Fuel tank/motor issues.... Again...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> Fuel tank/motor issues.... Again... Page: [1] 2 3   next >   >>
Login
Fuel tank/motor issues.... Again... - 7/4/2006 7:12:14 PM
ThermalRD
Status: offline
Well i had gone over this last summer when i bought this truck, and its apparent again this year. This truck needs constant tuning. Seems every 3 minutes the tune changes. Does anyone have a newer genesis, or Nemesis, that DOESNT do this. If i tune this to run cool all the time, it will run horribly slow for the first half tank of fuel. Then get slightly better near the end. I just wonder if a newer .46 would help, or if this is just common with this truck. Right now its just not fun. I had told myself i was done selling trucks from my collection, but this ones about to go...
       Post #: 1
RE: Fuel tank/motor issues.... Again... - 7/4/2006 7:54:58 PM
blackrain
Status: offline
i wasnt to crazy about the stock engine my self thermal it gave me some issue s on my nemesis. but since i changed to a .28 i couldnt be happier. other people seemed to have better luck with the stock engine . i wouldnt sell it i would mod the engine mount and go with a .28 or .32 or wait till the new CEN GST come out with its new upgraded 46. i sold my engine on ebay with pipe and made 135 dollars on it
_____________________________
mugen mbx5t hott mod nova 528, , Cen nemesis picco 28, lst2 hott mod nova 528, hyper 8 buggy rb s5, hpi baja ss
(in reply to ThermalRD)
       Post #: 2
RE: Fuel tank/motor issues.... Again... - 7/4/2006 10:04:28 PM
Bash-m-up
Status: offline
This is a common issue with all the trucks with fuel tank s like this. HotBodies, Savage, Gen's, and Nem's. The only way to omit the whole problem is to nip it early, as early as when you first break in the engine . If you tune the engine with only a half tank of fuel and get the temps to run fine there with a good smoke trail at around 260-280F then you should do fine even with a full tank . Only thing is you may need to go with a hotter plug to keep it running at the full tank . But give that a try. Tune your LSN and HSN with only a half tank in those temps. At a half with temps in 260 you will end up empty at 280. With a full tank it will seem a bit slugish but will get going after it warms up and should temp at about 220-230 full. I hope this works for you, the only other option is to go with the HB's style tank for the savage and mod it into your CEN to work like a buggy.
If it's not broken, then your not bashin hard enough.
Savage X.
(in reply to blackrain)
       Post #: 3
RE: Fuel tank/motor issues.... Again... - 7/5/2006 1:02:21 AM
ThermalRD
Status: offline
Bash-m-up, that is exactly what Andrew Smolnick had me do last year, and i've done this year. To me, its un-acceptable. The performance at a full tank , when tuned that way, is horrible. Theres no point in having a huge motor, if it doesnt give huge performance. I mean what is CEN doing wrong here? I've had several savages, and never experienced the half tank lean issue to this degree. Further more, i can run the 220cc tank on my LST without any issue s at all. I sent an e-mail over to the guys at CEN one last time. Im hoping theres a carb fix, or motor update, or some solid fix for this. I like the truck, but this issue just kills the fun. I can only imagine how bad im gonna lose my butt, when i sell this truck.
(in reply to Bash-m-up)
       Post #: 4
RE: Fuel tank/motor issues.... Again... - 7/5/2006 2:43:33 AM
The Real Dogman
Status: offline
Hey boys, I noticed this problem when I first tuned my Genesis @ full tank . Once I tuned it with half tank it was alot better, but here in the desert were it gets up to 105 degrees in the summer, the problem would re-appear were no tuning would help as well as the hot ambient air was a fight to tune without overheating anyway. So I got to thinking "why". I had a thought,, so after checking a few things on the trucks fuel delivery system, this is what I came up with:
First thing we need be sure I understand how the fuel delivery system works. The Exhaust provides pressure to the fuel tank via a pressure nipple and fuel tubing. The pressurized fuel tank pushes fuel thru the [restrictive]filter in to the waiting carb which via the venturi effect and High Speed Needle actually draws a measured amount of fuel to help delivery, Thus the more pressure in the tank the easier it is to get a good volumn of fuel in the carb. And the most important thing to remember is, Air Pressure=Compressed Air=Increased Air Volumn In A Given Space. Ok, thats it in a nut shell.
Now the problem with this simple system is the pressurized fuel tank cannot hold a constant pressure to feed the fuel line and carb due to the changing volumn of air inside the tank . To be more clear, when the tank is full there is a small amount of pressurized air volumn in the tank , quicker to build pressure. As the fuel gets used up, there is more air volumn in the tank to be pressurized, thus more volumn that can be compressed , takes longer to be compressed and build pressure.Theoretically you will need more Pressurized volumn to keep a constant fuel flow to the carb, however the exhuast pressure nipple will provide more pressurized volumn as the engine is revved higher but when the engine suddenly slows the lower pressurized volumn at exhaust nipple cannot compensate the gain of air volumn in a half full tank quickly enough to maintain the same pressure thru the filter and tube, as well as possible release of pressure exiting back out the exhuast nipple from the tank , thus a flame out due to the sudden loss of pressure at the carb.
