WillHobby Yak 54 ARF Question
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao Velox - Pro Built - ARF
Seller:  SinCityJets
Details:   $2,200.00   |  1/4/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> WillHobby Yak 54 ARF Question
Page: [1] 2 3 4 5 6 7   next >   >>
Login
WillHobby Yak 54 ARF Question - 7/4/2006 7:50:33 AM
cmejaf30
Status: offline
Hello to all...
I recently purchased a Yak 54 kit from Will Hobby and received the package a couple days ago. Everything in the kit looks good so far but I was going through the instruction manual and...well..it's not much of a manual. The manual itself is only like 6 pages long, no text, and a few vague diagrams. I was wondering if anyone has put together one of these ARF's and, if so, they have any tricks that worked well for the model. I was also wondering if anyone had any opinions of what type of servos to put in the plane. I am running a JR radio with a Saito 180 engine. I'm not sure if standard servos will give enough power and the quick response I want from the plane. The plane has a 71" wingspan and a flying weight of about 11 pounds. Let me know what you guys think. Happy flying!!
~Adam
       Post #: 1
RE: WillHobby Yak 54 ARF Question - 7/4/2006 12:06:45 PM
jlkonn
Status: offline
If I may ask...
Did you order your Yak from a distributor in the 'States?
Thanks!
JLK
_____________________________
A goal without a plan is just a dream.
AMA 97605
(in reply to cmejaf30)
       Post #: 2
RE: WillHobby Yak 54 ARF Question - 11/3/2006 11:45:59 AM
bill33
Status: offline
cmejaf30, what about your YAK ?
Are you satisfied with it ?
Can you tell me about this plane, the quality of accessories, the flight, etc.
(in reply to jlkonn)
       Post #: 3
RE: WillHobby Yak 54 ARF Question - 11/3/2006 11:47:22 AM
bill33
Status: offline
thanks
(in reply to bill33)
       Post #: 4
RE: WillHobby Yak 54 ARF Question - 11/3/2006 4:03:18 PM
Checklst
Status: offline
Hey cmejaf30 I would use metal gear servos on a plane with control surfaces this large. The 180 should pull her around with ease, I have a OS 160 on a SS 120 at 11.6 lbs and it will hover and do anything else I ask. The 180 FS should be slightly better.
How long did it take to receive it from Will Hobby?
       Post #: 5
RE: WillHobby Yak 54 ARF Question - 11/4/2006 8:20:17 AM
flapper
Status: offline
Gday,
Compare this model with the CMPro Yak 54 140. I think it is the same. Come from the same factory I believe.
(in reply to Checklst)
       Post #: 6
RE: WillHobby Yak 54 ARF Question - 11/9/2006 3:31:20 AM
panicman
Status: offline
cmejaf30
How is the work on your yak going? I,m looking at this plane and would like any info you can give me.
thanks:Matt
(in reply to flapper)
       Post #: 7
RE: WillHobby Yak 54 ARF Question - 11/14/2006 3:35:39 PM
gapple12
Status: offline
Hello, I also have one of these Yak's from Willhobby.com. It was a challenge to build. The manual is good for starting a fire, that’s about it. I am having a hell of a time with getting the CG set. I am running a SPE 40cc gasser and am going to have to add a ton of weight still. I even put my batteries and receiver up front. Overall, the airplane looks great, hardware sucks, and cowl is very brittle. My cowl was damaged in shipping and Jerry at Will Hobby agreed to send me another one. Haven’t flown her yet, but looking forward to it. Does anyone else have this plane? If so, what did you set your CG too? Thanks
(in reply to panicman)
       Post #: 8
RE: WillHobby Yak 54 ARF Question - 11/15/2006 3:10:09 AM
panicman
Status: offline
gapple12
can you tell me the weight of your plane? I have an O.S 1.60 I want to put in it. But if it is still tail heavy with a 40 cc gasser in it I don't have a chance.
thanks
Matt
(in reply to gapple12)
       Post #: 9
RE: WillHobby Yak 54 ARF Question - 11/15/2006 3:26:41 AM
gapple12
Status: offline
panicman, I dont have a scale but will get one tomorrow from work. My gasser is pretty light. It is a SPE 40cc that I found searching online. Check it out on this link:
http://ak-models.com/spe_engines.htm
       Post #: 10
RE: WillHobby Yak 54 ARF Question - 11/16/2006 3:17:09 AM
Rick75
Status: offline
Any pictures?
       Post #: 11
RE: WillHobby Yak 54 ARF Question - 11/16/2006 3:27:18 AM
gapple12
Status: offline
My camera is not very good, there a little dark..........I will try to get better ones of the engine. What do you think about putting batteries in the cowl with the engine?
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Rick75)
       Post #: 12
RE: WillHobby Yak 54 ARF Question - 12/14/2006 7:30:24 PM
scrafe
Status: offline
I have 2 of these YAK-54's (one unbuilt) I would say that this is a very nice plane for the money, but there are some minor issue with build quality and the hardware is below par with U.S. Mfg's. Some of the hardware such as control horns, and clevises are useless. Another problem is the landing gear. The aluminum gear that comes with the kit is too thin and will collapse even under a normal landing. I reinforced my gear with a 3/16" music wire that runs the entire length under the gear attached with straps to the aluminum, which also serves as the axle for the wheels. The wheels are a little small. OK- now for what is nice about the plane. The overall quality of the plane is good but it takes a little extra time and patience to get things installed and lined up correctly. The YAK flies good! I'm powering mine with an OS 1.60FX with Slimline Pitts muffler, swinging a 20x6-10 TF prop. I have the CG set right on the wing tube, which is a little aft but the plane has no apparent tip stall problems. The yak will hover nicely, knife edges very well, but has some considerable wing rocking during an elevator. The instructions for this plane are basically just pictures and no help to the un-experienced builder, and definitely not a novice fliers plane either. Overall, not a bad plane for price. I'll try to post some pics of mine in the near future.
       Post #: 13
RE: WillHobby Yak 54 ARF Question - 12/15/2006 6:06:26 PM
scrafe
Status: offline
Here are some pics of my Willhobby Yak-54. Powered by an OS 1.60FX w/Slimline Pitts muffler, TF 20x6-10 prop. Check them out in my Gallery link. I'm not sure how to post them as an attachment.
Scrafe
< Message edited by scrafe -- 12/15/2006 7:17:12 PM >
(in reply to scrafe)
       Post #: 14
RE: WillHobby Yak 54 ARF Question - 12/15/2006 9:30:36 PM
bill33
Status: offline
looks very nice
       Post #: 15
RE: WillHobby Yak 54 ARF Question - 2/14/2007 10:53:21 PM
teletrix
Status: offline
Just noticed your WillHobby YAK info. Agree the manual and hardware are useless and the fiberglass parts of very brittle. The landing gear is far too light weight for the plan.I heavily reinforced the firewall and installed a Saito 180. In order to get CG at the location specified on the plans, it took 2.3 lbs of dead weight. How did you fair with the CG problem? It seems to me that CG over the wing tube should work but am afraid to try.
Plane looks nice and may be in a new category - "CTFTK" Closer To Flying Than a Kit.
       Post #: 16
RE: WillHobby Yak 54 ARF Question - 2/15/2007 2:02:58 PM
