RE: ANYONE RUNNING LRP SPEC 3 YET
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> RE: ANYONE RUNNING LRP SPEC 3 YET Page: <<   < prev  1 [2]
Login
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/13/2006 2:16:29 PM
jjaus
Status: offline
antsb, just found this at killer hobbies
http://www.killerhobbies.com/Browse_Item_Details.asp/Item_ID/604495/categ_id//parent_ids//Name/Team_Orion_CRF_V6_adjustable_clutch_-_ORI88600
jjaus
_____________________________
If it aint broke upgrade it any way!!!
(in reply to antsb)
       Post #: 26
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/13/2006 2:26:13 PM
mikewoodkozar
Status: offline
Yes that is where i got the clutches from, but, remember that you will need a sleeved bell to run this clutch as the shoes will not engage far enough without one
Its chocolate, its peppermint, its delicious.
(in reply to jjaus)
       Post #: 27
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/13/2006 2:31:19 PM
jjaus
Status: offline
Mike, would any engineering shop be able to do this as i'm not really equiped to do it at home and if so how much do they sleeve it down by?
Cheers jjaus
(in reply to mikewoodkozar)
       Post #: 28
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/14/2006 3:45:25 PM
mikewoodkozar
Status: offline
they actually have to make a sleeve out of steel (i think) and press it into the bell. The sleeve itself is pretty thin, doesnt take much. I think pretty much any machine shop can do it
(in reply to jjaus)
       Post #: 29
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/14/2006 7:23:35 PM
antsb
Status: offline
thanks for that its a great help
wot about exausts though? this engine just keeps empresing me more and more
academy sb\shumacher mi2 carbon\ losixxx4g+\ losi lst!!!!
(in reply to jjaus)
       Post #: 30
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/14/2006 9:57:24 PM
jjaus
Status: offline
Well Mike, after posting all that stuff on the other thread about Drakes no pressure line i've done a backflip and bought a Nosram RS.28 V3 which is the same engine as the LRP spec three and i've just finished getting it in last night so now i cant wait to run it in "now i'm officially one of the big boys" out with old (Mach) and in with the new.
       Post #: 31
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/14/2006 10:42:39 PM
mikewoodkozar
Status: offline
quote:
ORIGINAL: jjaus
muhahaha cool man, you should post some pics of that new engine (i am very curious).
Do you have a link to where you got it and how much it cost ya?
(in reply to jjaus)
       Post #: 32
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/15/2006 6:04:24 AM
jjaus
Status: offline
mike,i bought it from my Lhs (very small shop) but below is the link to the web site for the engine, it came as a pull start but the losi (mach) spin start went on with just the elongation of the holes. Apparently the LRP, Nosram and one other (read it in a thread)are all made by golden lion in taiwan. i'm thinking its only equivalent to the spec 2 as it is 6+1 port although the thead i read said it was the same as the spec 3 anyway i ran my first tank through it and holy cow even running as rich as it is it brought a big smile to my face. its sounds wild (probably the RD-Logics twin stinger i'm running with it). i can tell this things gonna haul a$$ when its got a tune trown at it.
http://www.nosram.com/products.asp?id=41
Also mike it cost $289 oz which is $218 usd (ouch, Nasty little hobby shop) still everything gets expensive by the time it gets to us out in the burbs of oz.
< Message edited by jjaus -- 7/15/2006 6:18:52 AM >
       Post #: 33
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/17/2006 5:55:29 AM
wlfgnggtr
Status: offline
Try the Werks pipe for the LST on the spec 3. works great, or the Ofna 086 isn't to bad either...
(in reply to jjaus)
       Post #: 34
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/17/2006 8:39:14 AM
jjaus
Status: offline
Hey fellas
just wondering what temps your Lrp engines seem happiest at once run in?
i'm running mine in at 195-200 at about half throttle, does this seem about right?
it holds temp so well that i can move the temp 2 or 3 degrees up or down quite accurately. Bl@@dy good engine!
(in reply to wlfgnggtr)
       Post #: 35
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/17/2006 2:32:08 PM
mikewoodkozar
Status: offline
well its been in the high 90's here in michigan, with about 98% humidity (YUCK!), so i have found with the body on and really running it, it sits at about 240ish
(in reply to jjaus)
       Post #: 36
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/18/2006 8:35:13 AM
jjaus
Status: offline
Thanks mate,
Temps here in brisbane (Oz) are about 75 in your scale (quite nice)
The Mach used to make good power at about 245 or so.
jj
       Post #: 37
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/18/2006 12:43:39 PM
jjaus
Status: offline
Hey Mike,
Here's a few pics of the installed Nosram RS.28
jjaus
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by jjaus -- 7/18/2006 12:48:16 PM >
       Post #: 38
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/21/2006 3:39:42 PM
antsb
Status: offline
should i be altering my head shims as it says in instructions iam using 20%rtr fuel?
       Post #: 39
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/21/2006 3:43:37 PM
mikewoodkozar
Status: offline
i am running one shim in my LRP's and i am using sidewinder 30%. It runs great, so i dont really see a need, but you may want to keep an extra couple head shims around to compensate for different fuel, or if yours isnt running as well. Its always an option and you could always expierement and see what works best for you.
(in reply to antsb)
       Post #: 40
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/21/2006 3:46:17 PM
antsb
Status: offline
thanks man thats great
       Post #: 41
RE: ANYONE RUNNING LRP SPEC 3 YET - 7/21/2006 10:04:00 PM
jjaus
Status: offline
Mike, just wondering what glow plugs you use in the lrp's?
The Nosram came with an "R5" (what ever that is, i think its an os plug), seems to run fine with it it,