When you tune the carb you are actually controlling how much fuel(volumn) is allowed into the venturi, so when you tune with a full tank it is easier to build pressure in a small volumn of space and you dont need to let as much fuel into the venturi. When you tune at lower level of fuel in the tank (preferrably half full) you will need to allow more fuel in to compensate for the lower pressure or lower volumn at the venturi, to minimize flame-outs When there is a sudden drop in RPM's(exhuast pressure). But if you allow too much fuel in you will be running very rich, so a fine line must be maintained to run at optimal performance. This all is highly affected by atmospheric condintions as well, but that is whole new topic.
This is all made more difficult by the somewhat restrictive brass filter in the tank , which I will be removing to see if it helps.
holy$hit!!!I hope that was clear.
Now, if we were to solve this problem what would we need to do?? HHMM...Maybe a check valve between the Exhaust Pressure Nipple and Fuel Tank might help with sudden back feed from the tank to exhaust nipple..but what about maintaining pressure in a higher air volumn condition??have to think about that one some more.....
< Message edited by dogman_1@hotmail.com -- 7/5/2006 2:52:32 AM >
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Arena/3 Tubers/Axial Comp Crawler/Raze
       Post #: 5
RE: Fuel tank/motor issues.... Again... - 7/5/2006 12:51:14 PM
Scott_GTR
Status: offline
It sounds like a one way valve would be the solution as you suggest.
But why has CEN not come up with this fix?????
(in reply to The Real Dogman)
       Post #: 6
RE: Fuel tank/motor issues.... Again... - 7/5/2006 1:46:15 PM
ThermalRD
Status: offline
I thought that last year. I put one on the pressure line at the time, and it continually flooded the engine .
quote:
ORIGINAL: Scott_GTR
(in reply to Scott_GTR)
       Post #: 7
RE: Fuel tank/motor issues.... Again... - 7/5/2006 2:03:38 PM
The Real Dogman
Status: offline
Thermal, did you retune after installing the check valve and running it for a bit??
       Post #: 8
RE: Fuel tank/motor issues.... Again... - 7/5/2006 5:27:10 PM
jombo
Status: offline
quote: This is all made more difficult by the somewhat restrictive brass filter in the tank , which I will be removing to see if it helps.
i removed mine a while ago but havent tried it yet because of the move. i just installed an inline fuel filter from a plane i had and hopfully it will help.
here is my other post that i got no responce to either by cen
http://www.rcuniverse.com/forum/m_4364205/anchors_4364205/mpage_1/key_/anchor/tm.htm#4364205
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by jombo -- 7/5/2006 5:33:09 PM >
ka-chow
lst2, there is no substitute lst forums, ground pounders rc
       Post #: 9
RE: Fuel tank/motor issues.... Again... - 7/5/2006 8:27:38 PM
dustin7837
Status: offline
quote:
ORIGINAL: ThermalRD
quote:
ORIGINAL: Scott_GTR
how about a check valve and a regulator?
an inline regulator would make the tank pressure up till the lid popped open, but if you were to screw a regulator into the tank , so that the tank stays at a constant pressure....
Would that work?
Where do you even get valves that small?
MORE POWER!!!
       Post #: 10
RE: Fuel tank/motor issues.... Again... - 7/6/2006 2:47:13 AM
The Real Dogman
Status: offline
Check this site out and their cheap!!
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=45&product%5Fid=20411&gclid=CMCg6bj7-4UCFSIrIgodzWQuTg&cookie%5Ftest=1
here is another one but I'm noty sure if we need it yet.
http://www.globalspec.com/FeaturedProducts/Detail/BeswickEngineering/MICROMINIATURE_PRESSURE_REGULATOR/21641/0
Click for fullsize
Click for fullsize
(in reply to dustin7837)
       Post #: 11
RE: Fuel tank/motor issues.... Again... - 7/6/2006 3:36:32 AM
Timmahh
Status: offline
i had thought about this as i was having issue s with my Maxx, and i thought about the check valve, but you would also need to put in a pop valve as to allow any pressure over 11lbs i think it is allowed to be released. can find the check valve via any rc plane place, but the pop valve was an issue i couldnt find.
Timmahh
       Post #: 12
RE: Fuel tank/motor issues.... Again... - 7/6/2006 3:55:04 AM
The Real Dogman
Status: offline
I have not checked but I would be suprised if that kinda of pressure is coming thru the pressure tube. But you never know..
(in reply to Timmahh)
       Post #: 13
RE: Fuel tank/motor issues.... Again... - 7/6/2006 6:49:49 AM
dustin7837
Status: offline
A regulator like that one in the pic would function like a pop valve, but smoother. Just drilla little hole in your tank and thread that in and set it for whatever pressure you want the tank to stay at, and pua check valve in the line form the exhaust to the tank , and you should have a constant pressure from full to empty....
Anyone know where to get a price on that little regulator??
And does anyone have a pressure tester taht would be suitable for less than 20 PSIg?
We would need to know what the tank pressure is while the truck is running good, and set the regulator at that.
Good find on that reg, dogman. Never seen one that small.
MORE POWER!!!
       Post #: 14
RE: Fuel tank/motor issues.... Again... - 7/7/2006 5:04:23 AM
