RE: Tamiya Subaru Drift Spec Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> RE: Tamiya Subaru Drift Spec Build Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 6:10:19 AM
SJN
Status: offline
Im sorry, but im not sure what tie rods are....
What is the tamiya number and description on those parts ?
_____________________________
Sonnich Johannesen
(in reply to JDM_DRIFTER)
       Post #: 51
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 10:35:37 AM
JDM_DRIFTER
Status: offline
It's ok I got it now.. I'm now close to finshing but my front suspension arms don't move at all all my rear dampers and un even..
"I COULD HAVE BOUGHT A YOKOMO WITH ALL THE MONEY I SPENT.. I'M RIDIN TT-01"
(in reply to SJN)
       Post #: 52
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 2:24:25 PM
SJN
Status: offline
JDM, in step 12, are you sure you installed the inserts B3 and B4 the correct way ?
Sonnich Johannesen
       Post #: 53
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 8:29:40 PM
JDM_DRIFTER
Status: offline
Did you push those plastic spacers into the arms?
(in reply to SJN)
       Post #: 54
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 8:41:15 PM
SJN
Status: offline
the round plastic balls P7 ?
They got a dab of grease, and inserted into the arm.
I then screwed in the MA7 into outer arm piece, and then took inner half, and screwed it on too, so they are joined.
Then I pushed the MB5 with the rough surface first into the hole as shown in the picture.
Are you calling K1 a spacer ?
Sonnich Johannesen
       Post #: 55
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 10:06:33 PM
JDM_DRIFTER
Status: offline
Yeah I was refering to P7. So P7 goes in the arm completely correct? And also how did you get the shock dampers onto the car?
Thanks for your time,
JDM_DRIFTER
quote:
ORIGINAL: SJN
(in reply to SJN)
       Post #: 56
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 10:14:29 PM
SJN
Status: offline
Yes, the P-7 slips rigth into the arm. it should be able to rotate freely and smoothe , once in place.
The shocks just snap onto the balls that you have installed. They are pretty tough to press on with your fingers.
Sonnich Johannesen
       Post #: 57
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 10:18:03 PM
JDM_DRIFTER
Status: offline
Thanks man your more help then the instruction det they gave. Pretty good tutorial man.
THANKS,
JDM_DRIFTER
quote:
ORIGINAL: SJN
(in reply to SJN)
       Post #: 58
RE: Tamiya Subaru Drift Spec Build - 7/12/2006 11:26:19 PM
JDM_DRIFTER
Status: offline
I should be done soon
< Message edited by JDM_DRIFTER -- 7/12/2006 11:27:41 PM >
       Post #: 59
RE: Tamiya Subaru Drift Spec Build - 7/14/2006 1:10:26 AM
JDM_DRIFTER
Status: offline
I'm on vacation right now but when I come back I still need to put my dampers on the car.. What is a easier way to snap them on without struggle?
       Post #: 60
RE: Tamiya Subaru Drift Spec Build - 7/14/2006 1:48:34 AM
pyrodon
Status: offline
hey guys i just got my tt-01d 2day i will post pics when it done.
GOT:TT-01, TA-05, Savage X SS, LST2, Wheely King Rock Crawler, Scale Axial Crawler , Ultra GTP, Blade cp+
       Post #: 61
RE: Tamiya Subaru Drift Spec Build - 7/14/2006 3:35:19 AM
SJN
Status: offline
JDM, you should be able to use your fingers.....
If it extremly hard to snap on, then try and rotate it half a turn, and try again. Im not 100% sure, but maybe they are meant to snap on in one direction only. This seems to work for me.
Pyrodon, looking forward to seeing your paintjob
Sonnich Johannesen
(in reply to pyrodon)
       Post #: 62
RE: Tamiya Subaru Drift Spec Build - 7/14/2006 5:43:17 AM
JDM_DRIFTER
Status: offline
ok cool. I will try it out. I also painted my body already so pix will be up soon. Mine has a clean white look to it
(in reply to SJN)
       Post #: 63
RE: Tamiya Subaru Drift Spec Build - 7/14/2006 5:48:15 AM
Rc_drifter36
Status: offline
you should be able to use your fingers to push them on. But if it is too much of a struggle, get needle nose pliers and somthing soft to put inbetween them and the shock and gently squeeze until they snap into place
Can You Drift A Mini-T??
AS magnat would say "get that Tail out and Keep it out!!"LOL
       Post #: 64
RE: Tamiya Subaru Drift Spec Build - 8/12/2006 8:20:21 PM
Bumer
Status: offline
Hello! I'm thinking about buying this Tamiya Subaru Drift Spec. I already have receiver, transmitter, and servos, but i wonder if i need this electronic speed control too, or is it included in this kit?
       Post #: 65
RE: Tamiya Subaru Drift Spec Build - 8/12/2006 8:22:52 PM
em x 6 racer
Status: offline
No it comes with that.
(in reply to Bumer)
       Post #: 66
RE: Tamiya Subaru Drift Spec Build - 8/12/2006 8:28:40 PM
SJN
Status: offline
yea, here it is http://image.rcuniverse.com/forum/upfiles/35977/Kb44007.jpg
Sonnich Johannesen
(in reply to em x 6 racer)
       Post #: 67
