RE: HOW-To..3D maneuvers
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: HOW-To..3D maneuvers
Page: <<   < prev  8 9 10 11 12 13 14 15 [16] 17   next >   >>
Login
RE: HOW-To..3D maneuvers - 1/10/2009 10:45 PM
AirWizard
Score: 100
Last Login: 3/12/2010
Status: offline
I have had problems with the 225 mg.....wouldn't hold center
_____________________________
David
____I''m having a Yak Attack_____
Hide Signatures
(in reply to bfreee)
       Post #: 376
RE: HOW-To..3D maneuvers - 1/11/2009 12:34 AM
McChiken
Score: 100
Last Login: 2/19/2010
Status: offline
bfree,
You might be using a servo for the wrong application too . Just cause a micro servo says its good for 60 oz of torque doesn't mean it was intended for a 70" wings aileron .
Just as a HS-225mg or 85mg is a better choice than a karbanite for throttle because of vibration issues and constant ramping up and down for 3d flying .
Hide Signatures
       Post #: 377
RE: HOW-To..3D maneuvers - 1/11/2009 12:45 AM
diamondave
Score: 107
Status: online
the last hitech servos i bought were 7985's, the box says 3 metal gears and a karbonite gear, so i dont believe there is any plastic involved at all
Hide Signatures
(in reply to McChiken)
       Post #: 378
RE: HOW-To..3D maneuvers - 1/11/2009 12:56 AM
bfreee
Score: 100
Last Login: 7/8/2009
Status: offline
Thanks guys,
I didn't mean to make everyone think this was a real problem. I haven't had this happen much since I learned what not to do.....Like crash or hit my rudder on the door frame on the way through the door. On occasion it still happens and maybe the alternative would be worse ie, a broken control surface
I didn't mean to drag you guys sort of off topic.
Just wondering if anyone else had info about servos with truly all metal gear construction. I had bought these years ago under the advice of my friend Cliff Whitney of Atlanta Hobby where I bought the plane and what others were using at the time here on RCU. They have served me well. That one gear can be fragile if you're not careful. If I had to buy a micro now I'm not sure what I'd buy. Thats why I was wondering about the construction.
Good luck, Bruce.
Hide Signatures
       Post #: 379
RE: HOW-To..3D maneuvers - 1/11/2009 1:08 AM
bfreee
Score: 100
Status: offline
Thanks Dave,
That's good to know. The karbonite is 4 times stronger than the standard plastic, if I recall correctly. I have several 65hb's. I haven't had anything happen to them. I'll research this some so you guys can get back to what you'd rather talk about. I feel I'm being a distraction to you all. Thanks again.
Bruce
Hide Signatures
(in reply to diamondave)
       Post #: 380
RE: HOW-To..3D maneuvers - 1/11/2009 1:45 AM
diamondave
Score: 107
Status: online
i do remember when the first karbonite final gears came out, they were all hyped and supposed to be great, i broke two of them very easy, i bumped the ele on my old funtana and it broke a tooth out, then after that i purposely moved my rudder back and forth by hand rather quickly, at the end rotation as i changed direction, that broke, so i can see how you can break them by bumping them, but i think they changed something since then, and ive never heard of one internally breaking like on the final metal gear servos, ... its all related to the topic, kinda sorta, servos are a very big part of 3d planes
Hide Signatures
       Post #: 381
RE: HOW-To..3D maneuvers - 1/11/2009 2:20 AM
McChiken
Score: 100
Status: offline
I'm putting a Mojo together now and was thinking HS-475's or DS-821's . Anybody have horror stories on either of these . I'm thinkin more of 475's cause I have a gift cert. for Tower . And I was thinkin HS-85mg for throttle . I have only used 965mg , 65hg and 55's in Hitec's and never used a spectrum but I heard there real good. I could care less about the digital thing . Never have noticed a difference other than digitals are crybabies and current suckers . Probly cause I'm a rookie to 3d nitro .
Hide Signatures
       Post #: 382
RE: HOW-To..3D maneuvers - 1/11/2009 11:26 AM
airwayman
Score: 100
Last Login: 2/25/2010
Status: offline
quote:
I would hate to lose a $3,000.00 plane to a bad servo.
