moving it higher into the air?
(in reply to porkboy125)
       Post #: 332
RE: New Video: HOW-To..3D maneuvers - 4/28/2008 1:44:49 AM
AirWizard
Status: offline
quote:
ORIGINAL: porkboy125
You should have a 2 to 1 thrust to weight ratio for good 3D
David
____I'm having a Yak Attack_____
       Post #: 333
RE: HOW-To..3D maneuvers - 4/28/2008 1:52:04 AM
AirWizard
Status: offline
quote:
ORIGINAL: Cambo
How about a harrier into hoover or using a tail slide into a hoover.
David
(in reply to Cambo)
       Post #: 334
RE: HOW-To..3D maneuvers - 4/28/2008 2:12:07 AM
Doppelganger
Status: offline
quote:
ORIGINAL: AirWizard
quote:
ORIGINAL: Cambo
I was going to say the same thing. With practice you can learn to transition from a wall into a hover without gaining a lot of altitude. But wizards' suggestion is spot on.
Steve
I refuse to grow up. And as long as there are planes to fly, I won't have to!
(in reply to AirWizard)
       Post #: 335
RE: HOW-To..3D maneuvers - 4/28/2008 2:28:46 AM
RC MANIAC119
Status: offline
quote:
ORIGINAL: Cambo
The easiest way...is to NOT have the momentum when you start, and enough elevator to pop it nose up!! really simple...when you get the "hang" of it.....no pun intended. LOL
RC MANIAC-PRO BRO 1900-AMA# 95841
(in reply to Cambo)
       Post #: 336
RE: HOW-To..3D maneuvers - 5/20/2008 4:26:42 AM
perkinsm
Status: offline
quote:
ORIGINAL: AirWizard
quote:
ORIGINAL: Cambo
Thats how I do it,, works great
       Post #: 337
RE: HOW-To..3D maneuvers - 5/20/2008 5:00:26 AM
Cambo
Status: offline
Ya, just haven't goten confident with those low hairiers yet. Really have to practice that. My walls look goood but i always seems to have a little upward speed after i stop. I could have something to do with a 50cc gasoline in a 13# plane .
I am so close to on the deck 3d. Just not quite there.
(in reply to perkinsm)
       Post #: 338
RE: HOW-To..3D maneuvers - 5/31/2008 8:34:03 PM
F-22
Status: offline
Nice video.
If you eat your own stomach, where does it go?
(in reply to Cambo)
       Post #: 339
