ultimate 27% wing tube
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> ultimate 27% wing tube
Page: [1]
Login
ultimate 27% wing tube - 7/5/2006 3:30:54 AM
jlmrph
Status: offline
to all 50 cc aeroworks ultimate biplane owners
Has anyone had to replace the wing tubes . If so where did you find them and what are the exact dimensions. I'm needing to replace mine with either aluminum or cf tubes. Most places I've looked dont have a long enough tube since the OD is only from my rough measurements one-half inch. thanks for any help jlmrph
       Post #: 1
RE: ultimate 27% wing tube - 7/13/2006 4:54:29 AM
mikec3d
Status: offline
Airborne models , good luck you'll need it, how bad r they,can you straighten them,be sure to say you have the old design so they dont send u the new ones like they did me. PM me for more details.
(in reply to jlmrph)
       Post #: 2
RE: ultimate 27% wing tube - 11/2/2006 11:54:12 PM
Twistawrecka
Status: offline
Same thing just hapened to me. I have an Aerworks Ultimate and ordered new wing tubes from AB Models. The are about .020 of an inch too big in diameter.
My top one is wearing where it goes through the center cabane strut so I want to replace it. If I can't find new ones I guess I'll have to cut the bad section out of the old tube and machine a new piece to join the two halves, probably from solid aluminum about 6 inchees long. Then secure it in the halves probably epoxy or a small roll pin. Anyone tried this repair method? Or found an source for new wings tubes that fit? I wouldn't use CF since it will wear rather quickly on that center cabane.
(in reply to mikec3d)
       Post #: 3
RE: ultimate 27% wing tube - 12/8/2006 2:10:48 AM
Twistawrecka
Status: offline
If you're patient with AB models they can get you the wing tubes (14mm), mine just should up and fit perfectly
(in reply to Twistawrecka)
       Post #: 4
RE: ultimate 27% wing tube - 12/13/2006 4:39:18 AM
WarbirdAirRacer
Status: offline
i called AB models and they said it would be a 3 week wait for the wing tubes....hope this helps.
_____________________________
Tat-Tude 379
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU4
