RE: WillHobby Yak 54 ARF Question
Tower Hobbies
Logged in as Guest
  Printable Version
A10X Jet Trainer RTF Jet Cat P-60 - RTF
Seller:  LawMaker
Details:   $3,200.00   |  8/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: WillHobby Yak 54 ARF Question
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: WillHobby Yak 54 ARF Question - 5/28/2008 10:21:33 PM
maxun
Status: offline
I think I say that long time ago this planes is for a 45CCminimum.
(in reply to T3beatz)
       Post #: 51
RE: WillHobby Yak 54 ARF Question - 6/2/2008 12:41:10 PM
crycroft
Status: offline
Hmm dont say that i just got one for my saito 150 26cc
_____________________________
plant 'em deep... They will grow"Sometimes I land Vertically!!!
(in reply to maxun)
       Post #: 52
RE: WillHobby Yak 54 ARF Question - 6/2/2008 12:50:54 PM
maxun
Status: offline
this plane is heavy, so learn as you go, I did have this plane, and I have one new in box, the plane is heavy, and need a heavy engine to balance, you can see video in rc universe of this plane flying that I did and on engines the video of the spe40 I install, even with a spe40 the plane was tail heavy and in top of that I did a pull pull system. With a 40 was a border line to plunch from hover and with a 26CC LOL will be a brick with wings. Maybe the 150 saito does better who knows?
(in reply to crycroft)
       Post #: 53
RE: WillHobby Yak 54 ARF Question - 6/2/2008 2:17:06 PM
R/C Foolish
Status: offline
I just put mine together over the weekend. I am using an OS160, pull-pull battery all the way up front and still had to add a 1-1/2 of lead to the nose. I had to reinforce the entire engine box, fiberglass, screws, triangle stock. For the money (got cheap on E-bay) good plane, lousy hardware - never use it, instructions only good for lighting fireplace. Hope to get it in the air tonight.
R/C Foolish
(in reply to maxun)
       Post #: 54
RE: WillHobby Yak 54 ARF Question - 6/2/2008 5:28:24 PM
T3beatz
Status: offline
remember this is a Chinese made arf and the CG in the instructions is off a tad bit... it may not be as bad as it seems, If you plan on doing some 3D with this Yak an aft CG might not be a bad Idea for you... Get you one of those 45 or 52cc engines from Hobby city they cost less than most Glow 2 strokes out there and they should be more than enough to yank this plane around... and at 175 to 209.95 you could get 2 of these and have another on the side.
http://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_listCategoriesAndProducts.asp?catname=Gas+Engines&idCategory=80&ParentCat=55
Build em Fly em Crash em!!!
       Post #: 55
RE: WillHobby Yak 54 ARF Question - 6/6/2008 5:56:43 AM
crycroft
Status: offline
is this the norm 10mm in the fire wall
and what are the little bits wood for ?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 56
RE: WillHobby Yak 54 ARF Question - 6/6/2008 11:18:06 AM
R/C Foolish
Status: offline
It's called "right thrust" built into the firewall and the pieces of wood are for the canopy.
R/C Foolish
       Post #: 57
RE: WillHobby Yak 54 ARF Question - 6/6/2008 11:39:10 AM
crycroft
Status: offline
just look a lot
have you had your one in the air yet ?
(in reply to R/C Foolish)
       Post #: 58
RE: WillHobby Yak 54 ARF Question - 6/6/2008 1:53:53 PM
R/C Foolish
Status: offline
yup, flew fine.
       Post #: 59
RE: WillHobby Yak 54 ARF Question - 6/6/2008 2:47:06 PM
maxun
Status: offline
I have a video of my in 2007 the plane is in the end of the video.
http://youtube.com/watch?v=HWN4m9MJtLI
       Post #: 60
RE: WillHobby Yak 54 ARF Question - 6/6/2008 11:27:54 PM
crycroft
Status: offline
if you had to change something on kit what would it be ?
(in reply to maxun)
       Post #: 61
RE: WillHobby Yak 54 ARF Question - 6/7/2008 12:00:23 AM
R/C Foolish
Status: offline
I changed the whole thing. Flutter on maiden flight, destroyed whole plane. Replaced it with Aeroworks Yak 54, much better quality and lighter.
R/C Foolish
       Post #: 62
RE: WillHobby Yak 54 ARF Question - 6/7/2008 1:47:59 AM
T3beatz
Status: offline
The plane is ok, they should redesign the plane to get the CG a little better, this plane should not have to have a 45cc engine on it to fly right... it should be more at about 8 or 9 lbs, but there comming out at 11 or 12, some even 13... just because of the CG issue.
Mine had a twisted fuse, it wasn't to bad but I couldn't take it back because I noticed it after I put some stuff togther. I learned now to check over everything before i purchase anything now.
       Post #: 63
RE: WillHobby Yak 54 ARF Question - 6/7/2008 5:00:48 AM
crycroft
Status: offline
so seal the wing gaps ?
dubro hinges ?
durbo pull pull
spe 26cc motor
Sullivan 1/4 Scale Double Rudder Horn8-32
Sullivan Tailwheel Bracket.60-1/4
Dubro HingeNylon (15)
Hitec Ultra Speed Sx HS-625MG: JR/RCD/AIRZ
Dubro HD Adj Control Horns.91 & Up
Dubro Super Strength Long Servo Arms
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 64
RE: WillHobby Yak 54 ARF Question - 6/7/2008 5:39:38 AM
T3beatz
