RE: WillHobby Yak 54 ARF Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: WillHobby Yak 54 ARF Question
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: WillHobby Yak 54 ARF Question - 6/8/2008 9:13:44 PM
T3beatz
Status: offline
Hey Maxun do you own a lanier edge 540?
_____________________________
Build em Fly em Crash em!!!
(in reply to maxun)
       Post #: 76
RE: WillHobby Yak 54 ARF Question - 6/9/2008 12:32:04 PM
maxun
Status: offline
yes I do can you can check the videos of rc universe, under members videos and in the shearch tipe tailspinners .
http://www.youtube.com/watch?v=fmGlCY-TK2I
http://www.youtube.com/watch?v=_Ib2og9h7i4
http://www.youtube.com/watch?v=MHcfyl6hnN0
here are the 3 video links. for the lanier edge 94"
(in reply to T3beatz)
       Post #: 77
RE: WillHobby Yak 54 ARF Question - 6/9/2008 2:15:36 PM
T3beatz
Status: offline
You sure you got enough power ! That plane looks like it flys pretty good... I bought the 87" version from tower, then a week later the 94" version went on sale for less money, I almost wet my self! ol well, ya win some ya lose some, (Nice Flying by the way).
(in reply to maxun)
       Post #: 78
RE: WillHobby Yak 54 ARF Question - 6/9/2008 2:24:06 PM
R/C Foolish
Status: online
You didn't buy this plane from Tower. They do not carry Willhobby or CMP.
R/C Foolish
       Post #: 79
RE: WillHobby Yak 54 ARF Question - 6/9/2008 8:02:57 PM
T3beatz
Status: offline
Sorry, I didn't mean the will hobby yak, I was talking about the Lanier edge he had posted on You tube...
(in reply to R/C Foolish)
       Post #: 80
RE: WillHobby Yak 54 ARF Question - 6/13/2008 11:32:19 PM
crycroft
Status: offline
this is what motor i will be useing
Specifications: MLD-28CC
Displacement: 1.7ci (28cc)
configuration: 2C single cylinder air cooled
Carburetor: Walbro pump
Ignition: CDI Electronic ignition w/auto timing advance
Power supply: 4.8v-15.0v
Weight: 2.3ibs (36oz) including ignition and muffler
Maximum output: 2.8 HP
Maximum RPM: 9000
Idel RPM: 1500
Fuel: Unleaded Gasoline
Oil: 2-cycle H-performance (synthetic is recommended)
Mix: 1:30 to 1:45
Prop selection 17x8-18x10
Click to see fullsize image.
Click for fullsize
plant 'em deep... They will grow"Sometimes I land Vertically!!!
       Post #: 81
RE: WillHobby Yak 54 ARF Question - 6/14/2008 12:09:30 AM
T3beatz
Status: offline
That must be the spe 26cc's bigger brother because Melody makes the spe's I'm sure....
(in reply to crycroft)
       Post #: 82
RE: WillHobby Yak 54 ARF Question - 6/14/2008 4:45:16 AM
maxun
Status: offline
if you got the motor use, but you will be under power, the minimum is a 45CC or 40CC. the plane is heavy and need a heavy engine in the nose.
       Post #: 83
RE: WillHobby Yak 54 ARF Question - 6/14/2008 2:39:22 PM
crycroft
Status: offline
ok will go to its only 65 bucks more
SPE-43
Displacement: (42.9cc)
·Configuration: 2C single cylinder air cooled
·Carburetor: Walbro pump
·Ignition: CDI Electronic ignition w/Auto timing advance
·Power supply: 4.8V-18.0V
·Weight 3.2 lbs (51oz) including ignition and muffler
·Maximum output: 3.9 HP
·Maximum RPM 9000
·Idle rpm 1300 RPM
·Fuel: Unleaded Gasoline
·OIL: 2-cycle high performance (Opti-2 is recommended)
·MIX: 1:30 to 1:45
·Prop selection: 18X8 20X10 21X8
Click for fullsize
Click for fullsize
(in reply to maxun)
       Post #: 84
RE: WillHobby Yak 54 ARF Question - 6/14/2008 2:47:11 PM
maxun
Status: offline
Use the 18X8 prop and keep that prop, do not go bigger. Even do the engine can have a bigger prop. With this engine you will balance Ok without the nessesity of lead in the front. Install battery in the engine box for balass, you plane will be abaut 13 LBS all finish and will be a super airplane to fly. You'll see.
       Post #: 85
RE: WillHobby Yak 54 ARF Question - 6/14/2008 3:24:15 PM
crycroft
Status: offline
hope so it will be my first gaser time for bed going flying sunday
18 x 8 ok to run it in ?
(in reply to maxun)
       Post #: 86
RE: WillHobby Yak 54 ARF Question - 6/14/2008 3:52:20 PM
R/C Foolish
Status: online
I wouldn't waste any money on this plane, too heavy. I replaced mine with the Aeroworks 1.20 size Yak 54, much lighter, better built and flys great witH AN os 160. Unlimited verticle, great snaps, hovers easy. Plus the QB go together very easy, nice kits.
R/C Foolish
       Post #: 87
RE: WillHobby Yak 54 ARF Question - 6/14/2008 4:21:20 PM
T3beatz
Status: offline
Well, he said its his first gasser, and this was my first gasser also! I learned alot from this plane, even though it was a tat bit heavier than I wanted it still flew like a champ! even with my little spe 26cc, No 3d or hovers though . I think you will be fine its good for the price and you can always upgrade later on down the road... I sold mine because I wanted something new, and with more power...
       Post #: 88
RE: WillHobby Yak 54 ARF Question - 6/15/2008 6:38:52 PM
maxun
Status: offline
Guy's this is a plane for fun, no for competision, have fun with it, you crash so what 200 dollars frame and the best is that you can tune your engine with this plane and them go to more expecive and better airframe but with a engine that you know is good.
       Post #: 89
RE: WillHobby Yak 54 ARF Question - 6/16/2008 2:04:05 AM
2robinhood
Status: offline
Mine flys really good, even if it is heavy.
Tracks straight and no coupling.
If you read my earlier post, I could not keep the prop off the ground.
Perfect balance, high rate on elevator, and full up, I still counldn't keep the tail on the ground.
Kept hitting the prop, plus using a 18" prop made it that much closer to the ground.
I had TNT Gear make me some taller, wider, and forward swept gear.
That was the best thing I could have done for this plane.
(in reply to maxun)
       Post #: 90
RE: WillHobby Yak 54 ARF Question - 6/16/2008 8:09:48 AM
T3beatz
Status: offline
Nice planes robinhood... I need to get some new landing gear for my 50cc yak, you think they have any that may fit, its about the same size as yours in the pic about 85-87 inches WS...
(in reply to 2robinhood)
       Post #: 91
RE: WillHobby Yak 54 ARF Question - 6/16/2008 10:54:30 AM
crycroft
Status: offline
Hmm nice yak