quote:
I lost a plane to cheap servos years ago. A total loss....all except for a couple of cheap servos. It was a 33% Extra I built and painted from a kit, it took months to complete. I got four and a half flights out of it. That day I learned the hard way about using cheap servos. One of my favorite questions to ask is "what's the worst that can happen?" Using cheap servos the answer is you risk a total loss. Except for a JR8711 on the rudder of my H9 Sukhoi (411 oz. in. torque) I use Hitec 5955TG and the newer 7955TGs (both have 333 oz. in. torque @ 6V). I have never stripped a gear and although I own 25+ of these servos, I've never taken one apart. Last summer I lost a 2.6m Comp ARF Extra in a bean field. We looked for days but didn't find it (the beans were chest high). It stayed in the beans, rain, sunshine, heat, cold and all until fall when a buddy found it. The plane and servos were in the beans two months. I sent all 8 Hitec 5955s back for possible repair. Hitec installed new pig tails, ran diagnostic checks and sent all 8 of them back. Total charge was $48.50 or so. They are now in my 35% Hangar 9 Extra 260. I have several of the old JR 4721s, which have plastic gears, I use them on throttle. Airwayman
Forward is down, back is up and further back is....down?
Hide Signatures
(in reply to AirWizard)
       Post #: 383
RE: HOW-To..3D maneuvers - 1/11/2009 3:37 PM
stryker11
Score: 100
Status: offline
Would you want to tell us what kind they were?, Maybe some of us could avoid such a disaster.
Hide Signatures
(in reply to airwayman)
       Post #: 384
RE: HOW-To..3D maneuvers - 1/12/2009 10:52 AM
airwayman
Score: 100
Status: offline
It's been a long time ago, 20 yrs. or so. I think they were JR4721s or perhaps a Futaba 131s? ...I'm sure they were ball bearing servos. They weren't cheap servos, just had plastic gears. I do know what happened, and it wasn't entirely the fault of the servo. Back then most of the control horns were made of white colored nylon or something similar. Ball links were for cars but were beginning to be used by R/C airplanes. For the first time, I used ball links on the ailerons with nylon control horns. At the time I didn't realize the nylon type control horns are best suited for use with a clevis which centers the force from the servo directly forward and aft on the control horn, NOT from the side, like a ball link (especially when you use the cone spacer which moves the ball link even farther away from the side of the control horn) . Twist one of the nylon horns sideways and you'll immediately see what I'm talking about.....they flex sideways, but not fore and aft. (I'm not talking about the newer heavy duty control horns nowadays, I'm referring to the light duty kind. Back then there were no heavy duty horns that I knew of.) Anyway, coming out of a loop and gathering speed, all of a sudden there was a loud BZZZZZZZZZ, and parts starting coming off the plane. It rolled to knife edge, turned 45 degrees, hit he ground and exploded. Investigation revealed the lack of rigidity of the nylon control horn allowed the right aileron to flutter. This immediately started breaking the plastic gears in the servo which allowed the aileron to flutter even more. It shook the plane so violently in a milisecond, it stripped the gears on the left aileron servo as well. The right aileron fluttered so bad it ripped the control horn out of the aileron and the aileron began to shed parts. All of this happened in a split second. I learned two very valuable lessons that day. It was Thanksgiving, I had a new plane, the weather was perfect. My loving wife said "oh, honey, I know your dying to fly (little did she know) why don't you go get in a few flights on your new plane while I fix dinner?" I went to the field, there was nobody there so I flew by myself. When I lost control, the plane turned towards me. It came very close to ruining my Thanksgiving dinner....or worse. This was before cell phones so there was no help available if I had been hurt. We learn from our mistakes. Nowadays, I don't fly by myself, I always have a cell phone and I use heavy duty horns and SWB servo arms. Airwayman
Hide Signatures
(in reply to stryker11)
       Post #: 385
RE: HOW-To..3D maneuvers - 1/13/2009 3:36 AM
McChiken
Score: 100
Status: offline
R's not to ask Why .
Hide Signatures
       Post #: 386
RE: New Video: HOW-To..3D maneuvers - 2/5/2009 9:50 AM
hollowman
Score: 100
Last Login: 12/9/2009
Status: offline
sefc
Hide Signatures
(in reply to AeroDave)
       Post #: 387
RE: New Video: HOW-To..3D maneuvers - 2/5/2009 9:53 AM
hollowman
Score: 100
Status: offline
Hide Signatures
       Post #: 388
RE: HOW-To..3D maneuvers - 2/22/2009 10:40 PM
diamondave
Score: 107
Status: online
here is a link to me trying my hand at hovers
http://www.youtube.com/watch?v=1Ya7xJx73JE
Hide Signatures
(in reply to hollowman)
       Post #: 389
RE: HOW-To..3D maneuvers - 2/23/2009 1:51 AM
RC MANIAC119
Score: 100
Status: offline
Nice hovers.............I only have one suggestion for you
LOWER!!!!!
RC MANIAC-PRO BRO 1900-AMA# 95841
Hide Signatures
       Post #: 390
RE: HOW-To..3D maneuvers - 2/23/2009 3:17 AM
diamondave
Score: 107
Status: online
im not sure how much lower i can get without touching, too dusty at that site ....will try to get another vid of some more flying at my regular field one of these days, my camera man missed all my flat spins and KE figure8's and stuff, he was either way too far or too close, so i cut alot out, will find someone else to work it next time
Hide Signatures
(in reply to RC MANIAC119)
       Post #: 391
RE: HOW-To..3D maneuvers - 2/23/2009 10:27 AM
airwayman
Score: 100
Status: offline
Dang dude, you need to water your lawn. What engine is that? Sounds like you got it tuned to a gnat's patutte. Airwayman.
Hide Signatures
       Post #: 392
RE: HOW-To..3D maneuvers - 2/24/2009 12:40 AM
diamondave
Score: 107
Status: online
that is a field i only go to once in a great while, i fly mainly at a regular site with paved runway, bathroom, soda machine, pavilians, all the good stuff, i went there cause my field was closed to a work party, and i knew i could do anything i want there, ie..walk with the plane out in the open, no stands to stay behind, or noone to tell me too for that matter ....but its too dusty to go all the time with that plane anyway, plus not having any of the accomidations kinda stinks, especially now that its going to be getting warmer here real quick
its a zdz100, just about done with the 4th gallon of break in oil....runs good to me already
Hide Signatures
       Post #: 393
RE: HOW-To..3D maneuvers - 2/24/2009 12:42 AM
diamondave
Score: 107
Status: online
quote:
ORIGINAL: airwayman
i havent heard it put that way before
Hide Signatures
       Post #: 394
RE: HOW-To..3D maneuvers - 2/24/2009 10:53 AM
airwayman
Score: 100
Status: offline
quote:
ORIGINAL: diamondave
quote:
ORIGINAL: airwayman
What gnat's patutte? This is a public forum, I didn't want to use the A word. ZDZ 100 sounds good, great throttle response. As you know, that is essential for hovering/torque rolls. What does your plane weigh without fuel? Where is this flying site with the paved runway, soda fountain and did you say...swimming pool? Airwayman
Hide Signatures
       Post #: 395
RE: HOW-To..3D maneuvers - 2/24/2009 11:52 PM
diamondave
Score: 107
Status: online
www.timpa.org ...thats my regular site, happens to be where the tucson shootout is held.... i thought thats what you meant by patutte, i liked it ...i havent weighed it, my scale only goes up to 23, guess i could try the bathroom scale, or do my fuse and wings seperate on my more "accurate" scale, im guessing im somewhere between 28-30lbs, most guys are on the 28 side, mine always seem heavier for some reason, could be the gallons of epoxy i use , anyway i do love the way that thing runs, must be the rotary valves or whatever they call it, its snappy for sure
< Message edited by diamondave -- 2/24/2009 11:53 PM >
Hide Signatures
       Post #: 396
RE: HOW-To..3D maneuvers - 3/7/2009 6:49 AM
mithrandir
Score: 100
Status: offline
every plane I have ever 3D'd was easier to harrier and hover tail heavy.... more tail heavy was easier... but also krappier for every other flight regime.....
It is OK to go tail heavy to ease learning TR's and harriers... but once you get it... move the CG fwd to neutral or a RCH north of neutral.. My Compy SX and my FUNTANA 140S in a vertical power off dive will pull thru about 5 or 10 degrees in 800 to 1000 feet.....
This plane is near neutral... (Like the CG is .25" ahead of true neutral point... yes.. the fuel tank is on the CG)
http://www.giantcircus.com/Videos/SX-Cable-2009.wmv
LOOKING FOR ENGINEERING WORK ON UAV''S?
http://search9.smartsearchonline.com/asi/jobs/adhocjobsearch.asp
Hide Signatures
       Post #: 397
RE: HOW-To..3D maneuvers - 3/7/2009 2:43 PM
diamondave
Score: 107
Status: online
nice vid
Hide Signatures
(in reply to mithrandir)
       Post #: 398
RE: HOW-To..3D maneuvers - 5/1/2009 6:11 AM
mr.scale
Score: 101
Last Login: 2/28/2010
Status: offline
guess i'll have to get practicing!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Mr.Scale. Fernando L
CORSAIR Brotherhood #43
Hide Signatures
       Post #: 399
RE: HOW-To..3D maneuvers - 5/1/2009 7:59 AM
Lille-bror
Score: 100
Last Login: 1/18/2010
Status: offline
WOW. Very impressive!
110% control. Respect.
What is the maneuver called at 3.02?
0% nitro in car fuel? That works! :-)
http://www.youtube.com/watch?v=ykiffCV4xgk
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
5.266RCU1
